Results 1 to 9 of 9
    Newbie level 5
    Points: 112, Level: 1
    Oct 2017
    10
    112
    Protection for a micropreocessor
    Hi All,
    I'm trying to find a way to protect a microcontroller from a possible wrong input voltage( backwards mainly) in one of its inputs.
    The input works at TTL level or free volt, and the input is connected internally to a pull up resistor. When the user joins the cables (free volt)or apply a TTL input voltage ( max 5v) it works fine. If the input voltage is above 5V there is a clamping diode to suppress excessive voltage.
    The problem is when a backward voltage is applied as a TTL input.The ground of the microprocessor would be connected to an external voltage, causing a possible fault in the microprocessor.
    I could fix that problem putting a diode from the microprocessor to micro-ground and then avoid any backward TTL connection, but I will lose the free volt. Any idea??
    Please see attachment to illustrate the problem.
    Cheers,
    Winsu
    Points: 54,878, Level: 57
    Apr 2014
    11,115
    54,878
    57
    Re: Protection for a micropreocessor
    And what if the user connect it to 230V AC?
    Do you feel responsible for every mistake a user will make?
    Do a standard protection, use a series resistor. Maybe 10k is good... maybe less.
    Please donīt contact me via PM, because there is no time to respond to them. Thank you.
    •   Alt12th February 2018, 23:01
      advertising
    Newbie level 5
    Oct 2017
    10
    112
    Hi Klaus,
    I see your point and it is true.What happens is that I know that there will be users handling 24V around ( it is the voltage that they whole system works), so we know that there will be users connecting 24V backward where there are not meant to do by mistake.
    The series resistor would connected from microporcessor to ground I guess...
    Thanks,
    Winsu
    Apr 2014
    11,115
    54,878
    57
    series resistor for the IOs.
    •   Alt13th February 2018, 17:21
      advertising
    Newbie level 5
    Oct 2017
    10
    112
    The microprocessor is failing because people connect TTL backwards. By connecting TTL signal backwards they are connecting the are connecting the ground of thr microporcessor toa potential voltage, then it is causing a fail.......
    Points: 25,540, Level: 38
    andre_teprom's Avatar
    Nov 2006
    Brazil
    7,687
    25,540
    38
    Blog Entries
    Quote Originally Posted by Winsu View Post
    The floating potential you mentioned (if I took correctly) is indeed a very important point to be remarked and for that reason the inter board wirings wherever possible should have the GND as the first contact to be connected. When the connector is of the linear type for example, since we usually anchor the housing on the first or last pin of the PCB connector, by putting the ground at the both ends of the same connector, in some cases helps to ensure that the reference will be the first potential to be connected.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  7. #7
    Points: 6,357, Level: 19
    Jun 2015
    1,126
    6,357
    19
    Maybe a suitable reverse polarity protection MOSFET instead of the diode would mean a lower voltage drop across the protection device.
    Reverse Battery Protection
  8. #8
    Newbie level 5
    Oct 2017
    10
    112
    Hi Andre,
    Thanks for your input. I forgot to say that the inter board wiring( device supplying a TTL output and the microprocessor input) are actually two wires and they can not be changed by any possible connector.
    The problem is that a typical user could connect a TTL signal backwards to the microprocessor and corrupting the ground of the microprocessor. If you have a look to the above attachment, by connecting TTL+ in pin 2 and TTL- in pin 1 the microprocessor will be in a non expected stated producing a fault. The idea is design something to prevent that happens...
    Cheers,
    Winsu
    •   Alt13th February 2018, 20:14
      advertising
  9. #9
    Newbie level 5
    Oct 2017
    10
    112
    Thanks,
    They are very handy solutions, but I need to keep the volt free connections and I think those solutions would avoid that volt free connection works.
