BigBoss
Advanced Member level 6
The coils are printed on a substrate and a metallic proximity may create such problem( because the frequency is too high). I hope the oscillator is well screened.BigBoss,
My wrong - of course you have right. I just quickly compare in mind HEMT to FET.
frankrose,
I used simple "needle" probe which you can use to measuring ICs (pads are quite small) with shielded coax. I connected capacitors as closer as possible to the pad. I also try with 1k resistor as you wrote. Strange is fact, that distortion are visible only when I touch Vref pad... example: I touch it only bu using simple small screwdriver, thin wire, needle, tweezers (all without connection to power supply! ) and modulation just occurs...
I guess there is a screening error and if the coils are close to this Vref pad, some EM coupling may occur and this force the oscillator to change the frequency.Thus, the oscillator starts to swing..
I lived similar problem years ago, an electrolytic capacitor was pretty close to oscillator's coil and when I click the PCB the oscillator was swinging to left and right.A mechanical coupling between coil and
cap. was creating small shift on the frequency.
Can you post the layout and the enclosure if it doesn't harm you ??
