+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 1
    Points: 51, Level: 1
    Join Date
    Jan 2018
    Posts
    Points
    51
    Level
    [Moved]: voltage shiftier with conditional purpose
    Hello
    I need a voltage shifter like this below, 0:0.3 is logic 0 - 0.3:0.6 is logic 1- 0.6:0.9 is logic 2, you can see that need a gate in Hspice to filter or constant the voltage above 0.6v at the output, at first I want to do this by opamp but I couldn't, please someone help me in this
    Click image for larger version.
    •   Alt12th January 2018, 09:53
      advertising
  2. #2
    Member level 4
    Points: 868, Level: 6
    Join Date
    Jun 2015
    Posts
    78
    Points
    868
    Level
    Re: voltage shiftier with conditional purpose
    If you're talking about analog IC design, isn't it the job for ADC circuit?
    1 members found this post helpful.
    •   Alt12th January 2018, 11:30
      advertising
  3. #3
    Super Moderator
    Points: 241,412, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,906
    Points
    241,412
    Level
    100
    Re: [Moved]: voltage shiftier with conditional purpose
    You won't necessarily use an ADC to distinguish three voltage levels respectively implement just 2 thresholds. Two comparators should be fine. Additional logic depending on the intended result representation.
