Results 1 to 4 of 4
    Points: 792, Level: 6
    Dec 2014
    43
    792
    Does these values give any sense for the speed of system in Vivado timing summary
    Hello everyone
    I have built a system in tow different approach and implement both on FPGA using Vivado Design Suite using the same parameters
    and as expected, I got different timing summary and utilization placed reports
    my question and what I am looking for for this work is
    do these values give any indication or sense for which method or approach is faster
    1. WNS (Worst Negative Slack)
    2. Setup Worst Slack
    3. Hold Worst Slack
    Or is there any other value in the report that decides which system is faster in my case
    •   Alt12th February 2018, 22:35
      advertising
    Points: 5,343, Level: 17
    Apr 2016
    1,124
    5,343
    17
    Re: Does these values give any sense for the speed of system in Vivado timing summary
    Quote Originally Posted by Serwan Bamerni View Post
    Hello everyone
    3. Hold Worst Slack
    This is digital circuits 101. Please google these concepts.
    Really, I am not Sam.
    •   Alt13th February 2018, 02:43
      advertising
    Advanced Member level 3
    Points: 4,935, Level: 16
    Feb 2015
    822
    4,935
    16
    In this context, the values only make sense if the design does not meet timing.
    You should set timing constraints and lower them to see which fails first. You might need to ensure the design is realistic -- that it doesn't fail timing because it uses IO resources that don't exist in a real design.
    The reason for this is because the tools may choose to optimize area/power/synthesis-time if timing is already met.
    •   Alt13th February 2018, 04:21
      advertising
    Member level 4
    Points: 651, Level: 5
    Aug 2016
    Bangalore, India
    79
    651
    Hello everyone
    3. Hold Worst Slack
    After feeding the timing constraints for both the cases, you can also compare the minimum period (or maximum frequency) of both the designs.
