Results 1 to 15 of 15
    Full Member level 4
    Points: 1,197, Level: 7
    Feb 2016
    203
    1,197
    7
    S11 inductance measurement
    Have anyone used S11 result to calculate inductance value of active inductor as decribed in https://www.ieee.li/pdf/essay/s_para...nts.pdf#page=5 ?
    s_parameters_of_passive_components.pdf
    Points: 46,775, Level: 52
    Apr 2011
    Minneapolis, Minnesota, USA
    11,656
    46,775
    52
    Re: S11 inductance measurement
    The active inductor has an RC network which determines behavior. I have a simulation of an active inductor, compared with a plain series LR. Each has the same waveform applied. The result is that scope traces show identical Ampere waveforms through both loads. This implies they have identical rolloff curves, amplitude levels, and phase responses.
    The plain series L/R time constant is straightforward to calculate, because R is the load.
    However this does not translate easily to an RC time constant in the active inductor, since the RC network does not include the load. It is only one factor in the overall calculation. The load must be taken into account.
    •   Alt11th February 2018, 07:03
      advertising
    Points: 239,557, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,502
    239,557
    100
    Not sure what you are specifically asking? Yes, you can derive impedances from a S11 measurement. It works for discrete inductors, so why not for active inductors if you adjust the VNA output level aware of the linear voltage range.
    Full Member level 4
    Feb 2016
    203
    1,197
    7
    @BradtheRad
    Would you be able to share your simulation work of your active inductor circuitry ?
    RC network does not include the load ? I do not get what you were trying to convey.
    Full Member level 4
    Feb 2016
    203
    1,197
    7
    I have created a simulation circuit (test_active_inductor) for S11. The schematics and netlist could be found at https://github.com/promach/frequency...ee/development
    My S11 result is as follows: https://gist.github.com/promach/c4f9...7553530791334e
    How would I proceed to analyze these S11 data and perform calculation for the inductance value of the active inductor made out of gyrator and capacitor ?
     * gnetlist -g spice-noqsi -o test_active_inductor.net test_active_inductor.sch
     AC Analysis  Mon Feb 12 08:40:54  2018
    Index   frequency       s11
    0	1.000000e+02	9.975861e-01,	4.860801e-12
    1	1.001001e+02	9.975861e-01,	4.865667e-12
    2	1.002002e+02	9.975861e-01,	4.870533e-12
    3	1.003003e+02	9.975861e-01,	4.875398e-12
    4	1.004004e+02	9.975861e-01,	4.880264e-12
    5	1.005005e+02	9.975861e-01,	4.885130e-12
    6	1.006006e+02	9.975861e-01,	4.889995e-12
    7	1.007007e+02	9.975861e-01,	4.894861e-12
    8	1.008008e+02	9.975861e-01,	4.899727e-12
    9	1.009009e+02	9.975861e-01,	4.904592e-12
    10	1.010010e+02	9.975861e-01,	4.909458e-12
    11	1.011011e+02	9.975861e-01,	4.914324e-12
    12	1.012012e+02	9.975861e-01,	4.919189e-12
    13	1.013013e+02	9.975861e-01,	4.924055e-12
    14	1.014014e+02	9.975861e-01,	4.928921e-12
    15	1.015015e+02	9.975861e-01,	4.933786e-12
    16	1.016016e+02	9.975861e-01,	4.938652e-12
    17	1.017017e+02	9.975861e-01,	4.943518e-12
    18	1.018018e+02	9.975861e-01,	4.948383e-12
    19	1.019019e+02	9.975861e-01,	4.953249e-12
    20	1.020020e+02	9.975861e-01,	4.958115e-12
    21	1.021021e+02	9.975861e-01,	4.962980e-12
    22	1.022022e+02	9.975861e-01,	4.967846e-12
    23	1.023023e+02	9.975861e-01,	4.972712e-12
    24	1.024024e+02	9.975861e-01,	4.977577e-12
    25	1.025025e+02	9.975861e-01,	4.982443e-12
    26	1.026026e+02	9.975861e-01,	4.987309e-12
    27	1.027027e+02	9.975861e-01,	4.992174e-12
    28	1.028028e+02	9.975861e-01,	4.997040e-12
    29	1.029029e+02	9.975861e-01,	5.001906e-12
    30	1.030030e+02	9.975861e-01,	5.006771e-12
    31	1.031031e+02	9.975861e-01,	5.011637e-12
    32	1.032032e+02	9.975861e-01,	5.016503e-12
    33	1.033033e+02	9.975861e-01,	5.021368e-12
    34	1.034034e+02	9.975861e-01,	5.026234e-12
    35	1.035035e+02	9.975861e-01,	5.031100e-12
    36	1.036036e+02	9.975861e-01,	5.035965e-12
    37	1.037037e+02	9.975861e-01,	5.040831e-12
    38	1.038038e+02	9.975861e-01,	5.045697e-12
    39	1.039039e+02	9.975861e-01,	5.050562e-12
    40	1.040040e+02	9.975861e-01,	5.055428e-12
    41	1.041041e+02	9.975861e-01,	5.060294e-12
    42	1.042042e+02	9.975861e-01,	5.065159e-12
    43	1.043043e+02	9.975861e-01,	5.070025e-12
    44	1.044044e+02	9.975861e-01,	5.074891e-12
    45	1.045045e+02	9.975861e-01,	5.079756e-12
    46	1.046046e+02	9.975861e-01,	5.084622e-12
    47	1.047047e+02	9.975861e-01,	5.089488e-12
    48	1.048048e+02	9.975861e-01,	5.094353e-12
    49	1.049049e+02	9.975861e-01,	5.099219e-12
    50	1.050050e+02	9.975861e-01,	5.104085e-12
    51	1.051051e+02	9.975861e-01,	5.108950e-12
    52	1.052052e+02	9.975861e-01,	5.113816e-12
    53	1.053053e+02	9.975861e-01,	5.118682e-12
    54	1.054054e+02	9.975861e-01,	5.123547e-12
    Index   frequency       s11
    55	1.055055e+02	9.975861e-01,	5.128413e-12
    56	1.056056e+02	9.975861e-01,	5.133279e-12
    57	1.057057e+02	9.975861e-01,	5.138144e-12
    58	1.058058e+02	9.975861e-01,	5.143010e-12
    59	1.059059e+02	9.975861e-01,	5.147876e-12
    60	1.060060e+02	9.975861e-01,	5.152741e-12
    61	1.061061e+02	9.975861e-01,	5.157607e-12
    62	1.062062e+02	9.975861e-01,	5.162473e-12
    63	1.063063e+02	9.975861e-01,	5.167338e-12
    64	1.064064e+02	9.975861e-01,	5.172204e-12
    65	1.065065e+02	9.975861e-01,	5.177070e-12
    66	1.066066e+02	9.975861e-01,	5.181935e-12
    67	1.067067e+02	9.975861e-01,	5.186801e-12
    68	1.068068e+02	9.975861e-01,	5.191667e-12
    69	1.069069e+02	9.975861e-01,	5.196532e-12
    70	1.070070e+02	9.975861e-01,	5.201398e-12
    71	1.071071e+02	9.975861e-01,	5.206264e-12
    72	1.072072e+02	9.975861e-01,	5.211129e-12
    73	1.073073e+02	9.975861e-01,	5.215995e-12
    74	1.074074e+02	9.975861e-01,	5.220861e-12
    75	1.075075e+02	9.975861e-01,	5.225726e-12
    76	1.076076e+02	9.975861e-01,	5.230592e-12
    77	1.077077e+02	9.975861e-01,	5.235458e-12
    78	1.078078e+02	9.975861e-01,	5.240323e-12
    79	1.079079e+02	9.975861e-01,	5.245189e-12
    80	1.080080e+02	9.975861e-01,	5.250055e-12
    81	1.081081e+02	9.975861e-01,	5.254920e-12
    82	1.082082e+02	9.975861e-01,	5.259786e-12
    83	1.083083e+02	9.975861e-01,	5.264652e-12
    84	1.084084e+02	9.975861e-01,	5.269517e-12
    85	1.085085e+02	9.975861e-01,	5.274383e-12
    86	1.086086e+02	9.975861e-01,	5.279249e-12
    87	1.087087e+02	9.975861e-01,	5.284114e-12
    88	1.088088e+02	9.975861e-01,	5.288980e-12
    89	1.089089e+02	9.975861e-01,	5.293846e-12
    90	1.090090e+02	9.975861e-01,	5.298711e-12
    91	1.091091e+02	9.975861e-01,	5.303577e-12
    92	1.092092e+02	9.975861e-01,	5.308443e-12
    93	1.093093e+02	9.975861e-01,	5.313308e-12
    94	1.094094e+02	9.975861e-01,	5.318174e-12
    95	1.095095e+02	9.975861e-01,	5.323040e-12
    96	1.096096e+02	9.975861e-01,	5.327905e-12
    97	1.097097e+02	9.975861e-01,	5.332771e-12
    98	1.098098e+02	9.975861e-01,	5.337637e-12
    99	1.099099e+02	9.975861e-01,	5.342502e-12
    100	1.100100e+02	9.975861e-01,	5.347368e-12
    101	1.101101e+02	9.975861e-01,	5.352234e-12
    102	1.102102e+02	9.975861e-01,	5.357099e-12
    103	1.103103e+02	9.975861e-01,	5.361965e-12
    104	1.104104e+02	9.975861e-01,	5.366831e-12
    105	1.105105e+02	9.975861e-01,	5.371696e-12
    106	1.106106e+02	9.975861e-01,	5.376562e-12
    107	1.107107e+02	9.975861e-01,	5.381428e-12
    108	1.108108e+02	9.975861e-01,	5.386293e-12
    109	1.109109e+02	9.975861e-01,	5.391159e-12
    110	1.110110e+02	9.975861e-01,	5.396025e-12
    111	1.111111e+02	9.975861e-01,	5.400890e-12
    112	1.112112e+02	9.975861e-01,	5.405756e-12
    Index   frequency       s11
    113	1.113113e+02	9.975861e-01,	5.410622e-12
    114	1.114114e+02	9.975861e-01,	5.415487e-12
    115	1.115115e+02	9.975861e-01,	5.420353e-12
    116	1.116116e+02	9.975861e-01,	5.425219e-12
    117	1.117117e+02	9.975861e-01,	5.430084e-12
    118	1.118118e+02	9.975861e-01,	5.434950e-12
    119	1.119119e+02	9.975861e-01,	5.439816e-12
    120	1.120120e+02	9.975861e-01,	5.444681e-12
    121	1.121121e+02	9.975861e-01,	5.449547e-12
    122	1.122122e+02	9.975861e-01,	5.454413e-12
    123	1.123123e+02	9.975861e-01,	5.459278e-12
    124	1.124124e+02	9.975861e-01,	5.464144e-12
    125	1.125125e+02	9.975861e-01,	5.469010e-12
    126	1.126126e+02	9.975861e-01,	5.473875e-12
    127	1.127127e+02	9.975861e-01,	5.478741e-12
    128	1.128128e+02	9.975861e-01,	5.483607e-12
    129	1.129129e+02	9.975861e-01,	5.488472e-12
    130	1.130130e+02	9.975861e-01,	5.493338e-12
    131	1.131131e+02	9.975861e-01,	5.498204e-12
    132	1.132132e+02	9.975861e-01,	5.503069e-12
    133	1.133133e+02	9.975861e-01,	5.507935e-12
    134	1.134134e+02	9.975861e-01,	5.512801e-12
    135	1.135135e+02	9.975861e-01,	5.517666e-12
    136	1.136136e+02	9.975861e-01,	5.522532e-12
    137	1.137137e+02	9.975861e-01,	5.527398e-12
    138	1.138138e+02	9.975861e-01,	5.532263e-12
    139	1.139139e+02	9.975861e-01,	5.537129e-12
    140	1.140140e+02	9.975861e-01,	5.541995e-12
    141	1.141141e+02	9.975861e-01,	5.546860e-12
    142	1.142142e+02	9.975861e-01,	5.551726e-12
    143	1.143143e+02	9.975861e-01,	5.556592e-12
    144	1.144144e+02	9.975861e-01,	5.561457e-12
    145	1.145145e+02	9.975861e-01,	5.566323e-12
    146	1.146146e+02	9.975861e-01,	5.571189e-12
    147	1.147147e+02	9.975861e-01,	5.576054e-12
    148	1.148148e+02	9.975861e-01,	5.580920e-12
    149	1.149149e+02	9.975861e-01,	5.585786e-12
    150	1.150150e+02	9.975861e-01,	5.590651e-12
    151	1.151151e+02	9.975861e-01,	5.595517e-12
    152	1.152152e+02	9.975861e-01,	5.600383e-12
    153	1.153153e+02	9.975861e-01,	5.605248e-12
    154	1.154154e+02	9.975861e-01,	5.610114e-12
    155	1.155155e+02	9.975861e-01,	5.614980e-12
    156	1.156156e+02	9.975861e-01,	5.619845e-12
    157	1.157157e+02	9.975861e-01,	5.624711e-12
    158	1.158158e+02	9.975861e-01,	5.629577e-12
    159	1.159159e+02	9.975861e-01,	5.634442e-12
    160	1.160160e+02	9.975861e-01,	5.639308e-12
    161	1.161161e+02	9.975861e-01,	5.644174e-12
    162	1.162162e+02	9.975861e-01,	5.649039e-12
    163	1.163163e+02	9.975861e-01,	5.653905e-12
    164	1.164164e+02	9.975861e-01,	5.658771e-12
    165	1.165165e+02	9.975861e-01,	5.663636e-12
    166	1.166166e+02	9.975861e-01,	5.668502e-12
    167	1.167167e+02	9.975861e-01,	5.673368e-12
    168	1.168168e+02	9.975861e-01,	5.678233e-12
    169	1.169169e+02	9.975861e-01,	5.683099e-12
    170	1.170170e+02	9.975861e-01,	5.687965e-12
    Index   frequency       s11
    171	1.171171e+02	9.975861e-01,	5.692830e-12
    172	1.172172e+02	9.975861e-01,	5.697696e-12
    173	1.173173e+02	9.975861e-01,	5.702562e-12
    174	1.174174e+02	9.975861e-01,	5.707427e-12
    175	1.175175e+02	9.975861e-01,	5.712293e-12
    176	1.176176e+02	9.975861e-01,	5.717159e-12
    177	1.177177e+02	9.975861e-01,	5.722024e-12
    178	1.178178e+02	9.975861e-01,	5.726890e-12
    179	1.179179e+02	9.975861e-01,	5.731756e-12
    180	1.180180e+02	9.975861e-01,	5.736621e-12
    181	1.181181e+02	9.975861e-01,	5.741487e-12
    182	1.182182e+02	9.975861e-01,	5.746353e-12
    183	1.183183e+02	9.975861e-01,	5.751219e-12
    184	1.184184e+02	9.975861e-01,	5.756084e-12
    185	1.185185e+02	9.975861e-01,	5.760950e-12
    186	1.186186e+02	9.975861e-01,	5.765816e-12
    187	1.187187e+02	9.975861e-01,	5.770681e-12
    188	1.188188e+02	9.975861e-01,	5.775547e-12
    189	1.189189e+02	9.975861e-01,	5.780413e-12
    190	1.190190e+02	9.975861e-01,	5.785278e-12
    191	1.191191e+02	9.975861e-01,	5.790144e-12
    192	1.192192e+02	9.975861e-01,	5.795010e-12
    193	1.193193e+02	9.975861e-01,	5.799875e-12
    194	1.194194e+02	9.975861e-01,	5.804741e-12
    195	1.195195e+02	9.975861e-01,	5.809607e-12
    196	1.196196e+02	9.975861e-01,	5.814472e-12
    197	1.197197e+02	9.975861e-01,	5.819338e-12
    198	1.198198e+02	9.975861e-01,	5.824204e-12
    199	1.199199e+02	9.975861e-01,	5.829069e-12
    200	1.200200e+02	9.975861e-01,	5.833935e-12
    201	1.201201e+02	9.975861e-01,	5.838801e-12
    202	1.202202e+02	9.975861e-01,	5.843666e-12
    203	1.203203e+02	9.975861e-01,	5.848532e-12
    204	1.204204e+02	9.975861e-01,	5.853398e-12
    205	1.205205e+02	9.975861e-01,	5.858263e-12
    206	1.206206e+02	9.975861e-01,	5.863129e-12
    207	1.207207e+02	9.975861e-01,	5.867995e-12
    208	1.208208e+02	9.975861e-01,	5.872860e-12
    209	1.209209e+02	9.975861e-01,	5.877726e-12
    210	1.210210e+02	9.975861e-01,	5.882592e-12
    211	1.211211e+02	9.975861e-01,	5.887457e-12
    212	1.212212e+02	9.975861e-01,	5.892323e-12
    213	1.213213e+02	9.975861e-01,	5.897189e-12
    214	1.214214e+02	9.975861e-01,	5.902054e-12
    215	1.215215e+02	9.975861e-01,	5.906920e-12
    216	1.216216e+02	9.975861e-01,	5.911786e-12
    217	1.217217e+02	9.975861e-01,	5.916651e-12
    218	1.218218e+02	9.975861e-01,	5.921517e-12
    219	1.219219e+02	9.975861e-01,	5.926383e-12
    220	1.220220e+02	9.975861e-01,	5.931248e-12
    221	1.221221e+02	9.975861e-01,	5.936114e-12
    222	1.222222e+02	9.975861e-01,	5.940980e-12
    223	1.223223e+02	9.975861e-01,	5.945845e-12
    224	1.224224e+02	9.975861e-01,	5.950711e-12
    225	1.225225e+02	9.975861e-01,	5.955577e-12
    226	1.226226e+02	9.975861e-01,	5.960442e-12
    227	1.227227e+02	9.975861e-01,	5.965308e-12
    228	1.228228e+02	9.975861e-01,	5.970174e-12
    Index   frequency       s11
    229	1.229229e+02	9.975861e-01,	5.975039e-12
    230	1.230230e+02	9.975861e-01,	5.979905e-12
    231	1.231231e+02	9.975861e-01,	5.984771e-12
    232	1.232232e+02	9.975861e-01,	5.989636e-12
    233	1.233233e+02	9.975861e-01,	5.994502e-12
    234	1.234234e+02	9.975861e-01,	5.999368e-12
    235	1.235235e+02	9.975861e-01,	6.004233e-12
    236	1.236236e+02	9.975861e-01,	6.009099e-12
    237	1.237237e+02	9.975861e-01,	6.013965e-12
    238	1.238238e+02	9.975861e-01,	6.018830e-12
    239	1.239239e+02	9.975861e-01,	6.023696e-12
    240	1.240240e+02	9.975861e-01,	6.028562e-12
    241	1.241241e+02	9.975861e-01,	6.033427e-12
    242	1.242242e+02	9.975861e-01,	6.038293e-12
    243	1.243243e+02	9.975861e-01,	6.043159e-12
    244	1.244244e+02	9.975861e-01,	6.048024e-12
    245	1.245245e+02	9.975861e-01,	6.052890e-12
    246	1.246246e+02	9.975861e-01,	6.057756e-12
    247	1.247247e+02	9.975861e-01,	6.062621e-12
    248	1.248248e+02	9.975861e-01,	6.067487e-12
    249	1.249249e+02	9.975861e-01,	6.072353e-12
    250	1.250250e+02	9.975861e-01,	6.077218e-12
    251	1.251251e+02	9.975861e-01,	6.082084e-12
    252	1.252252e+02	9.975861e-01,	6.086950e-12
    253	1.253253e+02	9.975861e-01,	6.091815e-12
    254	1.254254e+02	9.975861e-01,	6.096681e-12
    255	1.255255e+02	9.975861e-01,	6.101547e-12
    256	1.256256e+02	9.975861e-01,	6.106412e-12
    257	1.257257e+02	9.975861e-01,	6.111278e-12
    258	1.258258e+02	9.975861e-01,	6.116144e-12
    259	1.259259e+02	9.975861e-01,	6.121009e-12
    260	1.260260e+02	9.975861e-01,	6.125875e-12
    261	1.261261e+02	9.975861e-01,	6.130741e-12
    262	1.262262e+02	9.975861e-01,	6.135606e-12
    263	1.263263e+02	9.975861e-01,	6.140472e-12
    264	1.264264e+02	9.975861e-01,	6.145338e-12
    265	1.265265e+02	9.975861e-01,	6.150203e-12
    266	1.266266e+02	9.975861e-01,	6.155069e-12
    267	1.267267e+02	9.975861e-01,	6.159935e-12
    268	1.268268e+02	9.975861e-01,	6.164800e-12
    269	1.269269e+02	9.975861e-01,	6.169666e-12
    270	1.270270e+02	9.975861e-01,	6.174532e-12
    271	1.271271e+02	9.975861e-01,	6.179397e-12
    272	1.272272e+02	9.975861e-01,	6.184263e-12
    273	1.273273e+02	9.975861e-01,	6.189129e-12
    274	1.274274e+02	9.975861e-01,	6.193994e-12
    275	1.275275e+02	9.975861e-01,	6.198860e-12
    276	1.276276e+02	9.975861e-01,	6.203726e-12
    277	1.277277e+02	9.975861e-01,	6.208591e-12
    278	1.278278e+02	9.975861e-01,	6.213457e-12
    279	1.279279e+02	9.975861e-01,	6.218323e-12
    280	1.280280e+02	9.975861e-01,	6.223188e-12
    281	1.281281e+02	9.975861e-01,	6.228054e-12
    282	1.282282e+02	9.975861e-01,	6.232920e-12
    283	1.283283e+02	9.975861e-01,	6.237785e-12
    284	1.284284e+02	9.975861e-01,	6.242651e-12
    285	1.285285e+02	9.975861e-01,	6.247517e-12
    286	1.286286e+02	9.975861e-01,	6.252382e-12
    Index   frequency       s11
    287	1.287287e+02	9.975861e-01,	6.257248e-12
    288	1.288288e+02	9.975861e-01,	6.262114e-12
    289	1.289289e+02	9.975861e-01,	6.266979e-12
    290	1.290290e+02	9.975861e-01,	6.271845e-12
    291	1.291291e+02	9.975861e-01,	6.276711e-12
    292	1.292292e+02	9.975861e-01,	6.281576e-12
    293	1.293293e+02	9.975861e-01,	6.286442e-12
    294	1.294294e+02	9.975861e-01,	6.291308e-12
    295	1.295295e+02	9.975861e-01,	6.296173e-12
    296	1.296296e+02	9.975861e-01,	6.301039e-12
    297	1.297297e+02	9.975861e-01,	6.305905e-12
    298	1.298298e+02	9.975861e-01,	6.310770e-12
    299	1.299299e+02	9.975861e-01,	6.315636e-12
    300	1.300300e+02	9.975861e-01,	6.320502e-12
    301	1.301301e+02	9.975861e-01,	6.325367e-12
    302	1.302302e+02	9.975861e-01,	6.330233e-12
    303	1.303303e+02	9.975861e-01,	6.335099e-12
    304	1.304304e+02	9.975861e-01,	6.339964e-12
    305	1.305305e+02	9.975861e-01,	6.344830e-12
    306	1.306306e+02	9.975861e-01,	6.349696e-12
    307	1.307307e+02	9.975861e-01,	6.354561e-12
    308	1.308308e+02	9.975861e-01,	6.359427e-12
    309	1.309309e+02	9.975861e-01,	6.364293e-12
    310	1.310310e+02	9.975861e-01,	6.369158e-12
    311	1.311311e+02	9.975861e-01,	6.374024e-12
    312	1.312312e+02	9.975861e-01,	6.378890e-12
    313	1.313313e+02	9.975861e-01,	6.383755e-12
    314	1.314314e+02	9.975861e-01,	6.388621e-12
    315	1.315315e+02	9.975861e-01,	6.393487e-12
    316	1.316316e+02	9.975861e-01,	6.398352e-12
    317	1.317317e+02	9.975861e-01,	6.403218e-12
    318	1.318318e+02	9.975861e-01,	6.408084e-12
    319	1.319319e+02	9.975861e-01,	6.412949e-12
    320	1.320320e+02	9.975861e-01,	6.417815e-12
    321	1.321321e+02	9.975861e-01,	6.422681e-12
    322	1.322322e+02	9.975861e-01,	6.427546e-12
    323	1.323323e+02	9.975861e-01,	6.432412e-12
    324	1.324324e+02	9.975861e-01,	6.437278e-12
    325	1.325325e+02	9.975861e-01,	6.442143e-12
    326	1.326326e+02	9.975861e-01,	6.447009e-12
    327	1.327327e+02	9.975861e-01,	6.451875e-12
    328	1.328328e+02	9.975861e-01,	6.456740e-12
    329	1.329329e+02	9.975861e-01,	6.461606e-12
    330	1.330330e+02	9.975861e-01,	6.466472e-12
    331	1.331331e+02	9.975861e-01,	6.471337e-12
    332	1.332332e+02	9.975861e-01,	6.476203e-12
    333	1.333333e+02	9.975861e-01,	6.481069e-12
    334	1.334334e+02	9.975861e-01,	6.485934e-12
    335	1.335335e+02	9.975861e-01,	6.490800e-12
    336	1.336336e+02	9.975861e-01,	6.495666e-12
    337	1.337337e+02	9.975861e-01,	6.500531e-12
    338	1.338338e+02	9.975861e-01,	6.505397e-12
    339	1.339339e+02	9.975861e-01,	6.510263e-12
    340	1.340340e+02	9.975861e-01,	6.515128e-12
    341	1.341341e+02	9.975861e-01,	6.519994e-12
    342	1.342342e+02	9.975861e-01,	6.524860e-12
    343	1.343343e+02	9.975861e-01,	6.529725e-12
    344	1.344344e+02	9.975861e-01,	6.534591e-12
    Index   frequency       s11
    345	1.345345e+02	9.975861e-01,	6.539457e-12
    346	1.346346e+02	9.975861e-01,	6.544322e-12
    347	1.347347e+02	9.975861e-01,	6.549188e-12
    348	1.348348e+02	9.975861e-01,	6.554054e-12
    349	1.349349e+02	9.975861e-01,	6.558919e-12
    350	1.350350e+02	9.975861e-01,	6.563785e-12
    351	1.351351e+02	9.975861e-01,	6.568651e-12
    352	1.352352e+02	9.975861e-01,	6.573516e-12
    353	1.353353e+02	9.975861e-01,	6.578382e-12
    354	1.354354e+02	9.975861e-01,	6.583248e-12
    355	1.355355e+02	9.975861e-01,	6.588113e-12
    356	1.356356e+02	9.975861e-01,	6.592979e-12
    357	1.357357e+02	9.975861e-01,	6.597845e-12
    358	1.358358e+02	9.975861e-01,	6.602710e-12
    359	1.359359e+02	9.975861e-01,	6.607576e-12
    360	1.360360e+02	9.975861e-01,	6.612442e-12
    361	1.361361e+02	9.975861e-01,	6.617307e-12
    362	1.362362e+02	9.975861e-01,	6.622173e-12
    363	1.363363e+02	9.975861e-01,	6.627039e-12
    364	1.364364e+02	9.975861e-01,	6.631904e-12
    365	1.365365e+02	9.975861e-01,	6.636770e-12
    366	1.366366e+02	9.975861e-01,	6.641636e-12
    367	1.367367e+02	9.975861e-01,	6.646501e-12
    368	1.368368e+02	9.975861e-01,	6.651367e-12
    369	1.369369e+02	9.975861e-01,	6.656233e-12
    370	1.370370e+02	9.975861e-01,	6.661098e-12
    371	1.371371e+02	9.975861e-01,	6.665964e-12
    372	1.372372e+02	9.975861e-01,	6.670830e-12
    373	1.373373e+02	9.975861e-01,	6.675695e-12
    374	1.374374e+02	9.975861e-01,	6.680561e-12
    375	1.375375e+02	9.975861e-01,	6.685427e-12
    376	1.376376e+02	9.975861e-01,	6.690292e-12
    377	1.377377e+02	9.975861e-01,	6.695158e-12
    378	1.378378e+02	9.975861e-01,	6.700024e-12
    379	1.379379e+02	9.975861e-01,	6.704889e-12
    380	1.380380e+02	9.975861e-01,	6.709755e-12
    381	1.381381e+02	9.975861e-01,	6.714621e-12
    382	1.382382e+02	9.975861e-01,	6.719486e-12
    383	1.383383e+02	9.975861e-01,	6.724352e-12
    384	1.384384e+02	9.975861e-01,	6.729218e-12
    385	1.385385e+02	9.975861e-01,	6.734083e-12
    386	1.386386e+02	9.975861e-01,	6.738949e-12
    387	1.387387e+02	9.975861e-01,	6.743815e-12
    388	1.388388e+02	9.975861e-01,	6.748680e-12
    389	1.389389e+02	9.975861e-01,	6.753546e-12
    390	1.390390e+02	9.975861e-01,	6.758412e-12
    391	1.391391e+02	9.975861e-01,	6.763277e-12
    392	1.392392e+02	9.975861e-01,	6.768143e-12
    393	1.393393e+02	9.975861e-01,	6.773009e-12
    394	1.394394e+02	9.975861e-01,	6.777874e-12
    395	1.395395e+02	9.975861e-01,	6.782740e-12
    396	1.396396e+02	9.975861e-01,	6.787606e-12
    397	1.397397e+02	9.975861e-01,	6.792471e-12
    398	1.398398e+02	9.975861e-01,	6.797337e-12
    399	1.399399e+02	9.975861e-01,	6.802203e-12
    400	1.400400e+02	9.975861e-01,	6.807068e-12
    401	1.401401e+02	9.975861e-01,	6.811934e-12
    402	1.402402e+02	9.975861e-01,	6.816800e-12
    Index   frequency       s11
    403	1.403403e+02	9.975861e-01,	6.821665e-12
    404	1.404404e+02	9.975861e-01,	6.826531e-12
    405	1.405405e+02	9.975861e-01,	6.831397e-12
    406	1.406406e+02	9.975861e-01,	6.836262e-12
    407	1.407407e+02	9.975861e-01,	6.841128e-12
    408	1.408408e+02	9.975861e-01,	6.845994e-12
    409	1.409409e+02	9.975861e-01,	6.850859e-12
    410	1.410410e+02	9.975861e-01,	6.855725e-12
    411	1.411411e+02	9.975861e-01,	6.860591e-12
    412	1.412412e+02	9.975861e-01,	6.865456e-12
    413	1.413413e+02	9.975861e-01,	6.870322e-12
    414	1.414414e+02	9.975861e-01,	6.875188e-12
    415	1.415415e+02	9.975861e-01,	6.880053e-12
    416	1.416416e+02	9.975861e-01,	6.884919e-12
    417	1.417417e+02	9.975861e-01,	6.889785e-12
    418	1.418418e+02	9.975861e-01,	6.894650e-12
    419	1.419419e+02	9.975861e-01,	6.899516e-12
    420	1.420420e+02	9.975861e-01,	6.904382e-12
    421	1.421421e+02	9.975861e-01,	6.909247e-12
    422	1.422422e+02	9.975861e-01,	6.914113e-12
    423	1.423423e+02	9.975861e-01,	6.918979e-12
    424	1.424424e+02	9.975861e-01,	6.923844e-12
    425	1.425425e+02	9.975861e-01,	6.928710e-12
    426	1.426426e+02	9.975861e-01,	6.933576e-12
    427	1.427427e+02	9.975861e-01,	6.938441e-12
    428	1.428428e+02	9.975861e-01,	6.943307e-12
    429	1.429429e+02	9.975861e-01,	6.948173e-12
    430	1.430430e+02	9.975861e-01,	6.953038e-12
    431	1.431431e+02	9.975861e-01,	6.957904e-12
    432	1.432432e+02	9.975861e-01,	6.962770e-12
    433	1.433433e+02	9.975861e-01,	6.967635e-12
    434	1.434434e+02	9.975861e-01,	6.972501e-12
    435	1.435435e+02	9.975861e-01,	6.977367e-12
    436	1.436436e+02	9.975861e-01,	6.982232e-12
    437	1.437437e+02	9.975861e-01,	6.987098e-12
    438	1.438438e+02	9.975861e-01,	6.991964e-12
    439	1.439439e+02	9.975861e-01,	6.996829e-12
    440	1.440440e+02	9.975861e-01,	7.001695e-12
    441	1.441441e+02	9.975861e-01,	7.006561e-12
    442	1.442442e+02	9.975861e-01,	7.011426e-12
    443	1.443443e+02	9.975861e-01,	7.016292e-12
    444	1.444444e+02	9.975861e-01,	7.021158e-12
    445	1.445445e+02	9.975861e-01,	7.026023e-12
    446	1.446446e+02	9.975861e-01,	7.030889e-12
    447	1.447447e+02	9.975861e-01,	7.035755e-12
    448	1.448448e+02	9.975861e-01,	7.040620e-12
    449	1.449449e+02	9.975861e-01,	7.045486e-12
    450	1.450450e+02	9.975861e-01,	7.050352e-12
    451	1.451451e+02	9.975861e-01,	7.055217e-12
    452	1.452452e+02	9.975861e-01,	7.060083e-12
    453	1.453453e+02	9.975861e-01,	7.064949e-12
    454	1.454454e+02	9.975861e-01,	7.069814e-12
    455	1.455455e+02	9.975861e-01,	7.074680e-12
    456	1.456456e+02	9.975861e-01,	7.079546e-12
    457	1.457457e+02	9.975861e-01,	7.084411e-12
    458	1.458458e+02	9.975861e-01,	7.089277e-12
    459	1.459459e+02	9.975861e-01,	7.094143e-12
    460	1.460460e+02	9.975861e-01,	7.099008e-12
    Index   frequency       s11
    461	1.461461e+02	9.975861e-01,	7.103874e-12
    462	1.462462e+02	9.975861e-01,	7.108740e-12
    463	1.463463e+02	9.975861e-01,	7.113605e-12
    464	1.464464e+02	9.975861e-01,	7.118471e-12
    465	1.465465e+02	9.975861e-01,	7.123337e-12
    466	1.466466e+02	9.975861e-01,	7.128202e-12
    467	1.467467e+02	9.975861e-01,	7.133068e-12
    468	1.468468e+02	9.975861e-01,	7.137934e-12
    469	1.469469e+02	9.975861e-01,	7.142799e-12
    470	1.470470e+02	9.975861e-01,	7.147665e-12
    471	1.471471e+02	9.975861e-01,	7.152531e-12
    472	1.472472e+02	9.975861e-01,	7.157396e-12
    473	1.473473e+02	9.975861e-01,	7.162262e-12
    474	1.474474e+02	9.975861e-01,	7.167128e-12
    475	1.475475e+02	9.975861e-01,	7.171993e-12
    476	1.476476e+02	9.975861e-01,	7.176859e-12
    477	1.477477e+02	9.975861e-01,	7.181725e-12
    478	1.478478e+02	9.975861e-01,	7.186590e-12
    479	1.479479e+02	9.975861e-01,	7.191456e-12
    480	1.480480e+02	9.975861e-01,	7.196322e-12
    481	1.481481e+02	9.975861e-01,	7.201187e-12
    482	1.482482e+02	9.975861e-01,	7.206053e-12
    483	1.483483e+02	9.975861e-01,	7.210919e-12
    484	1.484484e+02	9.975861e-01,	7.215784e-12
    485	1.485485e+02	9.975861e-01,	7.220650e-12
    486	1.486486e+02	9.975861e-01,	7.225516e-12
    487	1.487487e+02	9.975861e-01,	7.230381e-12
    488	1.488488e+02	9.975861e-01,	7.235247e-12
    489	1.489489e+02	9.975861e-01,	7.240113e-12
    490	1.490490e+02	9.975861e-01,	7.244978e-12
    491	1.491491e+02	9.975861e-01,	7.249844e-12
    492	1.492492e+02	9.975861e-01,	7.254710e-12
    493	1.493493e+02	9.975861e-01,	7.259575e-12
    494	1.494494e+02	9.975861e-01,	7.264441e-12
    495	1.495495e+02	9.975861e-01,	7.269307e-12
    496	1.496496e+02	9.975861e-01,	7.274172e-12
    497	1.497497e+02	9.975861e-01,	7.279038e-12
    498	1.498498e+02	9.975861e-01,	7.283904e-12
    499	1.499499e+02	9.975861e-01,	7.288769e-12
    500	1.500501e+02	9.975861e-01,	7.293635e-12
    501	1.501502e+02	9.975861e-01,	7.298501e-12
    502	1.502503e+02	9.975861e-01,	7.303366e-12
    503	1.503504e+02	9.975861e-01,	7.308232e-12
    504	1.504505e+02	9.975861e-01,	7.313098e-12
    505	1.505506e+02	9.975861e-01,	7.317963e-12
    506	1.506507e+02	9.975861e-01,	7.322829e-12
    507	1.507508e+02	9.975861e-01,	7.327695e-12
    508	1.508509e+02	9.975861e-01,	7.332560e-12
    509	1.509510e+02	9.975861e-01,	7.337426e-12
    510	1.510511e+02	9.975861e-01,	7.342292e-12
    511	1.511512e+02	9.975861e-01,	7.347157e-12
    512	1.512513e+02	9.975861e-01,	7.352023e-12
    513	1.513514e+02	9.975861e-01,	7.356889e-12
    514	1.514515e+02	9.975861e-01,	7.361754e-12
    515	1.515516e+02	9.975861e-01,	7.366620e-12
    516	1.516517e+02	9.975861e-01,	7.371486e-12
    517	1.517518e+02	9.975861e-01,	7.376351e-12
    518	1.518519e+02	9.975861e-01,	7.381217e-12
    Index   frequency       s11
    519	1.519520e+02	9.975861e-01,	7.386083e-12
    520	1.520521e+02	9.975861e-01,	7.390948e-12
    521	1.521522e+02	9.975861e-01,	7.395814e-12
    522	1.522523e+02	9.975861e-01,	7.400680e-12
    523	1.523524e+02	9.975861e-01,	7.405545e-12
    524	1.524525e+02	9.975861e-01,	7.410411e-12
    525	1.525526e+02	9.975861e-01,	7.415277e-12
    526	1.526527e+02	9.975861e-01,	7.420142e-12
    527	1.527528e+02	9.975861e-01,	7.425008e-12
    528	1.528529e+02	9.975861e-01,	7.429874e-12
    529	1.529530e+02	9.975861e-01,	7.434739e-12
    530	1.530531e+02	9.975861e-01,	7.439605e-12
    531	1.531532e+02	9.975861e-01,	7.444471e-12
    532	1.532533e+02	9.975861e-01,	7.449336e-12
    533	1.533534e+02	9.975861e-01,	7.454202e-12
    534	1.534535e+02	9.975861e-01,	7.459068e-12
    535	1.535536e+02	9.975861e-01,	7.463933e-12
    536	1.536537e+02	9.975861e-01,	7.468799e-12
    537	1.537538e+02	9.975861e-01,	7.473665e-12
    538	1.538539e+02	9.975861e-01,	7.478530e-12
    539	1.539540e+02	9.975861e-01,	7.483396e-12
    540	1.540541e+02	9.975861e-01,	7.488262e-12
    541	1.541542e+02	9.975861e-01,	7.493127e-12
    542	1.542543e+02	9.975861e-01,	7.497993e-12
    543	1.543544e+02	9.975861e-01,	7.502859e-12
    544	1.544545e+02	9.975861e-01,	7.507724e-12
    545	1.545546e+02	9.975861e-01,	7.512590e-12
    546	1.546547e+02	9.975861e-01,	7.517456e-12
    547	1.547548e+02	9.975861e-01,	7.522321e-12
    548	1.548549e+02	9.975861e-01,	7.527187e-12
    549	1.549550e+02	9.975861e-01,	7.532053e-12
    550	1.550551e+02	9.975861e-01,	7.536918e-12
    551	1.551552e+02	9.975861e-01,	7.541784e-12
    552	1.552553e+02	9.975861e-01,	7.546650e-12
    553	1.553554e+02	9.975861e-01,	7.551515e-12
    554	1.554555e+02	9.975861e-01,	7.556381e-12
    555	1.555556e+02	9.975861e-01,	7.561247e-12
    556	1.556557e+02	9.975861e-01,	7.566112e-12
    557	1.557558e+02	9.975861e-01,	7.570978e-12
    558	1.558559e+02	9.975861e-01,	7.575844e-12
    559	1.559560e+02	9.975861e-01,	7.580709e-12
    560	1.560561e+02	9.975861e-01,	7.585575e-12
    561	1.561562e+02	9.975861e-01,	7.590441e-12
    562	1.562563e+02	9.975861e-01,	7.595306e-12
    563	1.563564e+02	9.975861e-01,	7.600172e-12
    564	1.564565e+02	9.975861e-01,	7.605038e-12
    565	1.565566e+02	9.975861e-01,	7.609903e-12
    566	1.566567e+02	9.975861e-01,	7.614769e-12
    567	1.567568e+02	9.975861e-01,	7.619635e-12
    568	1.568569e+02	9.975861e-01,	7.624500e-12
    569	1.569570e+02	9.975861e-01,	7.629366e-12
    570	1.570571e+02	9.975861e-01,	7.634232e-12
    571	1.571572e+02	9.975861e-01,	7.639097e-12
    572	1.572573e+02	9.975861e-01,	7.643963e-12
    573	1.573574e+02	9.975861e-01,	7.648829e-12
    574	1.574575e+02	9.975861e-01,	7.653694e-12
    575	1.575576e+02	9.975861e-01,	7.658560e-12
    576	1.576577e+02	9.975861e-01,	7.663426e-12
    Index   frequency       s11
    577	1.577578e+02	9.975861e-01,	7.668291e-12
    578	1.578579e+02	9.975861e-01,	7.673157e-12
    579	1.579580e+02	9.975861e-01,	7.678023e-12
    580	1.580581e+02	9.975861e-01,	7.682888e-12
    581	1.581582e+02	9.975861e-01,	7.687754e-12
    582	1.582583e+02	9.975861e-01,	7.692620e-12
    583	1.583584e+02	9.975861e-01,	7.697485e-12
    584	1.584585e+02	9.975861e-01,	7.702351e-12
    585	1.585586e+02	9.975861e-01,	7.707217e-12
    586	1.586587e+02	9.975861e-01,	7.712082e-12
    587	1.587588e+02	9.975861e-01,	7.716948e-12
    588	1.588589e+02	9.975861e-01,	7.721814e-12
    589	1.589590e+02	9.975861e-01,	7.726679e-12
    590	1.590591e+02	9.975861e-01,	7.731545e-12
    591	1.591592e+02	9.975861e-01,	7.736411e-12
    592	1.592593e+02	9.975861e-01,	7.741276e-12
    593	1.593594e+02	9.975861e-01,	7.746142e-12
    594	1.594595e+02	9.975861e-01,	7.751008e-12
    595	1.595596e+02	9.975861e-01,	7.755873e-12
    596	1.596597e+02	9.975861e-01,	7.760739e-12
    597	1.597598e+02	9.975861e-01,	7.765605e-12
    598	1.598599e+02	9.975861e-01,	7.770470e-12
    599	1.599600e+02	9.975861e-01,	7.775336e-12
    600	1.600601e+02	9.975861e-01,	7.780202e-12
    601	1.601602e+02	9.975861e-01,	7.785067e-12
    602	1.602603e+02	9.975861e-01,	7.789933e-12
    603	1.603604e+02	9.975861e-01,	7.794799e-12
    604	1.604605e+02	9.975861e-01,	7.799664e-12
    605	1.605606e+02	9.975861e-01,	7.804530e-12
    606	1.606607e+02	9.975861e-01,	7.809396e-12
    607	1.607608e+02	9.975861e-01,	7.814261e-12
    608	1.608609e+02	9.975861e-01,	7.819127e-12
    609	1.609610e+02	9.975861e-01,	7.823993e-12
    610	1.610611e+02	9.975861e-01,	7.828858e-12
    611	1.611612e+02	9.975861e-01,	7.833724e-12
    612	1.612613e+02	9.975861e-01,	7.838590e-12
    613	1.613614e+02	9.975861e-01,	7.843455e-12
    614	1.614615e+02	9.975861e-01,	7.848321e-12
    615	1.615616e+02	9.975861e-01,	7.853187e-12
    616	1.616617e+02	9.975861e-01,	7.858052e-12
    617	1.617618e+02	9.975861e-01,	7.862918e-12
    618	1.618619e+02	9.975861e-01,	7.867784e-12
    619	1.619620e+02	9.975861e-01,	7.872649e-12
    620	1.620621e+02	9.975861e-01,	7.877515e-12
    621	1.621622e+02	9.975861e-01,	7.882381e-12
    622	1.622623e+02	9.975861e-01,	7.887246e-12
    623	1.623624e+02	9.975861e-01,	7.892112e-12
    624	1.624625e+02	9.975861e-01,	7.896978e-12
    625	1.625626e+02	9.975861e-01,	7.901843e-12
    626	1.626627e+02	9.975861e-01,	7.906709e-12
    627	1.627628e+02	9.975861e-01,	7.911575e-12
    628	1.628629e+02	9.975861e-01,	7.916440e-12
    629	1.629630e+02	9.975861e-01,	7.921306e-12
    630	1.630631e+02	9.975861e-01,	7.926172e-12
    631	1.631632e+02	9.975861e-01,	7.931037e-12
    632	1.632633e+02	9.975861e-01,	7.935903e-12
    633	1.633634e+02	9.975861e-01,	7.940769e-12
    634	1.634635e+02	9.975861e-01,	7.945634e-12
    Index   frequency       s11
    635	1.635636e+02	9.975861e-01,	7.950500e-12
    636	1.636637e+02	9.975861e-01,	7.955366e-12
    637	1.637638e+02	9.975861e-01,	7.960231e-12
    638	1.638639e+02	9.975861e-01,	7.965097e-12
    639	1.639640e+02	9.975861e-01,	7.969963e-12
    640	1.640641e+02	9.975861e-01,	7.974828e-12
    641	1.641642e+02	9.975861e-01,	7.979694e-12
    642	1.642643e+02	9.975861e-01,	7.984560e-12
    643	1.643644e+02	9.975861e-01,	7.989425e-12
    644	1.644645e+02	9.975861e-01,	7.994291e-12
    645	1.645646e+02	9.975861e-01,	7.999157e-12
    646	1.646647e+02	9.975861e-01,	8.004022e-12
    647	1.647648e+02	9.975861e-01,	8.008888e-12
    648	1.648649e+02	9.975861e-01,	8.013754e-12
    649	1.649650e+02	9.975861e-01,	8.018619e-12
    650	1.650651e+02	9.975861e-01,	8.023485e-12
    651	1.651652e+02	9.975861e-01,	8.028351e-12
    652	1.652653e+02	9.975861e-01,	8.033216e-12
    653	1.653654e+02	9.975861e-01,	8.038082e-12
    654	1.654655e+02	9.975861e-01,	8.042948e-12
    655	1.655656e+02	9.975861e-01,	8.047813e-12
    656	1.656657e+02	9.975861e-01,	8.052679e-12
    657	1.657658e+02	9.975861e-01,	8.057545e-12
    658	1.658659e+02	9.975861e-01,	8.062410e-12
    659	1.659660e+02	9.975861e-01,	8.067276e-12
    660	1.660661e+02	9.975861e-01,	8.072142e-12
    661	1.661662e+02	9.975861e-01,	8.077007e-12
    662	1.662663e+02	9.975861e-01,	8.081873e-12
    663	1.663664e+02	9.975861e-01,	8.086739e-12
    664	1.664665e+02	9.975861e-01,	8.091604e-12
    665	1.665666e+02	9.975861e-01,	8.096470e-12
    666	1.666667e+02	9.975861e-01,	8.101336e-12
    667	1.667668e+02	9.975861e-01,	8.106201e-12
    668	1.668669e+02	9.975861e-01,	8.111067e-12
    669	1.669670e+02	9.975861e-01,	8.115933e-12
    670	1.670671e+02	9.975861e-01,	8.120798e-12
    671	1.671672e+02	9.975861e-01,	8.125664e-12
    672	1.672673e+02	9.975861e-01,	8.130530e-12
    673	1.673674e+02	9.975861e-01,	8.135395e-12
    674	1.674675e+02	9.975861e-01,	8.140261e-12
    675	1.675676e+02	9.975861e-01,	8.145127e-12
    676	1.676677e+02	9.975861e-01,	8.149992e-12
    677	1.677678e+02	9.975861e-01,	8.154858e-12
    678	1.678679e+02	9.975861e-01,	8.159724e-12
    679	1.679680e+02	9.975861e-01,	8.164589e-12
    680	1.680681e+02	9.975861e-01,	8.169455e-12
    681	1.681682e+02	9.975861e-01,	8.174321e-12
    682	1.682683e+02	9.975861e-01,	8.179186e-12
    683	1.683684e+02	9.975861e-01,	8.184052e-12
    684	1.684685e+02	9.975861e-01,	8.188918e-12
    685	1.685686e+02	9.975861e-01,	8.193783e-12
    686	1.686687e+02	9.975861e-01,	8.198649e-12
    687	1.687688e+02	9.975861e-01,	8.203515e-12
    688	1.688689e+02	9.975861e-01,	8.208380e-12
    689	1.689690e+02	9.975861e-01,	8.213246e-12
    690	1.690691e+02	9.975861e-01,	8.218112e-12
    691	1.691692e+02	9.975861e-01,	8.222977e-12
    692	1.692693e+02	9.975861e-01,	8.227843e-12
    Index   frequency       s11
    693	1.693694e+02	9.975861e-01,	8.232709e-12
    694	1.694695e+02	9.975861e-01,	8.237574e-12
    695	1.695696e+02	9.975861e-01,	8.242440e-12
    696	1.696697e+02	9.975861e-01,	8.247306e-12
    697	1.697698e+02	9.975861e-01,	8.252171e-12
    698	1.698699e+02	9.975861e-01,	8.257037e-12
    699	1.699700e+02	9.975861e-01,	8.261903e-12
    700	1.700701e+02	9.975861e-01,	8.266768e-12
    701	1.701702e+02	9.975861e-01,	8.271634e-12
    702	1.702703e+02	9.975861e-01,	8.276500e-12
    703	1.703704e+02	9.975861e-01,	8.281365e-12
    704	1.704705e+02	9.975861e-01,	8.286231e-12
    705	1.705706e+02	9.975861e-01,	8.291097e-12
    706	1.706707e+02	9.975861e-01,	8.295962e-12
    707	1.707708e+02	9.975861e-01,	8.300828e-12
    708	1.708709e+02	9.975861e-01,	8.305694e-12
    709	1.709710e+02	9.975861e-01,	8.310559e-12
    710	1.710711e+02	9.975861e-01,	8.315425e-12
    711	1.711712e+02	9.975861e-01,	8.320291e-12
    712	1.712713e+02	9.975861e-01,	8.325156e-12
    713	1.713714e+02	9.975861e-01,	8.330022e-12
    714	1.714715e+02	9.975861e-01,	8.334888e-12
    715	1.715716e+02	9.975861e-01,	8.339753e-12
    716	1.716717e+02	9.975861e-01,	8.344619e-12
    717	1.717718e+02	9.975861e-01,	8.349485e-12
    718	1.718719e+02	9.975861e-01,	8.354350e-12
    719	1.719720e+02	9.975861e-01,	8.359216e-12
    720	1.720721e+02	9.975861e-01,	8.364082e-12
    721	1.721722e+02	9.975861e-01,	8.368947e-12
    722	1.722723e+02	9.975861e-01,	8.373813e-12
    723	1.723724e+02	9.975861e-01,	8.378679e-12
    724	1.724725e+02	9.975861e-01,	8.383544e-12
    725	1.725726e+02	9.975861e-01,	8.388410e-12
    726	1.726727e+02	9.975861e-01,	8.393276e-12
    727	1.727728e+02	9.975861e-01,	8.398141e-12
    728	1.728729e+02	9.975861e-01,	8.403007e-12
    729	1.729730e+02	9.975861e-01,	8.407873e-12
    730	1.730731e+02	9.975861e-01,	8.412738e-12
    731	1.731732e+02	9.975861e-01,	8.417604e-12
    732	1.732733e+02	9.975861e-01,	8.422470e-12
    733	1.733734e+02	9.975861e-01,	8.427335e-12
    734	1.734735e+02	9.975861e-01,	8.432201e-12
    735	1.735736e+02	9.975861e-01,	8.437067e-12
    736	1.736737e+02	9.975861e-01,	8.441932e-12
    737	1.737738e+02	9.975861e-01,	8.446798e-12
    738	1.738739e+02	9.975861e-01,	8.451664e-12
    739	1.739740e+02	9.975861e-01,	8.456529e-12
    740	1.740741e+02	9.975861e-01,	8.461395e-12
    741	1.741742e+02	9.975861e-01,	8.466261e-12
    742	1.742743e+02	9.975861e-01,	8.471126e-12
    743	1.743744e+02	9.975861e-01,	8.475992e-12
    744	1.744745e+02	9.975861e-01,	8.480858e-12
    745	1.745746e+02	9.975861e-01,	8.485723e-12
    746	1.746747e+02	9.975861e-01,	8.490589e-12
    747	1.747748e+02	9.975861e-01,	8.495455e-12
    748	1.748749e+02	9.975861e-01,	8.500320e-12
    749	1.749750e+02	9.975861e-01,	8.505186e-12
    750	1.750751e+02	9.975861e-01,	8.510052e-12
    Index   frequency       s11
    751	1.751752e+02	9.975861e-01,	8.514917e-12
    752	1.752753e+02	9.975861e-01,	8.519783e-12
    753	1.753754e+02	9.975861e-01,	8.524649e-12
    754	1.754755e+02	9.975861e-01,	8.529514e-12
    755	1.755756e+02	9.975861e-01,	8.534380e-12
    756	1.756757e+02	9.975861e-01,	8.539246e-12
    757	1.757758e+02	9.975861e-01,	8.544111e-12
    758	1.758759e+02	9.975861e-01,	8.548977e-12
    759	1.759760e+02	9.975861e-01,	8.553843e-12
    760	1.760761e+02	9.975861e-01,	8.558708e-12
    761	1.761762e+02	9.975861e-01,	8.563574e-12
    762	1.762763e+02	9.975861e-01,	8.568440e-12
    763	1.763764e+02	9.975861e-01,	8.573305e-12
    764	1.764765e+02	9.975861e-01,	8.578171e-12
    765	1.765766e+02	9.975861e-01,	8.583037e-12
    766	1.766767e+02	9.975861e-01,	8.587902e-12
    767	1.767768e+02	9.975861e-01,	8.592768e-12
    768	1.768769e+02	9.975861e-01,	8.597634e-12
    769	1.769770e+02	9.975861e-01,	8.602499e-12
    770	1.770771e+02	9.975861e-01,	8.607365e-12
    771	1.771772e+02	9.975861e-01,	8.612231e-12
    772	1.772773e+02	9.975861e-01,	8.617096e-12
    773	1.773774e+02	9.975861e-01,	8.621962e-12
    774	1.774775e+02	9.975861e-01,	8.626828e-12
    775	1.775776e+02	9.975861e-01,	8.631693e-12
    776	1.776777e+02	9.975861e-01,	8.636559e-12
    777	1.777778e+02	9.975861e-01,	8.641425e-12
    778	1.778779e+02	9.975861e-01,	8.646290e-12
    779	1.779780e+02	9.975861e-01,	8.651156e-12
    780	1.780781e+02	9.975861e-01,	8.656022e-12
    781	1.781782e+02	9.975861e-01,	8.660887e-12
    782	1.782783e+02	9.975861e-01,	8.665753e-12
    783	1.783784e+02	9.975861e-01,	8.670619e-12
    784	1.784785e+02	9.975861e-01,	8.675484e-12
    785	1.785786e+02	9.975861e-01,	8.680350e-12
    786	1.786787e+02	9.975861e-01,	8.685216e-12
    787	1.787788e+02	9.975861e-01,	8.690081e-12
    788	1.788789e+02	9.975861e-01,	8.694947e-12
    789	1.789790e+02	9.975861e-01,	8.699813e-12
    790	1.790791e+02	9.975861e-01,	8.704678e-12
    791	1.791792e+02	9.975861e-01,	8.709544e-12
    792	1.792793e+02	9.975861e-01,	8.714410e-12
    793	1.793794e+02	9.975861e-01,	8.719275e-12
    794	1.794795e+02	9.975861e-01,	8.724141e-12
    795	1.795796e+02	9.975861e-01,	8.729007e-12
    796	1.796797e+02	9.975861e-01,	8.733872e-12
    797	1.797798e+02	9.975861e-01,	8.738738e-12
    798	1.798799e+02	9.975861e-01,	8.743604e-12
    799	1.799800e+02	9.975861e-01,	8.748469e-12
    800	1.800801e+02	9.975861e-01,	8.753335e-12
    801	1.801802e+02	9.975861e-01,	8.758201e-12
    802	1.802803e+02	9.975861e-01,	8.763066e-12
    803	1.803804e+02	9.975861e-01,	8.767932e-12
    804	1.804805e+02	9.975861e-01,	8.772798e-12
    805	1.805806e+02	9.975861e-01,	8.777663e-12
    806	1.806807e+02	9.975861e-01,	8.782529e-12
    807	1.807808e+02	9.975861e-01,	8.787395e-12
    808	1.808809e+02	9.975861e-01,	8.792260e-12
    Index   frequency       s11
    809	1.809810e+02	9.975861e-01,	8.797126e-12
    810	1.810811e+02	9.975861e-01,	8.801992e-12
    811	1.811812e+02	9.975861e-01,	8.806857e-12
    812	1.812813e+02	9.975861e-01,	8.811723e-12
    813	1.813814e+02	9.975861e-01,	8.816589e-12
    814	1.814815e+02	9.975861e-01,	8.821454e-12
    815	1.815816e+02	9.975861e-01,	8.826320e-12
    816	1.816817e+02	9.975861e-01,	8.831186e-12
    817	1.817818e+02	9.975861e-01,	8.836051e-12
    818	1.818819e+02	9.975861e-01,	8.840917e-12
    819	1.819820e+02	9.975861e-01,	8.845783e-12
    820	1.820821e+02	9.975861e-01,	8.850648e-12
    821	1.821822e+02	9.975861e-01,	8.855514e-12
    822	1.822823e+02	9.975861e-01,	8.860380e-12
    823	1.823824e+02	9.975861e-01,	8.865245e-12
    824	1.824825e+02	9.975861e-01,	8.870111e-12
    825	1.825826e+02	9.975861e-01,	8.874977e-12
    826	1.826827e+02	9.975861e-01,	8.879842e-12
    827	1.827828e+02	9.975861e-01,	8.884708e-12
    828	1.828829e+02	9.975861e-01,	8.889574e-12
    829	1.829830e+02	9.975861e-01,	8.894439e-12
    830	1.830831e+02	9.975861e-01,	8.899305e-12
    831	1.831832e+02	9.975861e-01,	8.904171e-12
    832	1.832833e+02	9.975861e-01,	8.909036e-12
    833	1.833834e+02	9.975861e-01,	8.913902e-12
    834	1.834835e+02	9.975861e-01,	8.918768e-12
    835	1.835836e+02	9.975861e-01,	8.923633e-12
    836	1.836837e+02	9.975861e-01,	8.928499e-12
    837	1.837838e+02	9.975861e-01,	8.933365e-12
    838	1.838839e+02	9.975861e-01,	8.938230e-12
    839	1.839840e+02	9.975861e-01,	8.943096e-12
    840	1.840841e+02	9.975861e-01,	8.947962e-12
    841	1.841842e+02	9.975861e-01,	8.952827e-12
    842	1.842843e+02	9.975861e-01,	8.957693e-12
    843	1.843844e+02	9.975861e-01,	8.962559e-12
    844	1.844845e+02	9.975861e-01,	8.967424e-12
    845	1.845846e+02	9.975861e-01,	8.972290e-12
    846	1.846847e+02	9.975861e-01,	8.977156e-12
    847	1.847848e+02	9.975861e-01,	8.982021e-12
    848	1.848849e+02	9.975861e-01,	8.986887e-12
    849	1.849850e+02	9.975861e-01,	8.991753e-12
    850	1.850851e+02	9.975861e-01,	8.996618e-12
    851	1.851852e+02	9.975861e-01,	9.001484e-12
    852	1.852853e+02	9.975861e-01,	9.006350e-12
    853	1.853854e+02	9.975861e-01,	9.011215e-12
    854	1.854855e+02	9.975861e-01,	9.016081e-12
    855	1.855856e+02	9.975861e-01,	9.020947e-12
    856	1.856857e+02	9.975861e-01,	9.025812e-12
    857	1.857858e+02	9.975861e-01,	9.030678e-12
    858	1.858859e+02	9.975861e-01,	9.035544e-12
    859	1.859860e+02	9.975861e-01,	9.040409e-12
    860	1.860861e+02	9.975861e-01,	9.045275e-12
    861	1.861862e+02	9.975861e-01,	9.050141e-12
    862	1.862863e+02	9.975861e-01,	9.055006e-12
    863	1.863864e+02	9.975861e-01,	9.059872e-12
    864	1.864865e+02	9.975861e-01,	9.064738e-12
    865	1.865866e+02	9.975861e-01,	9.069603e-12
    866	1.866867e+02	9.975861e-01,	9.074469e-12
    Index   frequency       s11
    867	1.867868e+02	9.975861e-01,	9.079335e-12
    868	1.868869e+02	9.975861e-01,	9.084200e-12
    869	1.869870e+02	9.975861e-01,	9.089066e-12
    870	1.870871e+02	9.975861e-01,	9.093932e-12
    871	1.871872e+02	9.975861e-01,	9.098797e-12
    872	1.872873e+02	9.975861e-01,	9.103663e-12
    873	1.873874e+02	9.975861e-01,	9.108529e-12
    874	1.874875e+02	9.975861e-01,	9.113394e-12
    875	1.875876e+02	9.975861e-01,	9.118260e-12
    876	1.876877e+02	9.975861e-01,	9.123126e-12
    877	1.877878e+02	9.975861e-01,	9.127991e-12
    878	1.878879e+02	9.975861e-01,	9.132857e-12
    879	1.879880e+02	9.975861e-01,	9.137723e-12
    880	1.880881e+02	9.975861e-01,	9.142588e-12
    881	1.881882e+02	9.975861e-01,	9.147454e-12
    882	1.882883e+02	9.975861e-01,	9.152320e-12
    883	1.883884e+02	9.975861e-01,	9.157185e-12
    884	1.884885e+02	9.975861e-01,	9.162051e-12
    885	1.885886e+02	9.975861e-01,	9.166917e-12
    886	1.886887e+02	9.975861e-01,	9.171782e-12
    887	1.887888e+02	9.975861e-01,	9.176648e-12
    888	1.888889e+02	9.975861e-01,	9.181514e-12
    889	1.889890e+02	9.975861e-01,	9.186379e-12
    890	1.890891e+02	9.975861e-01,	9.191245e-12
    891	1.891892e+02	9.975861e-01,	9.196111e-12
    892	1.892893e+02	9.975861e-01,	9.200976e-12
    893	1.893894e+02	9.975861e-01,	9.205842e-12
    894	1.894895e+02	9.975861e-01,	9.210708e-12
    895	1.895896e+02	9.975861e-01,	9.215573e-12
    896	1.896897e+02	9.975861e-01,	9.220439e-12
    897	1.897898e+02	9.975861e-01,	9.225305e-12
    898	1.898899e+02	9.975861e-01,	9.230170e-12
    899	1.899900e+02	9.975861e-01,	9.235036e-12
    900	1.900901e+02	9.975861e-01,	9.239902e-12
    901	1.901902e+02	9.975861e-01,	9.244767e-12
    902	1.902903e+02	9.975861e-01,	9.249633e-12
    903	1.903904e+02	9.975861e-01,	9.254499e-12
    904	1.904905e+02	9.975861e-01,	9.259364e-12
    905	1.905906e+02	9.975861e-01,	9.264230e-12
    906	1.906907e+02	9.975861e-01,	9.269096e-12
    907	1.907908e+02	9.975861e-01,	9.273961e-12
    908	1.908909e+02	9.975861e-01,	9.278827e-12
    909	1.909910e+02	9.975861e-01,	9.283693e-12
    910	1.910911e+02	9.975861e-01,	9.288558e-12
    911	1.911912e+02	9.975861e-01,	9.293424e-12
    912	1.912913e+02	9.975861e-01,	9.298290e-12
    913	1.913914e+02	9.975861e-01,	9.303155e-12
    914	1.914915e+02	9.975861e-01,	9.308021e-12
    915	1.915916e+02	9.975861e-01,	9.312887e-12
    916	1.916917e+02	9.975861e-01,	9.317752e-12
    917	1.917918e+02	9.975861e-01,	9.322618e-12
    918	1.918919e+02	9.975861e-01,	9.327484e-12
    919	1.919920e+02	9.975861e-01,	9.332349e-12
    920	1.920921e+02	9.975861e-01,	9.337215e-12
    921	1.921922e+02	9.975861e-01,	9.342081e-12
    922	1.922923e+02	9.975861e-01,	9.346946e-12
    923	1.923924e+02	9.975861e-01,	9.351812e-12
    924	1.924925e+02	9.975861e-01,	9.356678e-12
    Index   frequency       s11
    925	1.925926e+02	9.975861e-01,	9.361543e-12
    926	1.926927e+02	9.975861e-01,	9.366409e-12
    927	1.927928e+02	9.975861e-01,	9.371275e-12
    928	1.928929e+02	9.975861e-01,	9.376140e-12
    929	1.929930e+02	9.975861e-01,	9.381006e-12
    930	1.930931e+02	9.975861e-01,	9.385872e-12
    931	1.931932e+02	9.975861e-01,	9.390737e-12
    932	1.932933e+02	9.975861e-01,	9.395603e-12
    933	1.933934e+02	9.975861e-01,	9.400469e-12
    934	1.934935e+02	9.975861e-01,	9.405334e-12
    935	1.935936e+02	9.975861e-01,	9.410200e-12
    936	1.936937e+02	9.975861e-01,	9.415066e-12
    937	1.937938e+02	9.975861e-01,	9.419931e-12
    938	1.938939e+02	9.975861e-01,	9.424797e-12
    939	1.939940e+02	9.975861e-01,	9.429663e-12
    940	1.940941e+02	9.975861e-01,	9.434528e-12
    941	1.941942e+02	9.975861e-01,	9.439394e-12
    942	1.942943e+02	9.975861e-01,	9.444260e-12
    943	1.943944e+02	9.975861e-01,	9.449125e-12
    944	1.944945e+02	9.975861e-01,	9.453991e-12
    945	1.945946e+02	9.975861e-01,	9.458857e-12
    946	1.946947e+02	9.975861e-01,	9.463722e-12
    947	1.947948e+02	9.975861e-01,	9.468588e-12
    948	1.948949e+02	9.975861e-01,	9.473454e-12
    949	1.949950e+02	9.975861e-01,	9.478319e-12
    950	1.950951e+02	9.975861e-01,	9.483185e-12
    951	1.951952e+02	9.975861e-01,	9.488051e-12
    952	1.952953e+02	9.975861e-01,	9.492916e-12
    953	1.953954e+02	9.975861e-01,	9.497782e-12
    954	1.954955e+02	9.975861e-01,	9.502648e-12
    955	1.955956e+02	9.975861e-01,	9.507513e-12
    956	1.956957e+02	9.975861e-01,	9.512379e-12
    957	1.957958e+02	9.975861e-01,	9.517245e-12
    958	1.958959e+02	9.975861e-01,	9.522110e-12
    959	1.959960e+02	9.975861e-01,	9.526976e-12
    960	1.960961e+02	9.975861e-01,	9.531842e-12
    961	1.961962e+02	9.975861e-01,	9.536707e-12
    962	1.962963e+02	9.975861e-01,	9.541573e-12
    963	1.963964e+02	9.975861e-01,	9.546439e-12
    964	1.964965e+02	9.975861e-01,	9.551304e-12
    965	1.965966e+02	9.975861e-01,	9.556170e-12
    966	1.966967e+02	9.975861e-01,	9.561036e-12
    967	1.967968e+02	9.975861e-01,	9.565901e-12
    968	1.968969e+02	9.975861e-01,	9.570767e-12
    969	1.969970e+02	9.975861e-01,	9.575633e-12
    970	1.970971e+02	9.975861e-01,	9.580498e-12
    971	1.971972e+02	9.975861e-01,	9.585364e-12
    972	1.972973e+02	9.975861e-01,	9.590230e-12
    973	1.973974e+02	9.975861e-01,	9.595096e-12
    974	1.974975e+02	9.975861e-01,	9.599961e-12
    975	1.975976e+02	9.975861e-01,	9.604827e-12
    976	1.976977e+02	9.975861e-01,	9.609693e-12
    977	1.977978e+02	9.975861e-01,	9.614558e-12
    978	1.978979e+02	9.975861e-01,	9.619424e-12
    979	1.979980e+02	9.975861e-01,	9.624290e-12
    980	1.980981e+02	9.975861e-01,	9.629155e-12
    981	1.981982e+02	9.975861e-01,	9.634021e-12
    982	1.982983e+02	9.975861e-01,	9.638887e-12
    Index   frequency       s11
    983	1.983984e+02	9.975861e-01,	9.643752e-12
    984	1.984985e+02	9.975861e-01,	9.648618e-12
    985	1.985986e+02	9.975861e-01,	9.653484e-12
    986	1.986987e+02	9.975861e-01,	9.658349e-12
    987	1.987988e+02	9.975861e-01,	9.663215e-12
    988	1.988989e+02	9.975861e-01,	9.668081e-12
    989	1.989990e+02	9.975861e-01,	9.672946e-12
    990	1.990991e+02	9.975861e-01,	9.677812e-12
    991	1.991992e+02	9.975861e-01,	9.682678e-12
    992	1.992993e+02	9.975861e-01,	9.687543e-12
    993	1.993994e+02	9.975861e-01,	9.692409e-12
    994	1.994995e+02	9.975861e-01,	9.697275e-12
    995	1.995996e+02	9.975861e-01,	9.702140e-12
    996	1.996997e+02	9.975861e-01,	9.707006e-12
    997	1.997998e+02	9.975861e-01,	9.711872e-12
    998	1.998999e+02	9.975861e-01,	9.716737e-12
    999	2.000000e+02	9.975861e-01,	9.721603e-12
    Apr 2011
    11,656
    46,775
    52
    Quote Originally Posted by promach View Post
    @BradtheRad
    The circuit below is listed among the menu of Falstad's interactive animated simulator. (Your computer needs to have Java installed. Whether to do so is up to you.)
    www.falstad.com/circuit
Name:	active inductor (gyrator) circuit in Falstad menu.png
    Both circuits have a 1k resistor as the load. The op amp output is determined by the inputs. When volt levels at the inputs cross, the output changes state. We might ask what the waveforms look like? After all the behavior is not obvious and we're not certain if the load has a part in the equation. In this case it appears that the RC network does in fact govern the action. Identical waveforms appear at both the inverting and non-inverting input.
    •   Alt12th February 2018, 03:18
      advertising
  7. #7
    Points: 25,907, Level: 39
    Nov 2001
    Earth
    3,659
    25,907
    39
    Transform this s-parameters list onto Touchstone format the use them in a any RF simulator to obtain all information.
    For instance ADS will directly give you Input Impedance/Admittance when you plot s-parameters on the Smith Chart.
    •   Alt12th February 2018, 03:22
      advertising
  8. #8
    Full Member level 4
    Feb 2016
    203
    1,197
    7
    @BradtheRad
    Would you be able share your specific falstad link containing your own active inductor circuitry ?
  9. #9
    Points: 34,250, Level: 45
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Sep 2007
    Richmond Hill, ON, Canada
    6,631
    34,250
    45
    Blog Entries
    7
    @BradtheRad
    For T=L/R =1/2pif R = Rin//Rload
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  10. #10
    Apr 2011
    11,656
    46,775
    52
    @BradtheRad
    Falstad's has the ability to export a link containing an entire circuit. By clicking the link below it will do the following:
    * Open the falstad.com website
    * Load my schematic into the simulator
    * Run it on your computer
    If a default RLC resonant circuit appears, then click the Circuits menu, and go to Op Amps >> Gyrator.
    https://tinyurl.com/yah5tp4t
    I merely numbered the circuits and added extra scope traces. The sine frequency sweep is also useful to test as a source. You'll see similar rolloff curves.
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,502
    239,557
    100
    First point, the used data format should be clarified, it's not obvious. Usual data files like touchstone are coming with an explicit format specification. Lets assume frequency in MHz, S-parameters in real-imaginary format, referenced to 50 ohm.
    Second point, the shown S11 is around 1,0 for all frequencies, in other words useless for inductance calculation. Either it's been measured in the wrong frequency range, or something's completely wrong with the circuit.
    I just noticed the measurement setup has a frequency range of 100 to 200 Hz. Do you expect relevant inductance in this frequency range?
    •   Alt12th February 2018, 18:00
      advertising
  12. #12
    Full Member level 4
    Feb 2016
    203
    1,197
    7
    @FvM
    I have then used a 1nH inductor with the same test circuit setup to do S11 measurement instead and I got the result below:
Name:	Screenshot from 2018-02-13 08-37-20.png
     AC Analysis  Tue Feb 13 08:35:33  2018
    Index   frequency       s11
    0	1.000000e+02	-1.00000e+00,	2.513274e-08
    1	1.001001e+02	-1.00000e+00,	2.515790e-08
    2	1.002002e+02	-1.00000e+00,	2.518306e-08
    3	1.003003e+02	-1.00000e+00,	2.520821e-08
    4	1.004004e+02	-1.00000e+00,	2.523337e-08
    5	1.005005e+02	-1.00000e+00,	2.525853e-08
    6	1.006006e+02	-1.00000e+00,	2.528369e-08
    7	1.007007e+02	-1.00000e+00,	2.530885e-08
    8	1.008008e+02	-1.00000e+00,	2.533400e-08
    9	1.009009e+02	-1.00000e+00,	2.535916e-08
    10	1.010010e+02	-1.00000e+00,	2.538432e-08
    11	1.011011e+02	-1.00000e+00,	2.540948e-08
    12	1.012012e+02	-1.00000e+00,	2.543464e-08
    13	1.013013e+02	-1.00000e+00,	2.545979e-08
    14	1.014014e+02	-1.00000e+00,	2.548495e-08
    15	1.015015e+02	-1.00000e+00,	2.551011e-08
    16	1.016016e+02	-1.00000e+00,	2.553527e-08
    17	1.017017e+02	-1.00000e+00,	2.556043e-08
    18	1.018018e+02	-1.00000e+00,	2.558558e-08
    19	1.019019e+02	-1.00000e+00,	2.561074e-08
    20	1.020020e+02	-1.00000e+00,	2.563590e-08
    21	1.021021e+02	-1.00000e+00,	2.566106e-08
    22	1.022022e+02	-1.00000e+00,	2.568622e-08
    23	1.023023e+02	-1.00000e+00,	2.571137e-08
    24	1.024024e+02	-1.00000e+00,	2.573653e-08
    25	1.025025e+02	-1.00000e+00,	2.576169e-08
    26	1.026026e+02	-1.00000e+00,	2.578685e-08
    27	1.027027e+02	-1.00000e+00,	2.581200e-08
    28	1.028028e+02	-1.00000e+00,	2.583716e-08
    29	1.029029e+02	-1.00000e+00,	2.586232e-08
    30	1.030030e+02	-1.00000e+00,	2.588748e-08
    31	1.031031e+02	-1.00000e+00,	2.591264e-08
    32	1.032032e+02	-1.00000e+00,	2.593779e-08
    33	1.033033e+02	-1.00000e+00,	2.596295e-08
    34	1.034034e+02	-1.00000e+00,	2.598811e-08
    35	1.035035e+02	-1.00000e+00,	2.601327e-08
    36	1.036036e+02	-1.00000e+00,	2.603843e-08
    37	1.037037e+02	-1.00000e+00,	2.606358e-08
    38	1.038038e+02	-1.00000e+00,	2.608874e-08
    39	1.039039e+02	-1.00000e+00,	2.611390e-08
    40	1.040040e+02	-1.00000e+00,	2.613906e-08
    41	1.041041e+02	-1.00000e+00,	2.616422e-08
    42	1.042042e+02	-1.00000e+00,	2.618937e-08
    43	1.043043e+02	-1.00000e+00,	2.621453e-08
    44	1.044044e+02	-1.00000e+00,	2.623969e-08
    45	1.045045e+02	-1.00000e+00,	2.626485e-08
    46	1.046046e+02	-1.00000e+00,	2.629000e-08
    47	1.047047e+02	-1.00000e+00,	2.631516e-08
    48	1.048048e+02	-1.00000e+00,	2.634032e-08
    49	1.049049e+02	-1.00000e+00,	2.636548e-08
    50	1.050050e+02	-1.00000e+00,	2.639064e-08
    51	1.051051e+02	-1.00000e+00,	2.641579e-08
    52	1.052052e+02	-1.00000e+00,	2.644095e-08
    53	1.053053e+02	-1.00000e+00,	2.646611e-08
    54	1.054054e+02	-1.00000e+00,	2.649127e-08
    Index   frequency       s11
    55	1.055055e+02	-1.00000e+00,	2.651643e-08
    56	1.056056e+02	-1.00000e+00,	2.654158e-08
    57	1.057057e+02	-1.00000e+00,	2.656674e-08
    58	1.058058e+02	-1.00000e+00,	2.659190e-08
    59	1.059059e+02	-1.00000e+00,	2.661706e-08
    60	1.060060e+02	-1.00000e+00,	2.664222e-08
    61	1.061061e+02	-1.00000e+00,	2.666737e-08
    62	1.062062e+02	-1.00000e+00,	2.669253e-08
    63	1.063063e+02	-1.00000e+00,	2.671769e-08
    64	1.064064e+02	-1.00000e+00,	2.674285e-08
    65	1.065065e+02	-1.00000e+00,	2.676800e-08
    66	1.066066e+02	-1.00000e+00,	2.679316e-08
    67	1.067067e+02	-1.00000e+00,	2.681832e-08
    68	1.068068e+02	-1.00000e+00,	2.684348e-08
    69	1.069069e+02	-1.00000e+00,	2.686864e-08
    70	1.070070e+02	-1.00000e+00,	2.689379e-08
    71	1.071071e+02	-1.00000e+00,	2.691895e-08
    72	1.072072e+02	-1.00000e+00,	2.694411e-08
    73	1.073073e+02	-1.00000e+00,	2.696927e-08
    74	1.074074e+02	-1.00000e+00,	2.699443e-08
    75	1.075075e+02	-1.00000e+00,	2.701958e-08
    76	1.076076e+02	-1.00000e+00,	2.704474e-08
    77	1.077077e+02	-1.00000e+00,	2.706990e-08
    78	1.078078e+02	-1.00000e+00,	2.709506e-08
    79	1.079079e+02	-1.00000e+00,	2.712022e-08
    80	1.080080e+02	-1.00000e+00,	2.714537e-08
    81	1.081081e+02	-1.00000e+00,	2.717053e-08
    82	1.082082e+02	-1.00000e+00,	2.719569e-08
    83	1.083083e+02	-1.00000e+00,	2.722085e-08
    84	1.084084e+02	-1.00000e+00,	2.724600e-08
    85	1.085085e+02	-1.00000e+00,	2.727116e-08
    86	1.086086e+02	-1.00000e+00,	2.729632e-08
    87	1.087087e+02	-1.00000e+00,	2.732148e-08
    88	1.088088e+02	-1.00000e+00,	2.734664e-08
    89	1.089089e+02	-1.00000e+00,	2.737179e-08
    90	1.090090e+02	-1.00000e+00,	2.739695e-08
    91	1.091091e+02	-1.00000e+00,	2.742211e-08
    92	1.092092e+02	-1.00000e+00,	2.744727e-08
    93	1.093093e+02	-1.00000e+00,	2.747243e-08
    94	1.094094e+02	-1.00000e+00,	2.749758e-08
    95	1.095095e+02	-1.00000e+00,	2.752274e-08
    96	1.096096e+02	-1.00000e+00,	2.754790e-08
    97	1.097097e+02	-1.00000e+00,	2.757306e-08
    98	1.098098e+02	-1.00000e+00,	2.759822e-08
    99	1.099099e+02	-1.00000e+00,	2.762337e-08
    100	1.100100e+02	-1.00000e+00,	2.764853e-08
    101	1.101101e+02	-1.00000e+00,	2.767369e-08
    102	1.102102e+02	-1.00000e+00,	2.769885e-08
    103	1.103103e+02	-1.00000e+00,	2.772400e-08
    104	1.104104e+02	-1.00000e+00,	2.774916e-08
    105	1.105105e+02	-1.00000e+00,	2.777432e-08
    106	1.106106e+02	-1.00000e+00,	2.779948e-08
    107	1.107107e+02	-1.00000e+00,	2.782464e-08
    108	1.108108e+02	-1.00000e+00,	2.784979e-08
    109	1.109109e+02	-1.00000e+00,	2.787495e-08
    110	1.110110e+02	-1.00000e+00,	2.790011e-08
    111	1.111111e+02	-1.00000e+00,	2.792527e-08
    112	1.112112e+02	-1.00000e+00,	2.795043e-08
    Index   frequency       s11
    113	1.113113e+02	-1.00000e+00,	2.797558e-08
    114	1.114114e+02	-1.00000e+00,	2.800074e-08
    115	1.115115e+02	-1.00000e+00,	2.802590e-08
    116	1.116116e+02	-1.00000e+00,	2.805106e-08
    117	1.117117e+02	-1.00000e+00,	2.807622e-08
    118	1.118118e+02	-1.00000e+00,	2.810137e-08
    119	1.119119e+02	-1.00000e+00,	2.812653e-08
    120	1.120120e+02	-1.00000e+00,	2.815169e-08
    121	1.121121e+02	-1.00000e+00,	2.817685e-08
    122	1.122122e+02	-1.00000e+00,	2.820200e-08
    123	1.123123e+02	-1.00000e+00,	2.822716e-08
    124	1.124124e+02	-1.00000e+00,	2.825232e-08
    125	1.125125e+02	-1.00000e+00,	2.827748e-08
    126	1.126126e+02	-1.00000e+00,	2.830264e-08
    127	1.127127e+02	-1.00000e+00,	2.832779e-08
    128	1.128128e+02	-1.00000e+00,	2.835295e-08
    129	1.129129e+02	-1.00000e+00,	2.837811e-08
    130	1.130130e+02	-1.00000e+00,	2.840327e-08
    131	1.131131e+02	-1.00000e+00,	2.842843e-08
    132	1.132132e+02	-1.00000e+00,	2.845358e-08
    133	1.133133e+02	-1.00000e+00,	2.847874e-08
    134	1.134134e+02	-1.00000e+00,	2.850390e-08
    135	1.135135e+02	-1.00000e+00,	2.852906e-08
    136	1.136136e+02	-1.00000e+00,	2.855422e-08
    137	1.137137e+02	-1.00000e+00,	2.857937e-08
    138	1.138138e+02	-1.00000e+00,	2.860453e-08
    139	1.139139e+02	-1.00000e+00,	2.862969e-08
    140	1.140140e+02	-1.00000e+00,	2.865485e-08
    141	1.141141e+02	-1.00000e+00,	2.868001e-08
    142	1.142142e+02	-1.00000e+00,	2.870516e-08
    143	1.143143e+02	-1.00000e+00,	2.873032e-08
    144	1.144144e+02	-1.00000e+00,	2.875548e-08
    145	1.145145e+02	-1.00000e+00,	2.878064e-08
    146	1.146146e+02	-1.00000e+00,	2.880579e-08
    147	1.147147e+02	-1.00000e+00,	2.883095e-08
    148	1.148148e+02	-1.00000e+00,	2.885611e-08
    149	1.149149e+02	-1.00000e+00,	2.888127e-08
    150	1.150150e+02	-1.00000e+00,	2.890643e-08
    151	1.151151e+02	-1.00000e+00,	2.893158e-08
    152	1.152152e+02	-1.00000e+00,	2.895674e-08
    153	1.153153e+02	-1.00000e+00,	2.898190e-08
    154	1.154154e+02	-1.00000e+00,	2.900706e-08
    155	1.155155e+02	-1.00000e+00,	2.903222e-08
    156	1.156156e+02	-1.00000e+00,	2.905737e-08
    157	1.157157e+02	-1.00000e+00,	2.908253e-08
    158	1.158158e+02	-1.00000e+00,	2.910769e-08
    159	1.159159e+02	-1.00000e+00,	2.913285e-08
    160	1.160160e+02	-1.00000e+00,	2.915801e-08
    161	1.161161e+02	-1.00000e+00,	2.918316e-08
    162	1.162162e+02	-1.00000e+00,	2.920832e-08
    163	1.163163e+02	-1.00000e+00,	2.923348e-08
    164	1.164164e+02	-1.00000e+00,	2.925864e-08
    165	1.165165e+02	-1.00000e+00,	2.928379e-08
    166	1.166166e+02	-1.00000e+00,	2.930895e-08
    167	1.167167e+02	-1.00000e+00,	2.933411e-08
    168	1.168168e+02	-1.00000e+00,	2.935927e-08
    169	1.169169e+02	-1.00000e+00,	2.938443e-08
    170	1.170170e+02	-1.00000e+00,	2.940958e-08
    Index   frequency       s11
    171	1.171171e+02	-1.00000e+00,	2.943474e-08
    172	1.172172e+02	-1.00000e+00,	2.945990e-08
    173	1.173173e+02	-1.00000e+00,	2.948506e-08
    174	1.174174e+02	-1.00000e+00,	2.951022e-08
    175	1.175175e+02	-1.00000e+00,	2.953537e-08
    176	1.176176e+02	-1.00000e+00,	2.956053e-08
    177	1.177177e+02	-1.00000e+00,	2.958569e-08
    178	1.178178e+02	-1.00000e+00,	2.961085e-08
    179	1.179179e+02	-1.00000e+00,	2.963601e-08
    180	1.180180e+02	-1.00000e+00,	2.966116e-08
    181	1.181181e+02	-1.00000e+00,	2.968632e-08
    182	1.182182e+02	-1.00000e+00,	2.971148e-08
    183	1.183183e+02	-1.00000e+00,	2.973664e-08
    184	1.184184e+02	-1.00000e+00,	2.976179e-08
    185	1.185185e+02	-1.00000e+00,	2.978695e-08
    186	1.186186e+02	-1.00000e+00,	2.981211e-08
    187	1.187187e+02	-1.00000e+00,	2.983727e-08
    188	1.188188e+02	-1.00000e+00,	2.986243e-08
    189	1.189189e+02	-1.00000e+00,	2.988758e-08
    190	1.190190e+02	-1.00000e+00,	2.991274e-08
    191	1.191191e+02	-1.00000e+00,	2.993790e-08
    192	1.192192e+02	-1.00000e+00,	2.996306e-08
    193	1.193193e+02	-1.00000e+00,	2.998822e-08
    194	1.194194e+02	-1.00000e+00,	3.001337e-08
    195	1.195195e+02	-1.00000e+00,	3.003853e-08
    196	1.196196e+02	-1.00000e+00,	3.006369e-08
    197	1.197197e+02	-1.00000e+00,	3.008885e-08
    198	1.198198e+02	-1.00000e+00,	3.011401e-08
    199	1.199199e+02	-1.00000e+00,	3.013916e-08
    200	1.200200e+02	-1.00000e+00,	3.016432e-08
    201	1.201201e+02	-1.00000e+00,	3.018948e-08
    202	1.202202e+02	-1.00000e+00,	3.021464e-08
    203	1.203203e+02	-1.00000e+00,	3.023979e-08
    204	1.204204e+02	-1.00000e+00,	3.026495e-08
    205	1.205205e+02	-1.00000e+00,	3.029011e-08
    206	1.206206e+02	-1.00000e+00,	3.031527e-08
    207	1.207207e+02	-1.00000e+00,	3.034043e-08
    208	1.208208e+02	-1.00000e+00,	3.036558e-08
    209	1.209209e+02	-1.00000e+00,	3.039074e-08
    210	1.210210e+02	-1.00000e+00,	3.041590e-08
    211	1.211211e+02	-1.00000e+00,	3.044106e-08
    212	1.212212e+02	-1.00000e+00,	3.046622e-08
    213	1.213213e+02	-1.00000e+00,	3.049137e-08
    214	1.214214e+02	-1.00000e+00,	3.051653e-08
    215	1.215215e+02	-1.00000e+00,	3.054169e-08
    216	1.216216e+02	-1.00000e+00,	3.056685e-08
    217	1.217217e+02	-1.00000e+00,	3.059201e-08
    218	1.218218e+02	-1.00000e+00,	3.061716e-08
    219	1.219219e+02	-1.00000e+00,	3.064232e-08
    220	1.220220e+02	-1.00000e+00,	3.066748e-08
    221	1.221221e+02	-1.00000e+00,	3.069264e-08
    222	1.222222e+02	-1.00000e+00,	3.071779e-08
    223	1.223223e+02	-1.00000e+00,	3.074295e-08
    224	1.224224e+02	-1.00000e+00,	3.076811e-08
    225	1.225225e+02	-1.00000e+00,	3.079327e-08
    226	1.226226e+02	-1.00000e+00,	3.081843e-08
    227	1.227227e+02	-1.00000e+00,	3.084358e-08
    228	1.228228e+02	-1.00000e+00,	3.086874e-08
    Index   frequency       s11
    229	1.229229e+02	-1.00000e+00,	3.089390e-08
    230	1.230230e+02	-1.00000e+00,	3.091906e-08
    231	1.231231e+02	-1.00000e+00,	3.094422e-08
    232	1.232232e+02	-1.00000e+00,	3.096937e-08
    233	1.233233e+02	-1.00000e+00,	3.099453e-08
    234	1.234234e+02	-1.00000e+00,	3.101969e-08
    235	1.235235e+02	-1.00000e+00,	3.104485e-08
    236	1.236236e+02	-1.00000e+00,	3.107001e-08
    237	1.237237e+02	-1.00000e+00,	3.109516e-08
    238	1.238238e+02	-1.00000e+00,	3.112032e-08
    239	1.239239e+02	-1.00000e+00,	3.114548e-08
    240	1.240240e+02	-1.00000e+00,	3.117064e-08
    241	1.241241e+02	-1.00000e+00,	3.119579e-08
    242	1.242242e+02	-1.00000e+00,	3.122095e-08
    243	1.243243e+02	-1.00000e+00,	3.124611e-08
    244	1.244244e+02	-1.00000e+00,	3.127127e-08
    245	1.245245e+02	-1.00000e+00,	3.129643e-08
    246	1.246246e+02	-1.00000e+00,	3.132158e-08
    247	1.247247e+02	-1.00000e+00,	3.134674e-08
    248	1.248248e+02	-1.00000e+00,	3.137190e-08
    249	1.249249e+02	-1.00000e+00,	3.139706e-08
    250	1.250250e+02	-1.00000e+00,	3.142222e-08
    251	1.251251e+02	-1.00000e+00,	3.144737e-08
    252	1.252252e+02	-1.00000e+00,	3.147253e-08
    253	1.253253e+02	-1.00000e+00,	3.149769e-08
    254	1.254254e+02	-1.00000e+00,	3.152285e-08
    255	1.255255e+02	-1.00000e+00,	3.154801e-08
    256	1.256256e+02	-1.00000e+00,	3.157316e-08
    257	1.257257e+02	-1.00000e+00,	3.159832e-08
    258	1.258258e+02	-1.00000e+00,	3.162348e-08
    259	1.259259e+02	-1.00000e+00,	3.164864e-08
    260	1.260260e+02	-1.00000e+00,	3.167380e-08
    261	1.261261e+02	-1.00000e+00,	3.169895e-08
    262	1.262262e+02	-1.00000e+00,	3.172411e-08
    263	1.263263e+02	-1.00000e+00,	3.174927e-08
    264	1.264264e+02	-1.00000e+00,	3.177443e-08
    265	1.265265e+02	-1.00000e+00,	3.179958e-08
    266	1.266266e+02	-1.00000e+00,	3.182474e-08
    267	1.267267e+02	-1.00000e+00,	3.184990e-08
    268	1.268268e+02	-1.00000e+00,	3.187506e-08
    269	1.269269e+02	-1.00000e+00,	3.190022e-08
    270	1.270270e+02	-1.00000e+00,	3.192537e-08
    271	1.271271e+02	-1.00000e+00,	3.195053e-08
    272	1.272272e+02	-1.00000e+00,	3.197569e-08
    273	1.273273e+02	-1.00000e+00,	3.200085e-08
    274	1.274274e+02	-1.00000e+00,	3.202601e-08
    275	1.275275e+02	-1.00000e+00,	3.205116e-08
    276	1.276276e+02	-1.00000e+00,	3.207632e-08
    277	1.277277e+02	-1.00000e+00,	3.210148e-08
    278	1.278278e+02	-1.00000e+00,	3.212664e-08
    279	1.279279e+02	-1.00000e+00,	3.215180e-08
    280	1.280280e+02	-1.00000e+00,	3.217695e-08
    281	1.281281e+02	-1.00000e+00,	3.220211e-08
    282	1.282282e+02	-1.00000e+00,	3.222727e-08
    283	1.283283e+02	-1.00000e+00,	3.225243e-08
    284	1.284284e+02	-1.00000e+00,	3.227758e-08
    285	1.285285e+02	-1.00000e+00,	3.230274e-08
    286	1.286286e+02	-1.00000e+00,	3.232790e-08
    Index   frequency       s11
    287	1.287287e+02	-1.00000e+00,	3.235306e-08
    288	1.288288e+02	-1.00000e+00,	3.237822e-08
    289	1.289289e+02	-1.00000e+00,	3.240337e-08
    290	1.290290e+02	-1.00000e+00,	3.242853e-08
    291	1.291291e+02	-1.00000e+00,	3.245369e-08
    292	1.292292e+02	-1.00000e+00,	3.247885e-08
    293	1.293293e+02	-1.00000e+00,	3.250401e-08
    294	1.294294e+02	-1.00000e+00,	3.252916e-08
    295	1.295295e+02	-1.00000e+00,	3.255432e-08
    296	1.296296e+02	-1.00000e+00,	3.257948e-08
    297	1.297297e+02	-1.00000e+00,	3.260464e-08
    298	1.298298e+02	-1.00000e+00,	3.262980e-08
    299	1.299299e+02	-1.00000e+00,	3.265495e-08
    300	1.300300e+02	-1.00000e+00,	3.268011e-08
    301	1.301301e+02	-1.00000e+00,	3.270527e-08
    302	1.302302e+02	-1.00000e+00,	3.273043e-08
    303	1.303303e+02	-1.00000e+00,	3.275558e-08
    304	1.304304e+02	-1.00000e+00,	3.278074e-08
    305	1.305305e+02	-1.00000e+00,	3.280590e-08
    306	1.306306e+02	-1.00000e+00,	3.283106e-08
    307	1.307307e+02	-1.00000e+00,	3.285622e-08
    308	1.308308e+02	-1.00000e+00,	3.288137e-08
    309	1.309309e+02	-1.00000e+00,	3.290653e-08
    310	1.310310e+02	-1.00000e+00,	3.293169e-08
    311	1.311311e+02	-1.00000e+00,	3.295685e-08
    312	1.312312e+02	-1.00000e+00,	3.298201e-08
    313	1.313313e+02	-1.00000e+00,	3.300716e-08
    314	1.314314e+02	-1.00000e+00,	3.303232e-08
    315	1.315315e+02	-1.00000e+00,	3.305748e-08
    316	1.316316e+02	-1.00000e+00,	3.308264e-08
    317	1.317317e+02	-1.00000e+00,	3.310780e-08
    318	1.318318e+02	-1.00000e+00,	3.313295e-08
    319	1.319319e+02	-1.00000e+00,	3.315811e-08
    320	1.320320e+02	-1.00000e+00,	3.318327e-08
    321	1.321321e+02	-1.00000e+00,	3.320843e-08
    322	1.322322e+02	-1.00000e+00,	3.323358e-08
    323	1.323323e+02	-1.00000e+00,	3.325874e-08
    324	1.324324e+02	-1.00000e+00,	3.328390e-08
    325	1.325325e+02	-1.00000e+00,	3.330906e-08
    326	1.326326e+02	-1.00000e+00,	3.333422e-08
    327	1.327327e+02	-1.00000e+00,	3.335937e-08
    328	1.328328e+02	-1.00000e+00,	3.338453e-08
    329	1.329329e+02	-1.00000e+00,	3.340969e-08
    330	1.330330e+02	-1.00000e+00,	3.343485e-08
    331	1.331331e+02	-1.00000e+00,	3.346001e-08
    332	1.332332e+02	-1.00000e+00,	3.348516e-08
    333	1.333333e+02	-1.00000e+00,	3.351032e-08
    334	1.334334e+02	-1.00000e+00,	3.353548e-08
    335	1.335335e+02	-1.00000e+00,	3.356064e-08
    336	1.336336e+02	-1.00000e+00,	3.358580e-08
    337	1.337337e+02	-1.00000e+00,	3.361095e-08
    338	1.338338e+02	-1.00000e+00,	3.363611e-08
    339	1.339339e+02	-1.00000e+00,	3.366127e-08
    340	1.340340e+02	-1.00000e+00,	3.368643e-08
    341	1.341341e+02	-1.00000e+00,	3.371158e-08
    342	1.342342e+02	-1.00000e+00,	3.373674e-08
    343	1.343343e+02	-1.00000e+00,	3.376190e-08
    344	1.344344e+02	-1.00000e+00,	3.378706e-08
    Index   frequency       s11
    345	1.345345e+02	-1.00000e+00,	3.381222e-08
    346	1.346346e+02	-1.00000e+00,	3.383737e-08
    347	1.347347e+02	-1.00000e+00,	3.386253e-08
    348	1.348348e+02	-1.00000e+00,	3.388769e-08
    349	1.349349e+02	-1.00000e+00,	3.391285e-08
    350	1.350350e+02	-1.00000e+00,	3.393801e-08
    351	1.351351e+02	-1.00000e+00,	3.396316e-08
    352	1.352352e+02	-1.00000e+00,	3.398832e-08
    353	1.353353e+02	-1.00000e+00,	3.401348e-08
    354	1.354354e+02	-1.00000e+00,	3.403864e-08
    355	1.355355e+02	-1.00000e+00,	3.406380e-08
    356	1.356356e+02	-1.00000e+00,	3.408895e-08
    357	1.357357e+02	-1.00000e+00,	3.411411e-08
    358	1.358358e+02	-1.00000e+00,	3.413927e-08
    359	1.359359e+02	-1.00000e+00,	3.416443e-08
    360	1.360360e+02	-1.00000e+00,	3.418958e-08
    361	1.361361e+02	-1.00000e+00,	3.421474e-08
    362	1.362362e+02	-1.00000e+00,	3.423990e-08
    363	1.363363e+02	-1.00000e+00,	3.426506e-08
    364	1.364364e+02	-1.00000e+00,	3.429022e-08
    365	1.365365e+02	-1.00000e+00,	3.431537e-08
    366	1.366366e+02	-1.00000e+00,	3.434053e-08
    367	1.367367e+02	-1.00000e+00,	3.436569e-08
    368	1.368368e+02	-1.00000e+00,	3.439085e-08
    369	1.369369e+02	-1.00000e+00,	3.441601e-08
    370	1.370370e+02	-1.00000e+00,	3.444116e-08
    371	1.371371e+02	-1.00000e+00,	3.446632e-08
    372	1.372372e+02	-1.00000e+00,	3.449148e-08
    373	1.373373e+02	-1.00000e+00,	3.451664e-08
    374	1.374374e+02	-1.00000e+00,	3.454180e-08
    375	1.375375e+02	-1.00000e+00,	3.456695e-08
    376	1.376376e+02	-1.00000e+00,	3.459211e-08
    377	1.377377e+02	-1.00000e+00,	3.461727e-08
    378	1.378378e+02	-1.00000e+00,	3.464243e-08
    379	1.379379e+02	-1.00000e+00,	3.466758e-08
    380	1.380380e+02	-1.00000e+00,	3.469274e-08
    381	1.381381e+02	-1.00000e+00,	3.471790e-08
    382	1.382382e+02	-1.00000e+00,	3.474306e-08
    383	1.383383e+02	-1.00000e+00,	3.476822e-08
    384	1.384384e+02	-1.00000e+00,	3.479337e-08
    385	1.385385e+02	-1.00000e+00,	3.481853e-08
    386	1.386386e+02	-1.00000e+00,	3.484369e-08
    387	1.387387e+02	-1.00000e+00,	3.486885e-08
    388	1.388388e+02	-1.00000e+00,	3.489401e-08
    389	1.389389e+02	-1.00000e+00,	3.491916e-08
    390	1.390390e+02	-1.00000e+00,	3.494432e-08
    391	1.391391e+02	-1.00000e+00,	3.496948e-08
    392	1.392392e+02	-1.00000e+00,	3.499464e-08
    393	1.393393e+02	-1.00000e+00,	3.501980e-08
    394	1.394394e+02	-1.00000e+00,	3.504495e-08
    395	1.395395e+02	-1.00000e+00,	3.507011e-08
    396	1.396396e+02	-1.00000e+00,	3.509527e-08
    397	1.397397e+02	-1.00000e+00,	3.512043e-08
    398	1.398398e+02	-1.00000e+00,	3.514559e-08
    399	1.399399e+02	-1.00000e+00,	3.517074e-08
    400	1.400400e+02	-1.00000e+00,	3.519590e-08
    401	1.401401e+02	-1.00000e+00,	3.522106e-08
    402	1.402402e+02	-1.00000e+00,	3.524622e-08
    Index   frequency       s11
    403	1.403403e+02	-1.00000e+00,	3.527137e-08
    404	1.404404e+02	-1.00000e+00,	3.529653e-08
    405	1.405405e+02	-1.00000e+00,	3.532169e-08
    406	1.406406e+02	-1.00000e+00,	3.534685e-08
    407	1.407407e+02	-1.00000e+00,	3.537201e-08
    408	1.408408e+02	-1.00000e+00,	3.539716e-08
    409	1.409409e+02	-1.00000e+00,	3.542232e-08
    410	1.410410e+02	-1.00000e+00,	3.544748e-08
    411	1.411411e+02	-1.00000e+00,	3.547264e-08
    412	1.412412e+02	-1.00000e+00,	3.549780e-08
    413	1.413413e+02	-1.00000e+00,	3.552295e-08
    414	1.414414e+02	-1.00000e+00,	3.554811e-08
    415	1.415415e+02	-1.00000e+00,	3.557327e-08
    416	1.416416e+02	-1.00000e+00,	3.559843e-08
    417	1.417417e+02	-1.00000e+00,	3.562359e-08
    418	1.418418e+02	-1.00000e+00,	3.564874e-08
    419	1.419419e+02	-1.00000e+00,	3.567390e-08
    420	1.420420e+02	-1.00000e+00,	3.569906e-08
    421	1.421421e+02	-1.00000e+00,	3.572422e-08
    422	1.422422e+02	-1.00000e+00,	3.574937e-08
    423	1.423423e+02	-1.00000e+00,	3.577453e-08
    424	1.424424e+02	-1.00000e+00,	3.579969e-08
    425	1.425425e+02	-1.00000e+00,	3.582485e-08
    426	1.426426e+02	-1.00000e+00,	3.585001e-08
    427	1.427427e+02	-1.00000e+00,	3.587516e-08
    428	1.428428e+02	-1.00000e+00,	3.590032e-08
    429	1.429429e+02	-1.00000e+00,	3.592548e-08
    430	1.430430e+02	-1.00000e+00,	3.595064e-08
    431	1.431431e+02	-1.00000e+00,	3.597580e-08
    432	1.432432e+02	-1.00000e+00,	3.600095e-08
    433	1.433433e+02	-1.00000e+00,	3.602611e-08
    434	1.434434e+02	-1.00000e+00,	3.605127e-08
    435	1.435435e+02	-1.00000e+00,	3.607643e-08
    436	1.436436e+02	-1.00000e+00,	3.610159e-08
    437	1.437437e+02	-1.00000e+00,	3.612674e-08
    438	1.438438e+02	-1.00000e+00,	3.615190e-08
    439	1.439439e+02	-1.00000e+00,	3.617706e-08
    440	1.440440e+02	-1.00000e+00,	3.620222e-08
    441	1.441441e+02	-1.00000e+00,	3.622737e-08
    442	1.442442e+02	-1.00000e+00,	3.625253e-08
    443	1.443443e+02	-1.00000e+00,	3.627769e-08
    444	1.444444e+02	-1.00000e+00,	3.630285e-08
    445	1.445445e+02	-1.00000e+00,	3.632801e-08
    446	1.446446e+02	-1.00000e+00,	3.635316e-08
    447	1.447447e+02	-1.00000e+00,	3.637832e-08
    448	1.448448e+02	-1.00000e+00,	3.640348e-08
    449	1.449449e+02	-1.00000e+00,	3.642864e-08
    450	1.450450e+02	-1.00000e+00,	3.645380e-08
    451	1.451451e+02	-1.00000e+00,	3.647895e-08
    452	1.452452e+02	-1.00000e+00,	3.650411e-08
    453	1.453453e+02	-1.00000e+00,	3.652927e-08
    454	1.454454e+02	-1.00000e+00,	3.655443e-08
    455	1.455455e+02	-1.00000e+00,	3.657959e-08
    456	1.456456e+02	-1.00000e+00,	3.660474e-08
    457	1.457457e+02	-1.00000e+00,	3.662990e-08
    458	1.458458e+02	-1.00000e+00,	3.665506e-08
    459	1.459459e+02	-1.00000e+00,	3.668022e-08
    460	1.460460e+02	-1.00000e+00,	3.670537e-08
    Index   frequency       s11
    461	1.461461e+02	-1.00000e+00,	3.673053e-08
    462	1.462462e+02	-1.00000e+00,	3.675569e-08
    463	1.463463e+02	-1.00000e+00,	3.678085e-08
    464	1.464464e+02	-1.00000e+00,	3.680601e-08
    465	1.465465e+02	-1.00000e+00,	3.683116e-08
    466	1.466466e+02	-1.00000e+00,	3.685632e-08
    467	1.467467e+02	-1.00000e+00,	3.688148e-08
    468	1.468468e+02	-1.00000e+00,	3.690664e-08
    469	1.469469e+02	-1.00000e+00,	3.693180e-08
    470	1.470470e+02	-1.00000e+00,	3.695695e-08
    471	1.471471e+02	-1.00000e+00,	3.698211e-08
    472	1.472472e+02	-1.00000e+00,	3.700727e-08
    473	1.473473e+02	-1.00000e+00,	3.703243e-08
    474	1.474474e+02	-1.00000e+00,	3.705759e-08
    475	1.475475e+02	-1.00000e+00,	3.708274e-08
    476	1.476476e+02	-1.00000e+00,	3.710790e-08
    477	1.477477e+02	-1.00000e+00,	3.713306e-08
    478	1.478478e+02	-1.00000e+00,	3.715822e-08
    479	1.479479e+02	-1.00000e+00,	3.718337e-08
    480	1.480480e+02	-1.00000e+00,	3.720853e-08
    481	1.481481e+02	-1.00000e+00,	3.723369e-08
    482	1.482482e+02	-1.00000e+00,	3.725885e-08
    483	1.483483e+02	-1.00000e+00,	3.728401e-08
    484	1.484484e+02	-1.00000e+00,	3.730916e-08
    485	1.485485e+02	-1.00000e+00,	3.733432e-08
    486	1.486486e+02	-1.00000e+00,	3.735948e-08
    487	1.487487e+02	-1.00000e+00,	3.738464e-08
    488	1.488488e+02	-1.00000e+00,	3.740980e-08
    489	1.489489e+02	-1.00000e+00,	3.743495e-08
    490	1.490490e+02	-1.00000e+00,	3.746011e-08
    491	1.491491e+02	-1.00000e+00,	3.748527e-08
    492	1.492492e+02	-1.00000e+00,	3.751043e-08
    493	1.493493e+02	-1.00000e+00,	3.753559e-08
    494	1.494494e+02	-1.00000e+00,	3.756074e-08
    495	1.495495e+02	-1.00000e+00,	3.758590e-08
    496	1.496496e+02	-1.00000e+00,	3.761106e-08
    497	1.497497e+02	-1.00000e+00,	3.763622e-08
    498	1.498498e+02	-1.00000e+00,	3.766137e-08
    499	1.499499e+02	-1.00000e+00,	3.768653e-08
    500	1.500501e+02	-1.00000e+00,	3.771169e-08
    501	1.501502e+02	-1.00000e+00,	3.773685e-08
    502	1.502503e+02	-1.00000e+00,	3.776201e-08
    503	1.503504e+02	-1.00000e+00,	3.778716e-08
    504	1.504505e+02	-1.00000e+00,	3.781232e-08
    505	1.505506e+02	-1.00000e+00,	3.783748e-08
    506	1.506507e+02	-1.00000e+00,	3.786264e-08
    507	1.507508e+02	-1.00000e+00,	3.788780e-08
    508	1.508509e+02	-1.00000e+00,	3.791295e-08
    509	1.509510e+02	-1.00000e+00,	3.793811e-08
    510	1.510511e+02	-1.00000e+00,	3.796327e-08
    511	1.511512e+02	-1.00000e+00,	3.798843e-08
    512	1.512513e+02	-1.00000e+00,	3.801359e-08
    513	1.513514e+02	-1.00000e+00,	3.803874e-08
    514	1.514515e+02	-1.00000e+00,	3.806390e-08
    515	1.515516e+02	-1.00000e+00,	3.808906e-08
    516	1.516517e+02	-1.00000e+00,	3.811422e-08
    517	1.517518e+02	-1.00000e+00,	3.813938e-08
    518	1.518519e+02	-1.00000e+00,	3.816453e-08
    Index   frequency       s11
    519	1.519520e+02	-1.00000e+00,	3.818969e-08
    520	1.520521e+02	-1.00000e+00,	3.821485e-08
    521	1.521522e+02	-1.00000e+00,	3.824001e-08
    522	1.522523e+02	-1.00000e+00,	3.826516e-08
    523	1.523524e+02	-1.00000e+00,	3.829032e-08
    524	1.524525e+02	-1.00000e+00,	3.831548e-08
    525	1.525526e+02	-1.00000e+00,	3.834064e-08
    526	1.526527e+02	-1.00000e+00,	3.836580e-08
    527	1.527528e+02	-1.00000e+00,	3.839095e-08
    528	1.528529e+02	-1.00000e+00,	3.841611e-08
    529	1.529530e+02	-1.00000e+00,	3.844127e-08
    530	1.530531e+02	-1.00000e+00,	3.846643e-08
    531	1.531532e+02	-1.00000e+00,	3.849159e-08
    532	1.532533e+02	-1.00000e+00,	3.851674e-08
    533	1.533534e+02	-1.00000e+00,	3.854190e-08
    534	1.534535e+02	-1.00000e+00,	3.856706e-08
    535	1.535536e+02	-1.00000e+00,	3.859222e-08
    536	1.536537e+02	-1.00000e+00,	3.861738e-08
    537	1.537538e+02	-1.00000e+00,	3.864253e-08
    538	1.538539e+02	-1.00000e+00,	3.866769e-08
    539	1.539540e+02	-1.00000e+00,	3.869285e-08
    540	1.540541e+02	-1.00000e+00,	3.871801e-08
    541	1.541542e+02	-1.00000e+00,	3.874316e-08
    542	1.542543e+02	-1.00000e+00,	3.876832e-08
    543	1.543544e+02	-1.00000e+00,	3.879348e-08
    544	1.544545e+02	-1.00000e+00,	3.881864e-08
    545	1.545546e+02	-1.00000e+00,	3.884380e-08
    546	1.546547e+02	-1.00000e+00,	3.886895e-08
    547	1.547548e+02	-1.00000e+00,	3.889411e-08
    548	1.548549e+02	-1.00000e+00,	3.891927e-08
    549	1.549550e+02	-1.00000e+00,	3.894443e-08
    550	1.550551e+02	-1.00000e+00,	3.896959e-08
    551	1.551552e+02	-1.00000e+00,	3.899474e-08
    552	1.552553e+02	-1.00000e+00,	3.901990e-08
    553	1.553554e+02	-1.00000e+00,	3.904506e-08
    554	1.554555e+02	-1.00000e+00,	3.907022e-08
    555	1.555556e+02	-1.00000e+00,	3.909538e-08
    556	1.556557e+02	-1.00000e+00,	3.912053e-08
    557	1.557558e+02	-1.00000e+00,	3.914569e-08
    558	1.558559e+02	-1.00000e+00,	3.917085e-08
    559	1.559560e+02	-1.00000e+00,	3.919601e-08
    560	1.560561e+02	-1.00000e+00,	3.922116e-08
    561	1.561562e+02	-1.00000e+00,	3.924632e-08
    562	1.562563e+02	-1.00000e+00,	3.927148e-08
    563	1.563564e+02	-1.00000e+00,	3.929664e-08
    564	1.564565e+02	-1.00000e+00,	3.932180e-08
    565	1.565566e+02	-1.00000e+00,	3.934695e-08
    566	1.566567e+02	-1.00000e+00,	3.937211e-08
    567	1.567568e+02	-1.00000e+00,	3.939727e-08
    568	1.568569e+02	-1.00000e+00,	3.942243e-08
    569	1.569570e+02	-1.00000e+00,	3.944759e-08
    570	1.570571e+02	-1.00000e+00,	3.947274e-08
    571	1.571572e+02	-1.00000e+00,	3.949790e-08
    572	1.572573e+02	-1.00000e+00,	3.952306e-08
    573	1.573574e+02	-1.00000e+00,	3.954822e-08
    574	1.574575e+02	-1.00000e+00,	3.957338e-08
    575	1.575576e+02	-1.00000e+00,	3.959853e-08
    576	1.576577e+02	-1.00000e+00,	3.962369e-08
    Index   frequency       s11
    577	1.577578e+02	-1.00000e+00,	3.964885e-08
    578	1.578579e+02	-1.00000e+00,	3.967401e-08
    579	1.579580e+02	-1.00000e+00,	3.969916e-08
    580	1.580581e+02	-1.00000e+00,	3.972432e-08
    581	1.581582e+02	-1.00000e+00,	3.974948e-08
    582	1.582583e+02	-1.00000e+00,	3.977464e-08
    583	1.583584e+02	-1.00000e+00,	3.979980e-08
    584	1.584585e+02	-1.00000e+00,	3.982495e-08
    585	1.585586e+02	-1.00000e+00,	3.985011e-08
    586	1.586587e+02	-1.00000e+00,	3.987527e-08
    587	1.587588e+02	-1.00000e+00,	3.990043e-08
    588	1.588589e+02	-1.00000e+00,	3.992559e-08
    589	1.589590e+02	-1.00000e+00,	3.995074e-08
    590	1.590591e+02	-1.00000e+00,	3.997590e-08
    591	1.591592e+02	-1.00000e+00,	4.000106e-08
    592	1.592593e+02	-1.00000e+00,	4.002622e-08
    593	1.593594e+02	-1.00000e+00,	4.005138e-08
    594	1.594595e+02	-1.00000e+00,	4.007653e-08
    595	1.595596e+02	-1.00000e+00,	4.010169e-08
    596	1.596597e+02	-1.00000e+00,	4.012685e-08
    597	1.597598e+02	-1.00000e+00,	4.015201e-08
    598	1.598599e+02	-1.00000e+00,	4.017716e-08
    599	1.599600e+02	-1.00000e+00,	4.020232e-08
    600	1.600601e+02	-1.00000e+00,	4.022748e-08
    601	1.601602e+02	-1.00000e+00,	4.025264e-08
    602	1.602603e+02	-1.00000e+00,	4.027780e-08
    603	1.603604e+02	-1.00000e+00,	4.030295e-08
    604	1.604605e+02	-1.00000e+00,	4.032811e-08
    605	1.605606e+02	-1.00000e+00,	4.035327e-08
    606	1.606607e+02	-1.00000e+00,	4.037843e-08
    607	1.607608e+02	-1.00000e+00,	4.040359e-08
    608	1.608609e+02	-1.00000e+00,	4.042874e-08
    609	1.609610e+02	-1.00000e+00,	4.045390e-08
    610	1.610611e+02	-1.00000e+00,	4.047906e-08
    611	1.611612e+02	-1.00000e+00,	4.050422e-08
    612	1.612613e+02	-1.00000e+00,	4.052938e-08
    613	1.613614e+02	-1.00000e+00,	4.055453e-08
    614	1.614615e+02	-1.00000e+00,	4.057969e-08
    615	1.615616e+02	-1.00000e+00,	4.060485e-08
    616	1.616617e+02	-1.00000e+00,	4.063001e-08
    617	1.617618e+02	-1.00000e+00,	4.065516e-08
    618	1.618619e+02	-1.00000e+00,	4.068032e-08
    619	1.619620e+02	-1.00000e+00,	4.070548e-08
    620	1.620621e+02	-1.00000e+00,	4.073064e-08
    621	1.621622e+02	-1.00000e+00,	4.075580e-08
    622	1.622623e+02	-1.00000e+00,	4.078095e-08
    623	1.623624e+02	-1.00000e+00,	4.080611e-08
    624	1.624625e+02	-1.00000e+00,	4.083127e-08
    625	1.625626e+02	-1.00000e+00,	4.085643e-08
    626	1.626627e+02	-1.00000e+00,	4.088159e-08
    627	1.627628e+02	-1.00000e+00,	4.090674e-08
    628	1.628629e+02	-1.00000e+00,	4.093190e-08
    629	1.629630e+02	-1.00000e+00,	4.095706e-08
    630	1.630631e+02	-1.00000e+00,	4.098222e-08
    631	1.631632e+02	-1.00000e+00,	4.100738e-08
    632	1.632633e+02	-1.00000e+00,	4.103253e-08
    633	1.633634e+02	-1.00000e+00,	4.105769e-08
    634	1.634635e+02	-1.00000e+00,	4.108285e-08
    Index   frequency       s11
    635	1.635636e+02	-1.00000e+00,	4.110801e-08
    636	1.636637e+02	-1.00000e+00,	4.113317e-08
    637	1.637638e+02	-1.00000e+00,	4.115832e-08
    638	1.638639e+02	-1.00000e+00,	4.118348e-08
    639	1.639640e+02	-1.00000e+00,	4.120864e-08
    640	1.640641e+02	-1.00000e+00,	4.123380e-08
    641	1.641642e+02	-1.00000e+00,	4.125895e-08
    642	1.642643e+02	-1.00000e+00,	4.128411e-08
    643	1.643644e+02	-1.00000e+00,	4.130927e-08
    644	1.644645e+02	-1.00000e+00,	4.133443e-08
    645	1.645646e+02	-1.00000e+00,	4.135959e-08
    646	1.646647e+02	-1.00000e+00,	4.138474e-08
    647	1.647648e+02	-1.00000e+00,	4.140990e-08
    648	1.648649e+02	-1.00000e+00,	4.143506e-08
    649	1.649650e+02	-1.00000e+00,	4.146022e-08
    650	1.650651e+02	-1.00000e+00,	4.148538e-08
    651	1.651652e+02	-1.00000e+00,	4.151053e-08
    652	1.652653e+02	-1.00000e+00,	4.153569e-08
    653	1.653654e+02	-1.00000e+00,	4.156085e-08
    654	1.654655e+02	-1.00000e+00,	4.158601e-08
    655	1.655656e+02	-1.00000e+00,	4.161117e-08
    656	1.656657e+02	-1.00000e+00,	4.163632e-08
    657	1.657658e+02	-1.00000e+00,	4.166148e-08
    658	1.658659e+02	-1.00000e+00,	4.168664e-08
    659	1.659660e+02	-1.00000e+00,	4.171180e-08
    660	1.660661e+02	-1.00000e+00,	4.173695e-08
    661	1.661662e+02	-1.00000e+00,	4.176211e-08
    662	1.662663e+02	-1.00000e+00,	4.178727e-08
    663	1.663664e+02	-1.00000e+00,	4.181243e-08
    664	1.664665e+02	-1.00000e+00,	4.183759e-08
    665	1.665666e+02	-1.00000e+00,	4.186274e-08
    666	1.666667e+02	-1.00000e+00,	4.188790e-08
    667	1.667668e+02	-1.00000e+00,	4.191306e-08
    668	1.668669e+02	-1.00000e+00,	4.193822e-08
    669	1.669670e+02	-1.00000e+00,	4.196338e-08
    670	1.670671e+02	-1.00000e+00,	4.198853e-08
    671	1.671672e+02	-1.00000e+00,	4.201369e-08
    672	1.672673e+02	-1.00000e+00,	4.203885e-08
    673	1.673674e+02	-1.00000e+00,	4.206401e-08
    674	1.674675e+02	-1.00000e+00,	4.208917e-08
    675	1.675676e+02	-1.00000e+00,	4.211432e-08
    676	1.676677e+02	-1.00000e+00,	4.213948e-08
    677	1.677678e+02	-1.00000e+00,	4.216464e-08
    678	1.678679e+02	-1.00000e+00,	4.218980e-08
    679	1.679680e+02	-1.00000e+00,	4.221495e-08
    680	1.680681e+02	-1.00000e+00,	4.224011e-08
    681	1.681682e+02	-1.00000e+00,	4.226527e-08
    682	1.682683e+02	-1.00000e+00,	4.229043e-08
    683	1.683684e+02	-1.00000e+00,	4.231559e-08
    684	1.684685e+02	-1.00000e+00,	4.234074e-08
    685	1.685686e+02	-1.00000e+00,	4.236590e-08
    686	1.686687e+02	-1.00000e+00,	4.239106e-08
    687	1.687688e+02	-1.00000e+00,	4.241622e-08
    688	1.688689e+02	-1.00000e+00,	4.244138e-08
    689	1.689690e+02	-1.00000e+00,	4.246653e-08
    690	1.690691e+02	-1.00000e+00,	4.249169e-08
    691	1.691692e+02	-1.00000e+00,	4.251685e-08
    692	1.692693e+02	-1.00000e+00,	4.254201e-08
    Index   frequency       s11
    693	1.693694e+02	-1.00000e+00,	4.256717e-08
    694	1.694695e+02	-1.00000e+00,	4.259232e-08
    695	1.695696e+02	-1.00000e+00,	4.261748e-08
    696	1.696697e+02	-1.00000e+00,	4.264264e-08
    697	1.697698e+02	-1.00000e+00,	4.266780e-08
    698	1.698699e+02	-1.00000e+00,	4.269295e-08
    699	1.699700e+02	-1.00000e+00,	4.271811e-08
    700	1.700701e+02	-1.00000e+00,	4.274327e-08
    701	1.701702e+02	-1.00000e+00,	4.276843e-08
    702	1.702703e+02	-1.00000e+00,	4.279359e-08
    703	1.703704e+02	-1.00000e+00,	4.281874e-08
    704	1.704705e+02	-1.00000e+00,	4.284390e-08
    705	1.705706e+02	-1.00000e+00,	4.286906e-08
    706	1.706707e+02	-1.00000e+00,	4.289422e-08
    707	1.707708e+02	-1.00000e+00,	4.291938e-08
    708	1.708709e+02	-1.00000e+00,	4.294453e-08
    709	1.709710e+02	-1.00000e+00,	4.296969e-08
    710	1.710711e+02	-1.00000e+00,	4.299485e-08
    711	1.711712e+02	-1.00000e+00,	4.302001e-08
    712	1.712713e+02	-1.00000e+00,	4.304517e-08
    713	1.713714e+02	-1.00000e+00,	4.307032e-08
    714	1.714715e+02	-1.00000e+00,	4.309548e-08
    715	1.715716e+02	-1.00000e+00,	4.312064e-08
    716	1.716717e+02	-1.00000e+00,	4.314580e-08
    717	1.717718e+02	-1.00000e+00,	4.317095e-08
    718	1.718719e+02	-1.00000e+00,	4.319611e-08
    719	1.719720e+02	-1.00000e+00,	4.322127e-08
    720	1.720721e+02	-1.00000e+00,	4.324643e-08
    721	1.721722e+02	-1.00000e+00,	4.327159e-08
    722	1.722723e+02	-1.00000e+00,	4.329674e-08
    723	1.723724e+02	-1.00000e+00,	4.332190e-08
    724	1.724725e+02	-1.00000e+00,	4.334706e-08
    725	1.725726e+02	-1.00000e+00,	4.337222e-08
    726	1.726727e+02	-1.00000e+00,	4.339738e-08
    727	1.727728e+02	-1.00000e+00,	4.342253e-08
    728	1.728729e+02	-1.00000e+00,	4.344769e-08
    729	1.729730e+02	-1.00000e+00,	4.347285e-08
    730	1.730731e+02	-1.00000e+00,	4.349801e-08
    731	1.731732e+02	-1.00000e+00,	4.352317e-08
    732	1.732733e+02	-1.00000e+00,	4.354832e-08
    733	1.733734e+02	-1.00000e+00,	4.357348e-08
    734	1.734735e+02	-1.00000e+00,	4.359864e-08
    735	1.735736e+02	-1.00000e+00,	4.362380e-08
    736	1.736737e+02	-1.00000e+00,	4.364895e-08
    737	1.737738e+02	-1.00000e+00,	4.367411e-08
    738	1.738739e+02	-1.00000e+00,	4.369927e-08
    739	1.739740e+02	-1.00000e+00,	4.372443e-08
    740	1.740741e+02	-1.00000e+00,	4.374959e-08
    741	1.741742e+02	-1.00000e+00,	4.377474e-08
    742	1.742743e+02	-1.00000e+00,	4.379990e-08
    743	1.743744e+02	-1.00000e+00,	4.382506e-08
    744	1.744745e+02	-1.00000e+00,	4.385022e-08
    745	1.745746e+02	-1.00000e+00,	4.387538e-08
    746	1.746747e+02	-1.00000e+00,	4.390053e-08
    747	1.747748e+02	-1.00000e+00,	4.392569e-08
    748	1.748749e+02	-1.00000e+00,	4.395085e-08
    749	1.749750e+02	-1.00000e+00,	4.397601e-08
    750	1.750751e+02	-1.00000e+00,	4.400117e-08
    Index   frequency       s11
    751	1.751752e+02	-1.00000e+00,	4.402632e-08
    752	1.752753e+02	-1.00000e+00,	4.405148e-08
    753	1.753754e+02	-1.00000e+00,	4.407664e-08
    754	1.754755e+02	-1.00000e+00,	4.410180e-08
    755	1.755756e+02	-1.00000e+00,	4.412696e-08
    756	1.756757e+02	-1.00000e+00,	4.415211e-08
    757	1.757758e+02	-1.00000e+00,	4.417727e-08
    758	1.758759e+02	-1.00000e+00,	4.420243e-08
    759	1.759760e+02	-1.00000e+00,	4.422759e-08
    760	1.760761e+02	-1.00000e+00,	4.425274e-08
    761	1.761762e+02	-1.00000e+00,	4.427790e-08
    762	1.762763e+02	-1.00000e+00,	4.430306e-08
    763	1.763764e+02	-1.00000e+00,	4.432822e-08
    764	1.764765e+02	-1.00000e+00,	4.435338e-08
    765	1.765766e+02	-1.00000e+00,	4.437853e-08
    766	1.766767e+02	-1.00000e+00,	4.440369e-08
    767	1.767768e+02	-1.00000e+00,	4.442885e-08
    768	1.768769e+02	-1.00000e+00,	4.445401e-08
    769	1.769770e+02	-1.00000e+00,	4.447917e-08
    770	1.770771e+02	-1.00000e+00,	4.450432e-08
    771	1.771772e+02	-1.00000e+00,	4.452948e-08
    772	1.772773e+02	-1.00000e+00,	4.455464e-08
    773	1.773774e+02	-1.00000e+00,	4.457980e-08
    774	1.774775e+02	-1.00000e+00,	4.460496e-08
    775	1.775776e+02	-1.00000e+00,	4.463011e-08
    776	1.776777e+02	-1.00000e+00,	4.465527e-08
    777	1.777778e+02	-1.00000e+00,	4.468043e-08
    778	1.778779e+02	-1.00000e+00,	4.470559e-08
    779	1.779780e+02	-1.00000e+00,	4.473074e-08
    780	1.780781e+02	-1.00000e+00,	4.475590e-08
    781	1.781782e+02	-1.00000e+00,	4.478106e-08
    782	1.782783e+02	-1.00000e+00,	4.480622e-08
    783	1.783784e+02	-1.00000e+00,	4.483138e-08
    784	1.784785e+02	-1.00000e+00,	4.485653e-08
    785	1.785786e+02	-1.00000e+00,	4.488169e-08
    786	1.786787e+02	-1.00000e+00,	4.490685e-08
    787	1.787788e+02	-1.00000e+00,	4.493201e-08
    788	1.788789e+02	-1.00000e+00,	4.495717e-08
    789	1.789790e+02	-1.00000e+00,	4.498232e-08
    790	1.790791e+02	-1.00000e+00,	4.500748e-08
    791	1.791792e+02	-1.00000e+00,	4.503264e-08
    792	1.792793e+02	-1.00000e+00,	4.505780e-08
    793	1.793794e+02	-1.00000e+00,	4.508296e-08
    794	1.794795e+02	-1.00000e+00,	4.510811e-08
    795	1.795796e+02	-1.00000e+00,	4.513327e-08
    796	1.796797e+02	-1.00000e+00,	4.515843e-08
    797	1.797798e+02	-1.00000e+00,	4.518359e-08
    798	1.798799e+02	-1.00000e+00,	4.520874e-08
    799	1.799800e+02	-1.00000e+00,	4.523390e-08
    800	1.800801e+02	-1.00000e+00,	4.525906e-08
    801	1.801802e+02	-1.00000e+00,	4.528422e-08
    802	1.802803e+02	-1.00000e+00,	4.530938e-08
    803	1.803804e+02	-1.00000e+00,	4.533453e-08
    804	1.804805e+02	-1.00000e+00,	4.535969e-08
    805	1.805806e+02	-1.00000e+00,	4.538485e-08
    806	1.806807e+02	-1.00000e+00,	4.541001e-08
    807	1.807808e+02	-1.00000e+00,	4.543517e-08
    808	1.808809e+02	-1.00000e+00,	4.546032e-08
    Index   frequency       s11
    809	1.809810e+02	-1.00000e+00,	4.548548e-08
    810	1.810811e+02	-1.00000e+00,	4.551064e-08
    811	1.811812e+02	-1.00000e+00,	4.553580e-08
    812	1.812813e+02	-1.00000e+00,	4.556096e-08
    813	1.813814e+02	-1.00000e+00,	4.558611e-08
    814	1.814815e+02	-1.00000e+00,	4.561127e-08
    815	1.815816e+02	-1.00000e+00,	4.563643e-08
    816	1.816817e+02	-1.00000e+00,	4.566159e-08
    817	1.817818e+02	-1.00000e+00,	4.568674e-08
    818	1.818819e+02	-1.00000e+00,	4.571190e-08
    819	1.819820e+02	-1.00000e+00,	4.573706e-08
    820	1.820821e+02	-1.00000e+00,	4.576222e-08
    821	1.821822e+02	-1.00000e+00,	4.578738e-08
    822	1.822823e+02	-1.00000e+00,	4.581253e-08
    823	1.823824e+02	-1.00000e+00,	4.583769e-08
    824	1.824825e+02	-1.00000e+00,	4.586285e-08
    825	1.825826e+02	-1.00000e+00,	4.588801e-08
    826	1.826827e+02	-1.00000e+00,	4.591317e-08
    827	1.827828e+02	-1.00000e+00,	4.593832e-08
    828	1.828829e+02	-1.00000e+00,	4.596348e-08
    829	1.829830e+02	-1.00000e+00,	4.598864e-08
    830	1.830831e+02	-1.00000e+00,	4.601380e-08
    831	1.831832e+02	-1.00000e+00,	4.603896e-08
    832	1.832833e+02	-1.00000e+00,	4.606411e-08
    833	1.833834e+02	-1.00000e+00,	4.608927e-08
    834	1.834835e+02	-1.00000e+00,	4.611443e-08
    835	1.835836e+02	-1.00000e+00,	4.613959e-08
    836	1.836837e+02	-1.00000e+00,	4.616474e-08
    837	1.837838e+02	-1.00000e+00,	4.618990e-08
    838	1.838839e+02	-1.00000e+00,	4.621506e-08
    839	1.839840e+02	-1.00000e+00,	4.624022e-08
    840	1.840841e+02	-1.00000e+00,	4.626538e-08
    841	1.841842e+02	-1.00000e+00,	4.629053e-08
    842	1.842843e+02	-1.00000e+00,	4.631569e-08
    843	1.843844e+02	-1.00000e+00,	4.634085e-08
    844	1.844845e+02	-1.00000e+00,	4.636601e-08
    845	1.845846e+02	-1.00000e+00,	4.639117e-08
    846	1.846847e+02	-1.00000e+00,	4.641632e-08
    847	1.847848e+02	-1.00000e+00,	4.644148e-08
    848	1.848849e+02	-1.00000e+00,	4.646664e-08
    849	1.849850e+02	-1.00000e+00,	4.649180e-08
    850	1.850851e+02	-1.00000e+00,	4.651696e-08
    851	1.851852e+02	-1.00000e+00,	4.654211e-08
    852	1.852853e+02	-1.00000e+00,	4.656727e-08
    853	1.853854e+02	-1.00000e+00,	4.659243e-08
    854	1.854855e+02	-1.00000e+00,	4.661759e-08
    855	1.855856e+02	-1.00000e+00,	4.664274e-08
    856	1.856857e+02	-1.00000e+00,	4.666790e-08
    857	1.857858e+02	-1.00000e+00,	4.669306e-08
    858	1.858859e+02	-1.00000e+00,	4.671822e-08
    859	1.859860e+02	-1.00000e+00,	4.674338e-08
    860	1.860861e+02	-1.00000e+00,	4.676853e-08
    861	1.861862e+02	-1.00000e+00,	4.679369e-08
    862	1.862863e+02	-1.00000e+00,	4.681885e-08
    863	1.863864e+02	-1.00000e+00,	4.684401e-08
    864	1.864865e+02	-1.00000e+00,	4.686917e-08
    865	1.865866e+02	-1.00000e+00,	4.689432e-08
    866	1.866867e+02	-1.00000e+00,	4.691948e-08
    Index   frequency       s11
    867	1.867868e+02	-1.00000e+00,	4.694464e-08
    868	1.868869e+02	-1.00000e+00,	4.696980e-08
    869	1.869870e+02	-1.00000e+00,	4.699496e-08
    870	1.870871e+02	-1.00000e+00,	4.702011e-08
    871	1.871872e+02	-1.00000e+00,	4.704527e-08
    872	1.872873e+02	-1.00000e+00,	4.707043e-08
    873	1.873874e+02	-1.00000e+00,	4.709559e-08
    874	1.874875e+02	-1.00000e+00,	4.712075e-08
    875	1.875876e+02	-1.00000e+00,	4.714590e-08
    876	1.876877e+02	-1.00000e+00,	4.717106e-08
    877	1.877878e+02	-1.00000e+00,	4.719622e-08
    878	1.878879e+02	-1.00000e+00,	4.722138e-08
    879	1.879880e+02	-1.00000e+00,	4.724653e-08
    880	1.880881e+02	-1.00000e+00,	4.727169e-08
    881	1.881882e+02	-1.00000e+00,	4.729685e-08
    882	1.882883e+02	-1.00000e+00,	4.732201e-08
    883	1.883884e+02	-1.00000e+00,	4.734717e-08
    884	1.884885e+02	-1.00000e+00,	4.737232e-08
    885	1.885886e+02	-1.00000e+00,	4.739748e-08
    886	1.886887e+02	-1.00000e+00,	4.742264e-08
    887	1.887888e+02	-1.00000e+00,	4.744780e-08
    888	1.888889e+02	-1.00000e+00,	4.747296e-08
    889	1.889890e+02	-1.00000e+00,	4.749811e-08
    890	1.890891e+02	-1.00000e+00,	4.752327e-08
    891	1.891892e+02	-1.00000e+00,	4.754843e-08
    892	1.892893e+02	-1.00000e+00,	4.757359e-08
    893	1.893894e+02	-1.00000e+00,	4.759875e-08
    894	1.894895e+02	-1.00000e+00,	4.762390e-08
    895	1.895896e+02	-1.00000e+00,	4.764906e-08
    896	1.896897e+02	-1.00000e+00,	4.767422e-08
    897	1.897898e+02	-1.00000e+00,	4.769938e-08
    898	1.898899e+02	-1.00000e+00,	4.772453e-08
    899	1.899900e+02	-1.00000e+00,	4.774969e-08
    900	1.900901e+02	-1.00000e+00,	4.777485e-08
    901	1.901902e+02	-1.00000e+00,	4.780001e-08
    902	1.902903e+02	-1.00000e+00,	4.782517e-08
    903	1.903904e+02	-1.00000e+00,	4.785032e-08
    904	1.904905e+02	-1.00000e+00,	4.787548e-08
    905	1.905906e+02	-1.00000e+00,	4.790064e-08
    906	1.906907e+02	-1.00000e+00,	4.792580e-08
    907	1.907908e+02	-1.00000e+00,	4.795096e-08
    908	1.908909e+02	-1.00000e+00,	4.797611e-08
    909	1.909910e+02	-1.00000e+00,	4.800127e-08
    910	1.910911e+02	-1.00000e+00,	4.802643e-08
    911	1.911912e+02	-1.00000e+00,	4.805159e-08
    912	1.912913e+02	-1.00000e+00,	4.807675e-08
    913	1.913914e+02	-1.00000e+00,	4.810190e-08
    914	1.914915e+02	-1.00000e+00,	4.812706e-08
    915	1.915916e+02	-1.00000e+00,	4.815222e-08
    916	1.916917e+02	-1.00000e+00,	4.817738e-08
    917	1.917918e+02	-1.00000e+00,	4.820253e-08
    918	1.918919e+02	-1.00000e+00,	4.822769e-08
    919	1.919920e+02	-1.00000e+00,	4.825285e-08
    920	1.920921e+02	-1.00000e+00,	4.827801e-08
    921	1.921922e+02	-1.00000e+00,	4.830317e-08
    922	1.922923e+02	-1.00000e+00,	4.832832e-08
    923	1.923924e+02	-1.00000e+00,	4.835348e-08
    924	1.924925e+02	-1.00000e+00,	4.837864e-08
    Index   frequency       s11
    925	1.925926e+02	-1.00000e+00,	4.840380e-08
    926	1.926927e+02	-1.00000e+00,	4.842896e-08
    927	1.927928e+02	-1.00000e+00,	4.845411e-08
    928	1.928929e+02	-1.00000e+00,	4.847927e-08
    929	1.929930e+02	-1.00000e+00,	4.850443e-08
    930	1.930931e+02	-1.00000e+00,	4.852959e-08
    931	1.931932e+02	-1.00000e+00,	4.855475e-08
    932	1.932933e+02	-1.00000e+00,	4.857990e-08
    933	1.933934e+02	-1.00000e+00,	4.860506e-08
    934	1.934935e+02	-1.00000e+00,	4.863022e-08
    935	1.935936e+02	-1.00000e+00,	4.865538e-08
    936	1.936937e+02	-1.00000e+00,	4.868053e-08
    937	1.937938e+02	-1.00000e+00,	4.870569e-08
    938	1.938939e+02	-1.00000e+00,	4.873085e-08
    939	1.939940e+02	-1.00000e+00,	4.875601e-08
    940	1.940941e+02	-1.00000e+00,	4.878117e-08
    941	1.941942e+02	-1.00000e+00,	4.880632e-08
    942	1.942943e+02	-1.00000e+00,	4.883148e-08
    943	1.943944e+02	-1.00000e+00,	4.885664e-08
    944	1.944945e+02	-1.00000e+00,	4.888180e-08
    945	1.945946e+02	-1.00000e+00,	4.890696e-08
    946	1.946947e+02	-1.00000e+00,	4.893211e-08
    947	1.947948e+02	-1.00000e+00,	4.895727e-08
    948	1.948949e+02	-1.00000e+00,	4.898243e-08
    949	1.949950e+02	-1.00000e+00,	4.900759e-08
    950	1.950951e+02	-1.00000e+00,	4.903275e-08
    951	1.951952e+02	-1.00000e+00,	4.905790e-08
    952	1.952953e+02	-1.00000e+00,	4.908306e-08
    953	1.953954e+02	-1.00000e+00,	4.910822e-08
    954	1.954955e+02	-1.00000e+00,	4.913338e-08
    955	1.955956e+02	-1.00000e+00,	4.915853e-08
    956	1.956957e+02	-1.00000e+00,	4.918369e-08
    957	1.957958e+02	-1.00000e+00,	4.920885e-08
    958	1.958959e+02	-1.00000e+00,	4.923401e-08
    959	1.959960e+02	-1.00000e+00,	4.925917e-08
    960	1.960961e+02	-1.00000e+00,	4.928432e-08
    961	1.961962e+02	-1.00000e+00,	4.930948e-08
    962	1.962963e+02	-1.00000e+00,	4.933464e-08
    963	1.963964e+02	-1.00000e+00,	4.935980e-08
    964	1.964965e+02	-1.00000e+00,	4.938496e-08
    965	1.965966e+02	-1.00000e+00,	4.941011e-08
    966	1.966967e+02	-1.00000e+00,	4.943527e-08
    967	1.967968e+02	-1.00000e+00,	4.946043e-08
    968	1.968969e+02	-1.00000e+00,	4.948559e-08
    969	1.969970e+02	-1.00000e+00,	4.951075e-08
    970	1.970971e+02	-1.00000e+00,	4.953590e-08
    971	1.971972e+02	-1.00000e+00,	4.956106e-08
    972	1.972973e+02	-1.00000e+00,	4.958622e-08
    973	1.973974e+02	-1.00000e+00,	4.961138e-08
    974	1.974975e+02	-1.00000e+00,	4.963653e-08
    975	1.975976e+02	-1.00000e+00,	4.966169e-08
    976	1.976977e+02	-1.00000e+00,	4.968685e-08
    977	1.977978e+02	-1.00000e+00,	4.971201e-08
    978	1.978979e+02	-1.00000e+00,	4.973717e-08
    979	1.979980e+02	-1.00000e+00,	4.976232e-08
    980	1.980981e+02	-1.00000e+00,	4.978748e-08
    981	1.981982e+02	-1.00000e+00,	4.981264e-08
    982	1.982983e+02	-1.00000e+00,	4.983780e-08
    Index   frequency       s11
    983	1.983984e+02	-1.00000e+00,	4.986296e-08
    984	1.984985e+02	-1.00000e+00,	4.988811e-08
    985	1.985986e+02	-1.00000e+00,	4.991327e-08
    986	1.986987e+02	-1.00000e+00,	4.993843e-08
    987	1.987988e+02	-1.00000e+00,	4.996359e-08
    988	1.988989e+02	-1.00000e+00,	4.998875e-08
    989	1.989990e+02	-1.00000e+00,	5.001390e-08
    990	1.990991e+02	-1.00000e+00,	5.003906e-08
    991	1.991992e+02	-1.00000e+00,	5.006422e-08
    992	1.992993e+02	-1.00000e+00,	5.008938e-08
    993	1.993994e+02	-1.00000e+00,	5.011454e-08
    994	1.994995e+02	-1.00000e+00,	5.013969e-08
    995	1.995996e+02	-1.00000e+00,	5.016485e-08
    996	1.996997e+02	-1.00000e+00,	5.019001e-08
    997	1.997998e+02	-1.00000e+00,	5.021517e-08
    998	1.998999e+02	-1.00000e+00,	5.024032e-08
    999	2.000000e+02	-1.00000e+00,	5.026548e-08
  13. #13
    Points: 239,557, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,502
    239,557
    100
    Re: S11 inductance measurement
    The 1 nH inductor is acting as almost perfect short, as expected. Why are you measuring at 100 to 200 Hz? What's the purpose of the setup, no real network Analysator works in a 100 Hz frequency range.
    If it's pure simulation, why not measuring inductance directly instead of taking the detour over S11?
  14. #14
    Full Member level 4
    Points: 1,197, Level: 7
    Feb 2016
    203
    1,197
    7
    @FvM
    I have now used much higher frequency range as below, but how do I analyze these data to obtain the inductance value ?
Name:	Screenshot from 2018-02-13 20-18-33.png
     * gnetlist -g spice-noqsi -o test_active_inductor.net test_active_inductor.sch
     AC Analysis  Tue Feb 13 20:11:09  2018
    Index   frequency       s11
    0	1.000000e+08	-9.99684e-01,	2.512877e-02
    1	1.001001e+08	-9.99684e-01,	2.515392e-02
    2	1.002002e+08	-9.99683e-01,	2.517906e-02
    3	1.003003e+08	-9.99682e-01,	2.520421e-02
    4	1.004004e+08	-9.99682e-01,	2.522936e-02
    5	1.005005e+08	-9.99681e-01,	2.525450e-02
    6	1.006006e+08	-9.99680e-01,	2.527965e-02
    7	1.007007e+08	-9.99680e-01,	2.530479e-02
    8	1.008008e+08	-9.99679e-01,	2.532994e-02
    9	1.009009e+08	-9.99679e-01,	2.535509e-02
    10	1.010010e+08	-9.99678e-01,	2.538023e-02
    11	1.011011e+08	-9.99677e-01,	2.540538e-02
    12	1.012012e+08	-9.99677e-01,	2.543052e-02
    13	1.013013e+08	-9.99676e-01,	2.545567e-02
    14	1.014014e+08	-9.99675e-01,	2.548081e-02
    15	1.015015e+08	-9.99675e-01,	2.550596e-02
    16	1.016016e+08	-9.99674e-01,	2.553111e-02
    17	1.017017e+08	-9.99673e-01,	2.555625e-02
    18	1.018018e+08	-9.99673e-01,	2.558140e-02
    19	1.019019e+08	-9.99672e-01,	2.560654e-02
    20	1.020020e+08	-9.99671e-01,	2.563169e-02
    21	1.021021e+08	-9.99671e-01,	2.565683e-02
    22	1.022022e+08	-9.99670e-01,	2.568198e-02
    23	1.023023e+08	-9.99670e-01,	2.570712e-02
    24	1.024024e+08	-9.99669e-01,	2.573227e-02
    25	1.025025e+08	-9.99668e-01,	2.575742e-02
    26	1.026026e+08	-9.99668e-01,	2.578256e-02
    27	1.027027e+08	-9.99667e-01,	2.580771e-02
    28	1.028028e+08	-9.99666e-01,	2.583285e-02
    29	1.029029e+08	-9.99666e-01,	2.585800e-02
    30	1.030030e+08	-9.99665e-01,	2.588314e-02
    31	1.031031e+08	-9.99664e-01,	2.590829e-02
    32	1.032032e+08	-9.99664e-01,	2.593343e-02
    33	1.033033e+08	-9.99663e-01,	2.595858e-02
    34	1.034034e+08	-9.99662e-01,	2.598372e-02
    35	1.035035e+08	-9.99662e-01,	2.600887e-02
    36	1.036036e+08	-9.99661e-01,	2.603401e-02
    37	1.037037e+08	-9.99660e-01,	2.605916e-02
    38	1.038038e+08	-9.99660e-01,	2.608430e-02
    39	1.039039e+08	-9.99659e-01,	2.610945e-02
    40	1.040040e+08	-9.99658e-01,	2.613459e-02
    41	1.041041e+08	-9.99658e-01,	2.615974e-02
    42	1.042042e+08	-9.99657e-01,	2.618488e-02
    43	1.043043e+08	-9.99656e-01,	2.621003e-02
    44	1.044044e+08	-9.99656e-01,	2.623517e-02
    45	1.045045e+08	-9.99655e-01,	2.626032e-02
    46	1.046046e+08	-9.99654e-01,	2.628546e-02
    47	1.047047e+08	-9.99654e-01,	2.631061e-02
    48	1.048048e+08	-9.99653e-01,	2.633575e-02
    49	1.049049e+08	-9.99652e-01,	2.636090e-02
    50	1.050050e+08	-9.99652e-01,	2.638604e-02
    51	1.051051e+08	-9.99651e-01,	2.641119e-02
    52	1.052052e+08	-9.99650e-01,	2.643633e-02
    53	1.053053e+08	-9.99650e-01,	2.646148e-02
    54	1.054054e+08	-9.99649e-01,	2.648662e-02
  15. #15
    Full Member level 4
    Feb 2016
    203
    1,197
    7
    I have added my own calculation, but I really doubt it.
    S11_inductance.wxmx.zip
Name:	Screenshot from 2018-02-13 22-16-24.png
