amin5659
Member level 3
hi every one. i want to program my Spartan6 Xc6slx9-2tqg144c with spi flash.(at45db141d)
the problem is when i want to program the flash with impact i get the error below ?
hardware schematic attached...
FPGA-MOSI is connected to P66;(CMP_MOSI)
FPGA-DIN -> P65;(DIN)
FPGA-CLK -> P70; (CCLK)
FPGA-CSO -> P38;(CSO_B)
can any one help me?
done.
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
// *** BATCH CMD : identifyMPM
Selected part: AT45DB161D
// *** BATCH CMD : attachflash -position 1 -spi "AT45DB161D"
// *** BATCH CMD : assignfiletoattachedflash -position 1 -file "D:/JOb/Projects/6-Logic_Analyzer/QT/Test/Plot_logic_1/myflash_test.mcs"
INFO:iMPACT - Current time: 1/19/2018 12:37:13 AM
// *** BATCH CMD : Program -p 1 -dataWidth 1 -spionly -e -v -loadfpga
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/14.7/ISE_DS/ISE/spartan6/data/xc6slx9_spi.cor.
'1': Downloading core...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1100 1110 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
INFO:iMPACT - SPI Device not found.
INFO:iMPACT:2488 - The operation did not complete successfully.
INFO:iMPACT - '1': Flash was not programmed successfully.
Elapsed time = 1 sec.
done.
Validating chain...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
