Pspice Error - "Less than 2 connections at node"
Liz_S
Newbie level 3
Hello!
I tried to build this circuit:
And I got this error:
*Analysis directives:
.TRAN 0 500ns 0
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source WET3
X_U2 N00164 N00168 $G_DPWR $G_DGND INV
C_C1 N00160 N00164 2pF TC=0,0
R_R1 N00164 N00495 50k TC=0,0
X_U3 N00216 N00168 N00160 $G_DPWR $G_DGND NOR2
M_M1 N00744 N01953 0 0 Mbreakn
M_M2 N00744 N01801 0 0 Mbreakn
M_M3 N01801 N00857 0 0 Mbreakn
M_M4 N01046 N01953 N00744 N01357 Mbreakp
M_M5 N01357 N01801 N01046 N01357 Mbreakp
M_M6 N01357 N00857 N01801 N01357 Mbreakp
V_Vdd 0 N01357 5v
C_C2 N01046 N00857 2pF TC=0,0
V_V1 0 N01953
+PULSE 0 5v 10ns 1ps 1ps 1ns
R_R2 N00857 N01357 50k TC=0,0
**** RESUMING sim1.cir ****
.END
**** Generated AtoD and DtoA Interfaces ****
* Analog/Digital interface for node N00160
* Moving X_U3.U1:OUT1 from analog node N00160 to new digital node N00160$DtoA
X$N00160_DtoA1
+ N00160$DtoA
+ N00160
+ $G_DPWR
+ $G_DGND
+ DtoAdefault
+ PARAMS: DRVH= 50 DRVL= 50 CAPACITANCE= 0
* Analog/Digital interface for node N00164
* Moving X_U2.U1:IN1 from analog node N00164 to new digital node N00164$AtoD
X$N00164_AtoD1
+ N00164
+ N00164$AtoD
+ $G_DPWR
+ $G_DGND
+ AtoDdefault
+ PARAMS: CAPACITANCE= 0
* Analog/Digital interface power supply subcircuits
X$DIGIFPWR 0 DIGIFPWR
ERROR(ORPSIM-15141): Less than 2 connections at node N00495.
Thank you very much! Liz
The above Log mentions a resistor R1 that at first glance I could not see in the circuit. In fact, this resistor is connected to two other devices also not visible in the snapshot, namelly C1 and U2. Try zooming out to see what else is on the project sheet.
Reactions: Liz_S
    Liz_S
Thank you very much! I'm new to PSpice so I make silly mistakes, I apologize.
Now, for the same circuit, I'm running transient analysis and I get the following error:
ERROR(ORPSIM-15659): Discontinuing simulation due to convergence problem
I tried to solve it using methods I found online, and nothing helps...
Guess you want to move C2 connection to the NAND output (M1/M2/M4 drain).
PSpice Error - Convergence Problem
Hello!
.TRAN  0 500n 0
.OPTIONS ADVCONV
* source WET3
V_Vdd         0 N05008 5v
M_M1         N04963 N05022 0 0 Mbreakn1
M_M2         N04963 N05022 N05004 N05008 Mbreakp3
M_M3         N04963 N05234 0 0 Mbreakn2
M_M4         N05004 N05234 N05008 N05008 Mbreakp4
C_C1         N04963 N05238  2p  TC=0,0
M_M6         N05234 N05238 0 0 Mbreakn5
M_M5         N05234 N05238 N05008 N05008 Mbreakp6
R_R1         N05238 N05008  50k TC=0,0
V_V1         N05022 0
+PULSE 0v 5v 10n 1p 1p 1n
.END
**** 01/13/18 13:20:38 ******* PSpice Lite (March 2016) ******* ID# 10813 ****
 ** Profile: "SCHEMATIC1-sim1"  [ C:\Cadence\SPB_17.2\wet3-pspicefiles\schematic1\sim1.sim ]
 ****     MOSFET MODEL PARAMETERS
               Mbreakn1        Mbreakp3        Mbreakn2        Mbreakp4
               NMOS            PMOS            NMOS            PMOS
       LEVEL    1               1               1               1
           L    3.000000E-06    3.000000E-06    3.000000E-06    3.000000E-06
           W    3.000000E-06   12.000000E-06    3.000000E-06   12.000000E-06
         VTO    2              -2               2              -2
          KP  207.100000E-06  103.500000E-06  207.100000E-06  103.500000E-06
       GAMMA    0               0               0               0
         PHI     .6              .6              .6              .6
      LAMBDA     .02             .02             .02             .02
          IS   10.000000E-15   10.000000E-15   10.000000E-15   10.000000E-15
          JS    0               0               0               0
          PB     .8              .8              .8              .8
        PBSW     .8              .8              .8              .8
          CJ    0               0               0               0
        CJSW    0               0               0               0
        CGSO    0               0               0               0
        CGDO    0               0               0               0
        CGBO    0               0               0               0
         TOX   10.000000E-09   10.000000E-09   10.000000E-09   10.000000E-09
          XJ    0               0               0               0
          UO                  300                             300
       UCRIT   10.000000E+03   10.000000E+03   10.000000E+03   10.000000E+03
      DIOMOD    1               1               1               1
         VFB    0               0               0               0
        LETA    0               0               0               0
        WETA    0               0               0               0
          U0    0               0               0               0
        TEMP    0               0               0               0
         VDD    5               5               5               5
       XPART    0               0               0               0
               Mbreakn5        Mbreakp6
               NMOS            PMOS
       LEVEL    1               1
           W    3.000000E-06    6.000000E-06
         VTO    2              -2
       GAMMA    0               0
         PHI     .6              .6
      LAMBDA     .02             .02
          JS    0               0
          PB     .8              .8
        PBSW     .8              .8
          CJ    0               0
        CJSW    0               0
        CGSO    0               0
        CGDO    0               0
        CGBO    0               0
          XJ    0               0
          UO                  300
      DIOMOD    1               1
         VFB    0               0
        LETA    0               0
        WETA    0               0
          U0    0               0
        TEMP    0               0
         VDD    5               5
       XPART    0               0
Starting pseudo-transient algorithm.
ERROR -- Convergence problem in transient bias point calculation
  Last node voltages tried were:
 NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE
(N04963)   -1.3975 (N05004)   -2.8130 (N05008)   -2.8130 (N05022)    0.0000
(N05234)   -1.4065 (N05238)   -2.3899
  These voltages failed to converge:
    V(N04963)                 =    -1.821V  \    -1.398V
    V(N05004)                 =    -2.809V  \    -2.813V
    V(N05238)                 =    -2.813V  \    -2.390V
  These supply currents failed to converge:
    I(V_Vdd)                  =   118.46pA  \   -10.00GA
    I(V_V1)                   =         0A  \   -1.036uA
  These devices failed to converge:
    M_M1      M_M2      M_M3      M_M6      M_M5
**** Interrupt ****
Re: PSpice Error - Convergence Problem
If you do a web search with the keywords "spice-convergence-workaround", you will find some common recommendations to adjust the simulation parameters in order to eliminate this error, but another alternative that often solves this is to perform the simulation, not with ideal components, but with real components (which in other words are modeled with parasitic elements). I'm not familiar with the PSPICE libraries, but at least in LTSPICE there are models of many 'real' devices. Another possibility is to place some components in the above circuit which do not impact on it performance, but prevents computing from being trapped around an oscillating state not steady (this so-called "convergence error" condition), such as adding high value pull-up/pull-down resistors in parallel to nodes to assert expected default values, as well as adding small value resistors in series to nodes where should not have infinite current, for example between each MOSFET totem. All these extra components would help the circuit to act as the real world behaving, for example, the current limiting due to wiring, as well as having asymmetry in biasing that forces the floating nodes to a random or determined state.
