vikash23
Full Member level 2
I am trying to implement a circuit that will energise the relay coil.
Attached is the screen shot of the LT spice simulation.
instead of relay coil I have used a inductor with 390uH and 18 ohm resistance, 1A current capability.
instead of using a load resistor with 18ohm i have used a inductor.
The spec of relay coil is 9 - 36V and 18ohm resistance.
my questions are
1. I am using a 24V to energise the coil and does it means 24V/18 ohm = 1.33A. So my input power should be able to deliver 1.5 A at 24V?
2. in the lt spice the blue trace is only 3.6V when simulating because if the 18ohm load on the inductor coil. So what does the 3.6V represent? will there be voltage drop of 20V and 4 volt approx will be still available in the capacitor when the coil is energised since the 18 ohm of the coil act as a load resistance ?
my questions are
