Bipolar circuit schematic has no size specified.
sys_eng
Full Member level 4
In MOS circuit schematic, it specifies the W/L size but Bipolar schematic, it doesn't specify the size. How do I know the size of the emitter, collector?
Maybe they do not want you to know. Device sizing
is part of the art and has to balance multiple interests
(for example, is your Vio hurt more by minimum emitter
area (raw matching) or by gain reduction (hFE-vs-Ic,
reduced "attenuation of back end systematic offset")
given that you want to run the front end at minimum
current so as to make Iib spec?
It's in nobody's interest to help you knock off their
part, so you never, as far back as I've ever seen
(and I have quite a collection) find datasheet schematics
showing such detail. Maybe resistor values if the MarCom
people were less than diligent (or their department did
not yet exist, at publication).
As a rough approach I recommend assuming they are all
minimum, and then do the work to figure out better sizing
based on what your analysis shows you. Because absent
other interests, die area is still concern #1.
