Through hole component on a one single layer PCB (IMS)
Winsu
Full Member level 3
Hello Everyone,
I have been trying to find a SMD common mode choke with the same specifications than this one:
https://www.digikey.co.uk/product-detail/en/kemet/SC-05-30J/399-10652-ND/4290718
At the moment it hasn't been possible, so I'm looking for solutions to fit a through hole component on an IMS single layer PCB. The PCB is sitting on a heat sink ( that's why it is single layer), so we can't make drill holes all the way through. I have though on cutting the legs of the common mode choke and solder it by hand, but it doesn't look a very secure solution. Any idea to fit it on?.
Thanks,
Winsu
with an approximate weight of 30g it will be hard to to in SMD.
The problem is the mechanical ruggedness against vibration.
Solutions:
* use a suitable glue for better mechanical ruggedness
* reduce the specification for your product regarding acceleration / vibration.
Reactions: Winsu
    Winsu
I don't see a SMD CM choke with same parameters. There's e.g. Laird CMX1211W182B-10, 9A - 1.8 mH or Coilcraft CG3528-AL, 3.1 A - 3 mH. You may need to make a custom designed SMD coil. I agree with KlausST that weight of large SMD coils may be a problem.
Reactions: Winsu
    Winsu
Maybe not stable enough: SMD sil sockets to accommodate those four pins.
Reactions: Winsu
    Winsu
