Astec AA23260 smps change output voltage to 13,5V
fjpompeo
Advanced Member level 1
Brazil
I need to modify the output voltage of an Astec AA23260 server power supply from 12V to 13,5V to be used as a car battery charger, can someone help me?
Regards,
Fernando - Call sign PU2PLL
It is a simple resistor change;
but it is imperative that you have the schematic to determine which one.
A power supply is no battery charger.
To build a charger you should have a current control also.
Read how a charger should operate.
Without series resistor you may overload the power supply. With series resistor you may increase charging time and power dissipation.
