How to find characteristic impedance of microstrip with an unknown substrate?
Luckyer
Newbie level 3
Hi all,
I probably have a simple question.
I have to design a circuit with a multilayer substrate which i cannot know his real permitivity nor other parameters but dimensions, I can just use it to my simulations and momentum.
But i need to make a 50 Ohms / 90º microstrip line. After doing the simulations and obtaining the S parameters, how could I obtain Z0 just with S parameters?
I put a 50 Ohm load at the line and made the Z0 = ZL (1-S(1,1))/(1+(S(1,1)) relation with a known line and substrate (W and L for 50 Ohm and 90º), but I can't obtain feasible results (Z0 = 0.2 < 80º)
Thanks ! :)
If you have to design it then:
* either you need to know it
* or you need to specify it
--> Discuss this with your PCB manufacturer
I may explained wrong.
I get the substrate specifications, but is multilayer, so I have differents permitivities for each layer but its behaviour is different all together. I did the momentum simulation of a kind of 50 Ohm / 90º degrees line (based on a medium of all layers permitivities, but it isnt the real permitivity) and obtained the S Parameters.
Now i want to know if its really 50 Ohms / 90º degrees, with the objetive of knowing how far of it is it and how to correct it later.
In conclusion, know the Zc and electric length of a microstrip line based on just the S parameters.
Thanks anyway!
Convert S={S11, S12 ; S21, S22} to F={A, B ; C, D}.
You can get Z0=sqrt(B/C).
2*pi*Length/Lambda=acos(A)=acos(D)
Nice! It worked like a charm. Now i think i could work with any substrate if i cant know its real permitivity.
Thanks!! :)
What i do...i take my simulation of the thru transmission line, plot S11 on a smith chart and sweep the frequency from say 1 to 10 GHz. It will draw a small circle on the smith chart, and the CENTER of that circle is the characteristic impedance of the line.
So this is showing a 40 ohm characteristic impedance line (assuming your simulation ports were 50 ohms).
Is that what you were asking?
