power supply metal and guard ring metal connection
shanmei
Advanced Member level 1
USA
Should I connect the p-tap guard-ring to the vss power supply line directly? Should I connect the n-tap guard-ring to the vdd power supply line directly?
Or the guard-ring and the power supply line should be separated? Thanks.
You can connect them directly by metal. But don't run the MOSFET currents over the guard-ring: connect the transistor sources also directly to the power supply, but separate from the guard-ring.
Vdd1 is connected to source of the pmos, and Vdd2 is connected to n-tap;
Vss1 is connected to source of the nmos, and Vss2 is connected to p-tap;
Vdd1 and Vdd2 are eventually connected together nearby the pad VDD;
Vss1 and Vss2 are eventually connected together nearby the pad VSS.
The reason for it is that there should be no current going through the psub and n-well, then they are very quite, not noise, right? Thanks.
Right, that's what I meant.
