dayana42200
Junior Member level 3
Hi all.
Based on the log report below, I dont unserstand why there is error during clock tree synthesis?
icc_shell> clock_opt
Warning: Starting from the 2011.09-SP4 release, clock_opt will NOT perform congestion-driven placement by default. (PSYN-1111)
The options for clock_opt:
COPT: Clock Tree Synthesis : Yes
COPT: Post CTS Optimization : Yes
COPT: Concurrent Clock/Data Optimization : No
COPT: Operation Condition : max
COPT: Balance Inter Clock Delay : No
COPT: Route Clock Nets : Yes
COPT: Update Clock Latency : No
COPT: Optimize Hold for All Clocks : No
COPT: Optimize Hold Timing Only : No
COPT: Optimize DFT : No
COPT: Area Recovery : No
COPT: Size Only : No
COPT: In Place Size Only : No
COPT: Congestion removal : No
COPT: Optimize Power : No
Executing ICC clock_opt...
medium
Building clock tree...
Operating Condition is max
Information: There is no scenario with cts_mode set to true, CTS will use old cts_scenario flow. (CTS-1115)
CTS Operating Condition(s): MAX(Worst)
Loading design 'Sync_Rst_CompTop'
Information: Library Manufacturing Grid(GridResolution) : 5
Information: Time Unit from Milkyway design library: 'ns'
Information: Design Library and main library timing units are matched - 1.000 ns.
Information: Resistance Unit from Milkyway design library: 'kohm'
Information: Design Library and main library resistance units are matched - 1.000 kohm.
Information: Capacitance Unit from Milkyway design library: 'pf'
Information: Design Library and main library capacitance units are matched - 1.000 pf.
[begin initializing data for legality checker]
Initializing Data Structure ...
INFO: legalizer_via_spacing_check_mode 0
Reading technology information ...
Technology table contains 6 routable metal layers
This is considered as a 6-metal-layer design
Reading library information from DB ...
Reading misc information ...
array <unit> has 0 vertical and 8 horizontal rows
8 pre-routes for placement blockage/checking
15 pre-routes for map congestion calculation
Checking information read in ...
design style = Horizontal masters, Horizontal rows
Preprocessing design ...
splitting rows by natural obstacles ...
... design style 0
... number of base array 1 0
INFO:... use original rows...
[end initializing data for legality checker]
Setting the GR Options
Information: TLUPlus based RC computation is enabled. (RCEX-141)
Information: The distance unit in Capacitance and Resistance is 1 micron. (RCEX-007)
Information: The RC model used is TLU+. (RCEX-015)
Information: Library Derived Cap for layer METAL : 1.9e-07 1.9e-07 (RCEX-011)
Information: Library Derived Res for layer METAL : 0.00065 0.00035 (RCEX-011)
Information: Library Derived Cap for layer METAL2 : 2.4e-07 2.4e-07 (RCEX-011)
Information: Library Derived Res for layer METAL2 : 0.00039 0.0002 (RCEX-011)
Information: Library Derived Cap for layer METAL3 : 2.4e-07 2.4e-07 (RCEX-011)
Information: Library Derived Res for layer METAL3 : 0.00039 0.0002 (RCEX-011)
Information: Library Derived Cap for layer METAL4 : 2e-07 1.9e-07 (RCEX-011)
Information: Library Derived Res for layer METAL4 : 0.00039 0.0002 (RCEX-011)
Information: Library Derived Cap for layer METAL5 : 2e-07 2e-07 (RCEX-011)
Information: Library Derived Res for layer METAL5 : 0.00019 0.0001 (RCEX-011)
Information: Library Derived Cap for layer METAL6 : 2.5e-07 2.5e-07 (RCEX-011)
Information: Library Derived Res for layer METAL6 : 5.8e-05 3.2e-05 (RCEX-011)
Information: Library Derived Horizontal Cap : 2.1e-07 2.1e-07 (RCEX-011)
Information: Library Derived Horizontal Res : 0.00041 0.00022 (RCEX-011)
Information: Library Derived Vertical Cap : 2.3e-07 2.3e-07 (RCEX-011)
Information: Library Derived Vertical Res : 0.00028 0.00015 (RCEX-011)
Information: Using derived R and C coefficients. (RCEX-008)
Information: Using region-based R and C coefficients. (RCEX-013)
Information: Library Derived Via Res : 0.00061 0.00019 (RCEX-011)
LR: Layer METAL3: Average tracks per gcell 9.6, utilization 0.00
LR: Layer METAL4: Average tracks per gcell 8.2, utilization 0.00
LR: Layer METAL5: Average tracks per gcell 4.7, utilization 0.00
LR: Layer METAL6: Average tracks per gcell 4.3, utilization 0.00
LR: Clock routing service standing by
Using cts integrated global router
CTS: Blockage Aware Algorithm
Top-Level OCV Path Sharing not effective when timing derating is too low
... design style 0
CTS: all inverters have too large rise/fall delay skew
CTS: inverter inv0da: rise/fall delay skew = 0.204816 (> 0.200000)
CTS: Region Aware Algorithm is automatically turned off when design has no region or only has one region.
CTS-Warning: clock root not found
CTS: ==================================================
CTS: Start DRC fixing beyond exceptions
CTS: Top-Level OCV Path Sharing not effective when timing derating is too low
... design style 0
CTS: DRC fixing initialization error. Abort
CTS Successful
Optimizing clock tree...
No valid clocks specified, all clocks will be optimized
CTS: CTS Operating Condition(s): MAX(Worst)
enable delay detour in ctdn
Legalizing Placement
... design style 0
Report : Chip Summary
Design : Sync_Rst_CompTop
Version: K-2015.06-SP5-1
Date : Tue Feb 20 12:29:34 2018
Std cell utilization: 79.69% (510/(640-0))
(Non-fixed + Fixed)
(Non-fixed only)
Chip area: 640 sites, bbox (5.00 5.00 37.80 34.52) um
Std cell area: 510 sites, (non-fixed:510 fixed:0)
64 cells, (non-fixed:64 fixed:0)
Macro cell area: 0 sites
0 cells
Placement blockages: 0 sites, (excluding fixed std cells)
0 sites, (include fixed std cells & chimney area)
0 sites, (complete p/g net blockages)
Routing blockages: 0 sites, (partial p/g net blockages)
0 sites, (routing blockages and signal pre-route)
Lib cell count: 13
Avg. std cell width: 3.53 um
Site array: unit (width: 0.41 um, height: 3.69 um, rows: 8)
Physical DB scale: 1000 db_unit = 1 um
Report : pnet options
Layer Blockage Min_width Min_height Via_additive Density
METAL none --- --- via additive ---
METAL2 none --- --- via additive ---
METAL3 none --- --- via additive ---
METAL4 none --- --- via additive ---
METAL5 none --- --- via additive ---
METAL6 none --- --- via additive ---
Report : Legalize Displacement
No cell displacement.
Placement Legalization Complete
Information: Updating database...
Unsetting the GR Options
LR: 0 out of 0 clock nets rerouted
LR: Clock routing service terminated
Invalidate design extracted status
Optimize clock tree UnSuccessful... Aborting clock_opt
