casemod
Since I often travel between Europe and America I have a number of work appliances that are AC 110V, fed here in Europe using a high power phase dimmer. These are resistive or have small universal motors.
I'm happy functionality wise (in fact I can even regulate power as a bonus), but I was looking for a smarter way to accomplish this that would be easier on the EMI, after all, I'm suddenly switching 10 or 20A to a resistive element at some point in the sine wave and I had this causing issues on some places.
I know using an inductor to limit DI/DV would be ideal, but this adds unnecessary weight and the idea is for the converter to be portable (as in carry on luggage portable)
I have pondered skipping cycles. So have 230V directly on the element (4x rated power) for one full cycle (20mS) and then skipping 3 cycles (60mS), but not sure how to trigger the triac for exactly one cycle (otherwise, if starting half way, the same problem as above would remain).
PWM'ing the sine wave using high frequency IGBT/MOSFET with an input filter capacitor/suppressor coil could also work, but I'm concerned with excessive power dissipation/circuit complexity
Any thoughts on this?
