aasimzee
Junior Member level 1
Helo guys, I need urgent help in this issue, i am trying to use controller's usb port to communicate with computer but usbb stops communicating after sending one byte. I am attaching a code in this thread, please help me. it is an examples project supposed to loop back but it is not doing it continoiusly
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 void device_template_task(void) #endif { static U8 buf[EP_SIZE_TEMP2]; #ifdef FREERTOS_USED portTickType xLastWakeTime; xLastWakeTime = xTaskGetTickCount(); while (true) { vTaskDelayUntil(&xLastWakeTime, configTSK_USB_DTP_PERIOD); // First, check the device enumeration state if (!Is_device_enumerated()) continue; #else // First, check the device enumeration state if (!Is_device_enumerated()) return; #endif // FREERTOS_USED // HERE STARTS THE USB DEVICE APPLICATIVE CODE // The example below just performs a loopback transmission/reception. // All data received with the OUT endpoint is stored in a RAM buffer and // sent back to the IN endpoint. #if BOARD == EVK1100 // For example, display Start-of-Frame counter on LEDs LED_Display_Field(LED_MONO0_GREEN | LED_MONO1_GREEN | LED_MONO2_GREEN | LED_MONO3_GREEN, sof_cnt >> 5); #elif BOARD == EVK1101 || BOARD == UC3C_EK || BOARD == EVK1104 || BOARD == EVK1105 // For example, display Start-of-Frame counter on LEDs LED_Display_Field(LED0 | LED1, sof_cnt >> 5); #else #error The display of the SOFs must be defined here. #endif // If we receive something in the OUT endpoint, just store it in the RAM buffer if (Is_usb_out_received(EP_TEMP_OUT)) { LED_On(LED_APPLI_1); Usb_reset_endpoint_fifo_access(EP_TEMP_OUT); data_length = Usb_byte_count(EP_TEMP_OUT); usb_read_ep_rxpacket(EP_TEMP_OUT, buf, data_length, NULL); Usb_ack_out_received_free(EP_TEMP_OUT); LED_Off(LED_APPLI_1); } // Load the IN endpoint with the contents of the RAM buffer if (data_length && Is_usb_in_ready(EP_TEMP_IN)) { LED_On(LED_APPLI_0); Usb_reset_endpoint_fifo_access(EP_TEMP_IN); usb_write_ep_txpacket(EP_TEMP_IN, buf, data_length, NULL); data_length = 0; Usb_ack_in_ready_send(EP_TEMP_IN); LED_Off(LED_APPLI_0); } #ifdef FREERTOS_USED } #endif }
