Geevaprasa
Newbie level 2
I am using PMDC Brushed motor for my Electric Car. When I was using some certain types of motor driver, I am facing some issues with the entire control unit. For example, whatever the sensor connected with the control unit, all sensor reading are improper and wrong readings.
I am thinking it is because of Motor driver (MOSFET). It is creating a noise, that is affecting nearby sensor unit. But, this problem occurs due to some specific industrial grade motor driver.
Statement: I am using https://www.nex-robotics.com/products/motor-drivers/hercules-6v-36v-16amp-motor-driver.html Hercules Motor Driver with my control unit, it contains a processor and another sensor unit. When I was using this motor driver I am not facing any problem(Noise issue). Whatever the sensors connected, everything working fine.
Problem: If I am using Industrial grade Motor driver Like Cytron Smart driver Duo 10 https://www.cytron.io/p-mdds10 or Sabertooth 2x12 https://www.dimensionengineering.com/products/sabertooth2x12 those problems will occur. I have tried 10 times. I have tried with an optocoupler, Common Ground, Sensor shielding but that is not working fine. I don't know how to proceed further?
