ALT_SLD_FAB error in DE1_SoC_SDRAM_Nios_Test project
ukoc
Newbie level 2
Hello,
I have been using Quartus Prime 17.0v. When I compile DE1_SoC_SDRAM_Nios_Test project which is in De1-Soc SystemCD, it gives following errors.
Code dot - [expand]
8
9
Error (11176): Set_instance_parameter_value: There is no parameter named DESIGN_HASH on instance alt_sld_fab
Error (11176): Alt_sld_fab.: version not allowed for EModuleProperty, must be in {[DESCRIPTION, NAME, VERSION, MODULE_TCL_FILE, MODULE_DIRECTORY, INTERNAL, HIDE_FROM_SOPC, HIDE_FROM_QSYS, HIDE_FROM_QUARTUS, OPAQUE_ADDRESS_MAP, GROUP, AUTHOR, ICON_PATH, DISPLAY_NAME, DATASHEET_URL, TOP_LEVEL_HDL_FILE, TOP_LEVEL_HDL_MODULE, INSTANTIATE_IN_SYSTEM_MODULE, EDITABLE, VALIDATION_CALLBACK, EDITOR_CALLBACK, ELABORATION_CALLBACK, GENERATION_CALLBACK, COMPOSITION_CALLBACK, PARAMETER_UPGRADE_CALLBACK, OUTDATED_IP_FILE, ANALYZE_HDL, STATIC_TOP_LEVEL_MODULE_NAME, FIX_110_VIP_PATH, SUPPORTED_DEVICE_FAMILIES, REPORT_TO_TALKBACK, ALLOW_GREYBOX_GENERATION, SUPPRESS_WARNINGS, STRUCTURAL_COMPOSITION_CALLBACK, NATIVE_INTERPRETER, PREFERRED_SIMULATION_LANGUAGE, REPORT_HIERARCHY, UPGRADEABLE_FROM]}
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 32 warnings
Error: Peak virtual memory: 883 megabytes
Error: Processing ended: Fri Mar 02 17:26:26 2018
Error: Elapsed time: 00:00:52
Error: Total CPU time (on all processors): 00:01:22
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 32 warnings
As I read on Altera's support for these features SignalTap™ II Logic AnalyzerIn-System Memory Content EditorLogic Analyzer InterfaceNios® II JTAG UARTNios II On-Chip Debugging (OCD) quartus using sld_hub file and I'm using 2 of them.
For this error...
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"...
Support says delete ./megafunction folder in archive...
but I cant find this folder in project. This folder is in Quartus Library.
I think there is problem in ALT_SLD_FAB files but I can not solve the problem yet.
I would be glad, if you help.
