viperpaki007
Full Member level 5
As far as I know, small signal non-linearity in MOSFET is mainly due to non-linear behavior of transconductance and output conductance. It is generally measured in IIP3 value. On the other hand, large signal non-linearity of MOSFET in an amplifier is related to its maximum linear swing range. If the swing range is higher, large signal non-linearity will also be higher. Large signal non-linearity is generally measured in 1dB compression point. I want to know what is the relationship between small and large signal non-linearity? Generally its said that P1dB is approximately 10dB lesser than IIP3. Why is this the case because as far as i can understand, large and small signal non-linearity originate from different sources. How can improving one help to improve other?
