How to get throughput of network in lte using omnet++
achopra
Newbie level 1
Hello,
I am working on Omnet++ but getting difficulties with it. I am getting zero for channel,bitrate, snr and want to get throughput of network. I am attaching my omet.ini file here
please let me know if i need to do any changes here and attaching screenshot of result as well where i am getting zero values. I have copied omnet.ini file here. Please let me know if i need to do any changes in it.
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
[General]
#image-path=../../images
tkenv-plugin-path = ../../../inet/etc/plugins
output-scalar-file-append = false
debug-on-errors = false
print-undisposed = true
tkenv-default-config =
sim-time-limit=5s
warmup-period=2s
repeat = 5
**.routingRecorder.enabled = false
############### Statistics ##################
output-scalar-file = ${resultdir}/${configname}/${repetition}.sca
output-vector-file = ${resultdir}/${configname}/${repetition}.vec
seed-set = ${repetition}
**.vector-recording = true
################ PhyLayer parameters #####################
**.nic.phy.channelModel=xmldoc("config_channel.xml")
**.feedbackComputation = xmldoc("config_channel.xml")
# UEs attached to eNB
**.fbDelay = 1
############### AMC MODULE PARAMETERS ###############
**.rbAllocationType = "localized"
**.deployer.numRbDl = 6
**.deployer.numRbUl = 6
**.numBands = 6
# In this configuration, a transmitting UE sends periodic alert messages to two
# users, located close to it.
[Config SingleCell]
network = lte.simulations.networks.SingleCell
*.numUe = ${numUEs=5}
#============= Amount of applications ================
*.ue[*].numUdpApps = 1
*.server.numUdpApps = ${numUEs}
# connect each UE to the eNB
**.ue[*].macCellId = 1
**.ue[*].masterId = 1
################ Channel parameters #####################
**.channelControl.pMax = 20W
**.channelControl.alpha = 3
**.channelControl.carrierFrequency = 2100e+6Hz
#============= Positioning and mobility ============
*.eNodeB.mobility.initFromDisplayString = false
*.eNodeB.mobility.initialX = 300m
*.eNodeB.mobility.initialY = 300m
*.ue[*].mobility.constraintAreaMaxX = 1000m
*.ue[*].mobility.constraintAreaMaxY = 1000m
*.ue[*].mobility.constraintAreaMinX = 0m
*.ue[*].mobility.constraintAreaMinY = 0m
*.ue[*].mobility.initFromDisplayString = false
*.ue[*].mobility.initialX = uniform(0m,1000m)
*.ue[*].mobility.initialY = uniform(0m,1000m)
*.ue[*].mobility.speed = 1mps
*.ue[*].mobilityType = "LinearMobility"
**.ue*.udpApp[0].typename = "UDPVideoStreamCli"
**.ue*.udpApp[0].serverAddress = "server"
**.ue*.udpApp[0].localPort = 9999
**.ue*.udpApp[0].serverPort = 3088+ancestorIndex(0)
**.ue*.udpApp[0].startTime = 0.01s
# Video Server Configuration
**.server.udpApp[*].typename = "UDPVideoStreamSvr"
**.server.udpApp[*].videoSize = 107MiB
**.server.udpApp[*].localPort = 3088+ancestorIndex(0)
**.server.udpApp[*].sendInterval = 10ms
**.server.udpApp[*].packetLen = 1000B
