joric
Newbie level 3
Communication channel: 500 kHz bandwidth.
a) if want to transmit a data rate of 8.3 Mbps, what is the minimum signal-to-noise ratio in dB required to do this?
b) If the effective data rate is 80% of the maximum channel data rate.
What is ratio of signal energy per bit to noise power density (Eb/N0)?
Anyone able to help with this questions?
