+ Post New Thread
Results 1 to 19 of 19
  1. #1
    Full Member level 6
    Points: 2,693, Level: 12
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    Suggestions welcome for Antenna for tranceiving 433 MHZ over 1000 meters
    Hello friends,
    I am using Si4432 RF Module (bought thru' Ebay.in) in my project. I can able to send and receive on 433 MHz up to 100 meters approximately using the spiral antenna (30mm (h), 5mm (dia), 25 no turns = Total length = 250 mm approx) came along with Module. But I want to transmit and receive up to 1000 m. Transmitter power is +18.5 dbm at 80mA current (tested and Confirmed). Receiver sensitivity is -117 dbm (as per datasheet at 1200 bps). Should I use high gain antenna on receiver side in order to receive up to 1000 m? I came to know from the "google"
    that Antenna Length should be proportional to the distance travel required.
    For example, to transmit 433 MHZ to 1000 m distance,
    The Antenna Length = 1000m/433 MHz = 2.30m = (2.30/4) (i.e lambda/4) = 0.57 m = 57 CM.
    Any amplifier available for increasing transmit power to 3W or so as to achieve 1000 m using small antenna at receiver side? Antenna at receiver side will be located at LOS (Line of sight). Can any one recommend the suitable Antenna to satisfy my requirement?
    thank you all,
    pmk
  2. #2
    Super Moderator
    Points: 241,738, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,978
    Points
    241,738
    Level
    100
    Re: Suggestions welcome for Antenna for tranceiving 433 MHZ over 1000 meters
    Your lambda calculation is flawed. It's the ratio between speed of light and frequency, 0.59 m for 433 MHz. λ/4 is 173 mm.
    A λ/4 antenna rod with sufficient ground plane or a λ/2 dipole for transmitter and receiver is the usual solution. Antennas with higher gain are not permitted for license free 433 MHz band, neither power boosters. Not sure if 18.5dBm is legal in your area.
    •   Alt11th January 2018, 10:33
      advertising
  3. #3
    Full Member level 6
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    FvM, you are right. it is 173 mm. ok. My PCB is single sided of 60mm x 70mm with GND Filled. The Si4432 Module connected to my PCB through berg connectors. Antenna pin located on Si4432 not on my PCB. As I said earlier, my spiral spring lamda/4 antenna length is 25 CM approx.
    RF SETTINGS: CFREQ= 433 MHz,
    +/- 30KHz deviation,
    datarate 1.171875 Kbps (1200 bps),
    BW = 64.1 KHz,
    IF = 937.5 KHz.
    But, I can able to realize only up to 100 meters.
    Any suggestions?
    pmk
  4. #4
    Advanced Member level 5
    Points: 13,525, Level: 27
    Join Date
    Nov 2012
    Posts
    2,521
    Points
    13,525
    Level
    27
    You will need a line of sight with a dish.
    If you get at 100 m (max) the signal will be 100 times less (20dB) at 1000 m.
    Else you need to amplify the transmission power to more than 1W.
  5. #5
    Full Member level 6
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    Both TX and RX is in Line of Sight (LOS).
    pmk
  6. #6
    Super Moderator
    Points: 70,474, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,530
    Points
    70,474
    Level
    64
    If they are line of sight, presumably they are in fixed locations. Why not make up the extra 20dB or so by using a directional antenna at both ends. A small Yagi should be adequate and inexpensive and would also help by reducing interference at the receiver end. You might be able to use a Yagi at only the receiving end if carefully designed.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
  7. #7
    Points: 9,603, Level: 23
    Join Date
    Apr 2014
    Posts
    1,482
    Points
    9,603
    Level
    23
    Quote Originally Posted by c_mitra View Post
    So we just need a small yagi antenna with 20dB gain on one end
    http://www.m2inc.com/FG43213WLA
    SCNR
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,978
    Points
    241,738
    Level
    100
    Yagi Antenna will surely work but doesn't comply with EIRP limits for 433 MHz. I would try with a real lambda/4 or lambda/2 antenna first.
    •   Alt11th January 2018, 15:56
      advertising
  9. #9
    Full Member level 6
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    No. It is not in a fixed location. Slave (Receiver) is a hand held device. It can move around. If the Master (TX) find the Slaves (RX) within its region (Line Of Sight - 1 Km), it will send a message. But it does not need to wait for acknowledgement from slaves (so no need for higher powered antenna at RX end). It is one-way transmission only.
    It is not possible to use bigger antennas in RX side. Because it is a hand held device.
    lambda/4 tried. The result was only 100 m. I am going to try dipole (λ/2) antenna. I will post the result tomorrow.
    thank you all,
    pmk
    •   Alt11th January 2018, 16:57
      advertising
  10. #10
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,978
    Points
    241,738
    Level
    100
    If you apply Friis free space propagation formula, you get -71 dBm received power for 10 dBm transmitter power at 433 Mhz, 1000 m distance and dipole gain for both antennas. That's more than 40 dB above specified receiver sensitivity.
  11. #11
    Join Date
    Apr 2014
    Posts
    1,482
    Points
    9,603
    Level
    23
    Quote Originally Posted by speedEC View Post
    This was only to show you what very large antenna (20dBi gain) you need for 100m -> 1000m, if you go for legal operation and antenna at the receive side. A dipole will maybe give 100m -> 150m increase.
  12. #12
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,978
    Points
    241,738
    Level
    100
    As calculation shows, there's a huge difference between the theoretical range and your tests. The question is, what are the shares of bad spiral antenna efficiency and matching losses, obstacles blocking line of sight, RF interferences reducing the sensitivity.
  13. #13
    Full Member level 6
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    Yes. I also looked in to FRIIS calculator. Free Space propagation loss at 75.17 dbm. So, if TX is at +18.5 dbm, then at 1000m the Rf signal strength should be at -56.67 dbm (+18.5 dbm - (+75.17)). The receiver sensitivity at -177 dbm as per datasheet. It well above the RX sensitivity. but, I can't able to realize more than 100 m. So, as you said, I have to look in to Spiral Antenna, trying with Dipole Antenna, etc.
    And also, In Si4432 datasheet, they recommend to set Sgin bit of non-default register 0x69 in order to work AGC (Automatic Gain Control in RX mode) correctly. I will set and test. Let us see whether this will make any difference.
    thank you,
    pmk
  14. #14
    Full Member level 6
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    Edit:
    ....The receiver sensitivity at -117 dbm as per datasheet....
    thank you,
    pmk
    Full Member level 3
    Points: 2,267, Level: 11
    Achievements:
    7 years registered
    Join Date
    May 2010
    Vancouver, Canada
    Posts
    186
    Points
    2,267
    Level
    11
    Assume your link is line-of-sight. If so you are 40 - 50 dB short of link budget (following your own calculations). Something is wrong in your system. First you figure out what is wrong.
    Is your link really line-of-sight? How high radios are above the ground? What RSSI you get reported from your receiver at the fringe of the link? What happens when you elevate radios?
    Perform conducted sensitivity test: Connect Tx and Rx with long cable (use shielded chamber or put Tx and Rx in different rooms to avoid leakage through the air); insert attenuators. Increase variable attenuator until you stop receiving. Figure out what is power level on Rx terminals. Register RSSI reading at or before the cut-off. This should give you initial idea what is happening.
    1 members found this post helpful.
  16. #16
    Full Member level 6
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    Yes
    case 1: 10 foot
    case 2: 3 foot
    RSSI = 0x54 approx when Both TX and RX placed between 1 foot. reading RSSI when RX receives signal from TX.
    Note: RSSI Chart from datasheet attached. As per this chart, RSSI Value should be above 200 ( > 0xC8). Am I right?
    Thank you,
    pmk
    •   Alt16th January 2018, 06:32
      advertising
  17. #17
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    May 2010
    Vancouver, Canada
    Posts
    186
    Points
    2,267
    Level
    11
    I do not know. You have a graph - figure it out.
    0x54 corresponds to 84 decimal, according to your graph it is ~-80 dB. At 1ft?
    Free space path loss calculator:
    https://www.pasternack.com/t-calculator-fspl.aspx
    gives us for 400MHz at 1m 24.5dB path loss.
    start by taking few points at few close distances (1ft is probably too close - within 1 wavelengh. Start with 1m and step back) . Do RSSI readings make sense?
    Switch to cable.
  18. #18
    Full Member level 6
    Join Date
    Apr 2011
    Posts
    323
    Points
    2,693
    Level
    12
    Dear friends,
    I have tested with Various Antenna and stored results in xl sheet. it is attached FYRef.
    The RF settings are:
    CFREQ = 433 MHz, DEVIATION = +/- 20 kHz, Data Rate = 1.171875 kbps (1200 bps), BW = 42.7 kHz
    I read the RSSI value at the time of Sync Word Interrupt. Now I can able to correct RSSI value at Receiver. The distance I can able to communicate is far more than 150 meters and I am getting signal still at -80 dBm. So, I have to increase the test distance and post in a day or two.
    I came to know that, as FvM said, Lambda/4 Antenna gives a good result. But copper wire with 1mm dia and 17.5 CM antenna gives much more good result than other types including dipole antenna. I have to check one more time with dipole antenna, however.
    Can we able to reduce the data rate to extend the distance further. In datasheet, it says The Modulation Index should be between 1 and 32. Modulation Index = (2 x Freq deviation)/datarate (in kbps). I read some other document which recommends, faster data rate with retransmission option is good than slow data rate.
    Your suggestions are welcome.
    thank you all,
    pmk
  19. #19
    Points: 33,398, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,699
    Points
    33,398
    Level
    44
    If you reliably want to get out to 1000 meters, you need a different transceiver. Try a Semtech heavily coded modulation scheme
    www.semtech.com/IOT
