pigtwo
Member level 4
Hello all,
I'm working of a very simple transistor circuit. The basic idea here is I'm going to be taking a signal from a comparator that will have a high voltage of +19v and a low voltage of -24v and I want to translate this to +3.3v and 0v. I also need it to be an open collector output.
The circuit I came up with is shown below. The transistor I'm using is a mmbt6428lt1g. I've use the spice model provided by ON Semiconductor in this simulation.
With this simulation I'm seeing spikes on the output during the transitions. See below.
I'm not exactly sure why this is happening. My guess is that it has something to do with the base voltage going above 3.3v or below 0v before the transistor completely turns on or off. But I have very little experience with transistor circuits so I'm not sure.
What could be causing this and what would be the way to prevent it?
Any advice or idea is greatly appreciated!
Thank you!
Thank you!
