Generate clocks and their clock uncertainties
harpv
Member level 4
If there's a generated clock which is a divided down version of an oscillator clock, how would the edge-to-edge and duty cycle uncertainties be propagated from source clock to the generated clock?
Say there's an oscillator clock clk_osc
create_clock -name clk_osc \
             -period 100 \
             u_osc/out
And a generated clock clk_gen_osc from the clk_osc
create_generated_clock -name clk_gen_osc \
                       -divide_by 2 \
                       -source [get_pins u_osc/out] \
                        u_clk_gen/out
I'm putting an edge-to-edge uncertainty of 1% and 10% on duty for the oscillator clock as follows :
# edge-to-edge
set_clock_uncertainty -setup [expr 100*1/100] -rise_from clk_osc -rise_to clk_osc
set_clock_uncertainty -setup [expr 100*1/100] -fall_from clk_osc -fall_to clk_osc
# duty cycle
set_clock_uncertainty -setup [expr 100*10/100] -rise_from clk_osc -fall_to clk_osc
set_clock_uncertainty -setup [expr 100*10/100] -fall_from clk_osc -rise_to clk_osc
My question is how will the uncertainties of clk_gen_osc look like.
  1. Will it be same as clk_osc?
  2. Will the edge-to-edge uncertainty of clk_osc become duty-uncertainty of clk_gen_osc, and edge-to-edge uncertainty of clk_gen_osc twice the edge-to-edge uncertainty of clk_osc ?
  3. Will the uncertainty depend on whether the generated clock is from a flop based divider or pulse dropped version through a clock gate ?
Thanks in advance.
not easy to answer.
lets say the input clock rising edge has an uncertainty of 1%, and you use this edge for the divider..
* then the input clock duty cycle plays no role. But this is theortecitally only
now imagine a clock divider "/n".
only every n-th input rising edge will cause a edge at the output signal.
--> Then I´d say 1% input clock uncertainty will become 1%/n of output clock uncertainty.
--> and (2*1%)/n in duty cycle uncrertainty.
But in detail it depends on the frequency spectrum of the input clock jitter.
Since the uncertainty is integrated over n cycles
--> a low frequency jitter will be almost added up to the input clock uncertainty of 1% (which means a change in frequency)
--> a high frequency clock jitter may be almost cancelled out.
Klaus
Reactions: harpv
    harpv
Thank for the answer, appreciate the details you've given here.
I agree most cases are context dependent, just wanted to get a general idea here.
I have couple of follow up questions.
not easy to answer.
Can you explain why it is only theoretically correct ?
Klaus
Just to make sure I understand this correctly,
  1. A low frequency jitter of 1% might get transferred as n*1% jitter on a divide-by-n generated clock. If this 'n' is big, say 100, then the jitter will really get bad over time for the generated clock?
  2. A high frequency jitter of 1% means it'll not be n*1% for the generated clock since it disappears over time. I guess to put a value to 'n' here will be case dependent.
Thanks,
Hari
The "theretical" is in the assumption that only the falling edge is influenced by the duty cycle jitter. This - I think - is not very realistic.
No.
I didn´t say "n*1%" but I said : "1%/n"
You could simply use Excel to run a simulation. Or just a pencil and paper...
Klaus
