[SOLVED] How to hide first time running digit 00.00
sacban
Junior Member level 3
Hello Everyone,
I made a project for a volt meter, this project already working fine, just I want to change the method during first time running.
First time running, I got digit 00.00 onto LCD appears, then once the voltage read source voltage "example 4,5 volt" the digit reading for 04.50, this is true, how can I change that way, when first time running the digit never show digit 00.00, then once have voltage 4.5 volt the digit will show 4.50.
Below are the code :
void main()
 ADCON1=0x82;
 TRISA=0XFF;
 Lcd_Init();
 lcd_cmd(_LCD_CLEAR);
 lcd_cmd(_LCD_CURSOR_OFF);
 Lcd_Out(1,5," Meter");
 lcd_out(2,1,"VOLT:");
 for(;;){
         adc_value=ADC_Read(0);
         adc_value=adc_value*5000/1023;
          hit1=adc_value/1000;
          hit2=(adc_value%1000)/100;
          hit3=((adc_Value%1000)%100)/10;
          hit4=((adc_value%1000)%100)%10;
          lcd_chr(2,11,48+hitung1);
          lcd_chr_cp(hitung2+48);
          lcd_chr_cp('.');
          lcd_chr_cp(48+hitung3);
          lcd_chr_cp(48+hitung4);
          lcd_chr_cp('V');
         delay_ms(20);
I hope someone there will help me solve this out.
Thank you.
Try this. It just needs a if() condition.
for(;;){
	if(adc_value > 0.0) {
          lcd_chr_cp('.');
          lcd_chr_cp('V');
         delay_ms(20);
My thoughts:
* What's wrong when it shows "00.00"?
* there are different variable names. I don't understand howit can work. "hit1" -> "hitung1"
* with the code of post#2 ... it never shows 0. So if you immediately remove the voltage, then it may "01.23" while the input voltage is 0V.
* a delay of 20ms is not useful. Our eyes can't read more than 3-4 values per second, thus a delay of 300ms is more suitable.
Klaus
Why not by simply handling digits, writing a space character instead Zero ?
Something like that (eg. for the first digit), not tested :
if (hitung1)
else
          lcd_chr(2,11, ' ');
Hello There,
Thank you for your respond according my question.
As well your suggestion below are :
baileychic : I trying that method but doesn't working.
KlausST : My thoughts:
** It's no wrong but more better if the zero hidden before use.
** Yes.....you are correct, there is should be hit1 not hitung....:oops:
** Yes.....If I go to lower voltage example 9 volt, then will show 09.00
** It's ok for the Delay_ms(20), but can change to 300ms.
Thank you......
andre_teprom : I trying your method and that working as well my expected.
unsigned long adc_value; //Declaration of adc_value (variable)
unsigned char hit1, hit2,hit3,hit4; //Declaration of hit (variable)
void main()
ADCON1=0x82;
TRISA=0XFF;
Lcd_Init();
Lcd_Out(1,1,"VOLT METER");
for(;;){
adc_value=ADC_Read(0); // Get AN0 PIN
adc_value=adc_value*5000/1023; // Calculate ADC_Read for 4.88 Vdc
// lcd_chr(2,11,48+hit1);
if (hit1) // Follow andrew method edaforum
else
lcd_chr(2,11, ' ');
lcd_chr_cp(hit2+48);
lcd_chr_cp('.');
lcd_chr_cp(48+hit3);
lcd_chr_cp(48+hit4);
lcd_chr_cp('V');
// lcd_chr(2,11, ' ');
delay_ms(20);
Thank you.
