LVS Setup error, it says the return code 34.
bwarlord01
Junior Member level 3
Hi, i am currently using Synopsys Custom Compiler (65nm Tech) and i am setting up my LVS for my design and i got this error:
"Error: The job 'hercules_lvs_17' started on host 'localhost' with process id 25915 failed to start or complete successfully; the job's return code is 34. "
Can anyone help me with this? Pls?
P.S. my design only contains MOS Transistors
Did you look up Hercules documentation (Reference Guide or User Guide) to see what "code 34" means?
