Edge detection, which parameter used for get autofocus working ?
abimann
Member level 4
Hello everyone PlS help !!!
Is that is same FrameEdgeCount with summa in a following code ? or how to make this ?
Frame edge count i found in youtube in 2:41 . I want to use it to make autofocus for my camera. Code from github ,
 architecture Behavioral of edge_sobel is
begin
	edge_sobel: process (pclk_i)
		variable summax, summay : std_logic_vector(10 downto 0);
		variable summa1, summa2 : std_logic_vector(10 downto 0);
		variable summa          : std_logic_vector(10 downto 0);
	begin
		if (pclk_i'event and pclk_i = '1') then
			rsync_o <= rsync_i;
			fsync_o <= fsync_i;
		if fsync_i = '1' then
			if rsync_i = '1' then
															-- x2
				summax:=("000" & pdata3)+("00" & pdata6 & '0')+("000" & pdata9)
					-("000" & pdata1)-("00" & pdata4 & '0')-("000" & pdata7);
															-- x2
				summay:=("000" & pdata7)+("00" & pdata8 & '0')+("000" & pdata9)
					-("000" & pdata1)-("00" & pdata2 & '0')-("000" & pdata3);
				-- Here is computed the absolute value of the numbers
				if summax(10)='1' then
					summa1:= not summax+1;
				else
					summa1:= summax;
				end if;
				if summay(10)='1' then
					summa2:= not summay+1;
				else
					summa2:= summay;
				end if;
				summa:=summa1+summa2;
				summa_out<=summa;
				-- Threshold = 127
				if summa>"00001111111" then
					pdata_o<=(others => '1');
				else
					pdata_o<=summa(DATA_WIDTH-	1 downto 0);
				end if;
			END IF;
		end if;
Sobel fileter result , has some display problem cannot find out why. frameedgesumm.png
I dont understand the quesiton? can you please rephrase exactly what the problem is?
what value or what variable need to be use from edge detection code to send to servo or stepper motor controller to regulate auto focus ?
you may focus on background and you may focus on foreground. Thus you need to specify the area of interest.
Generally sharper edges means a higher frequency range.
Thus a high pass filter (or differentiation) plus some kind of calculatein about the high pass filtered ampliltude (like RMS) should do the job.
I assume if you search the internet you will find optimized focus caclulation methods.
Klaus
Pulse width modulation? Surely your stepper motor controller has a datasheet?
I would imagine you have some threshold from the sorbel filter. For example here we have a blob - window - of values exceeding threshold, therefore we adjust motor, until blob is sharp line.
no good experience in vhdl
when so many edges , it mean camera best focused, so I think need to just invert data and summ for every frame.. pls help with code .
when video = '1' video is std_logic
x_int integer range from 0 to 639
y_int integer range from 0 to 479
DATA_O - output from sobel filter
sim is unsigned
sim_out also unsigned
data_int <= to_unsigned(DATA_O);
process(clk26)
begin
if rising_edge(clk26) then
if video = '1' then
sim:=sim+data_int;
if y_int = 478 then
sim_out<=sim;
if y_int = 479 then
sim:=(others => 0);
sim_out:=(others => 0);
end if;
end if;
end if;
end if;
end process;
Woah, hold up.
Do you know the difference between variables and signals?
Also please use indentation. That way you can see logical errors - see nested if below
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
 process(clk26)
 begin
     if video = '1' then
       sim:=sim+data_int;  -- This is a variable assignment? Is your variable local/shared?.
       if y_int = 478 then
         sim_out<=sim;
         if y_int = 479 then -- This is a nested IF, It is only analysed if parent if is true. Since parent implies this is false it will never execute.
           sim:=(others => 0);
         end if;
       end if;
     end if;
   end if;
 end process;
Look at comments I've placed inside
Hello , from VGA controller coming x and y , x is rows which is from 0 to 639 and y is a row's summ of x, from 0 to 479, so it need to find summ of all Data_int when video is equal to 1,
