Connect CAN bus controller to Differential Bus Transceiver
azadfalah
Full Member level 2
Hello friends
i want Connect CAN bus controller to Differential Bus Transceiver As ADM485 , SN75176A and ... Is this possible?
I do not want to use MCP2551 or any can transceiver
Where to connect the Receive Enable Pin?
Microcontroller : STM32F407
check following pinout which is self explanatorycan transceiver.JPG.
CAN uses dominant/recessive level concept, not possible with RS485 driver. Read about CAN basics.
A similar behavior can be possibly achieved when sending through transmit enable pin, with supporting pull-up and pull-down resistors, but not exactly complying with CAN standard.
