Opamp design in mentor graphics
gopalece
Newbie
I am designing opamp in mentor graphics.How can I get process parameters
vth, kn
What do you mean under "process parameters"?
Energy, doses, and angles of implants? Oxide thicknesses?
Or final doping profiles?
Or transistors' Vt values?
Or coefficients A determining device mismatch?
Your question is very vague...
How can I get Vth,Kn,mobility,oxide capacitance of mosfet in Mentor graphics
Design of opamp in mentor graphics
How can I know model of mosfet in mentor graphics(Technology 130nm).
Foundry PDK, which you would get from the foundry
you plan to fabricate at.
Or find one of the gpdk releases that match the node
if this is just a "paper exercise" that will never go to
fab.
"I want to build a house. What is lumber?"
Conceptually, this info is provided with PDK - which, physically, is a set of files stored on a disk somewhere - you need to ask people who installed the PDK, what is the path.
Some device parameters, measured characteristics, etc. may be found documents like Design Rule Manual.
