Results 1 to 2 of 2
    Newbie level 6
    Points: 1,268, Level: 8
    Jul 2011
    14
    1,268
    8
    ADS keep out layer, Ground Plane and ground vias
    Hello
    I have drawn a 6-layers layout in ADS.
    I should have a ground plane and many ground vias on the top layer.
    I have inserted a ground plane with 20mils clearance as shown below:
    some area should be ground free as you see with Red Cross in above pic. how should I draw a keep-out layer?
    some area I need to have many ground vias as you see with some Blue circles. is there any prepared multi-layer via?
    the left pad of C3 capacitor is connected to ground as you see in above schematic, but why the ground plane is not unified with this pad?!!!
    •   Alt14th February 2018, 20:02
      advertising
    Newbie level 6
    Jul 2011
    14
    1,268
    8
    Re: ADS keep out layer, Ground Plane and ground vias
    could you please tell me my problem?
    after many days I'm very frustrated with ADS!
    I have a very simple circuit:
    then from Layout Menu> Generate/update Layout>
    I have transferred it to a Layout (I have inserted a polygon and some vias)
    polygon property that I have used:
    via property that I have used:
    this is the technology and Layer Def and ...
    I have inserted plane, polygon, rectangular, .... many kind of vias... but the result of the layout simulation is not correct.
    please tell me what's my problem?
    how should I insert a correct ground plane?
    how should I insert correct ground vias?
