+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 1
    Points: 26, Level: 1
    Join Date
    Jan 2018
    Posts
    Points
    26
    Level
    Write a verilog/system verilog of a normally open momentary switch toggle with delays
    How to write in verilog and/or system verilog a normally open switch with delays with the following functionality: when pressed once it outputs 1 and stays 1 when depressed, when pressed a second time it outputs 0 and stays 0 when depressed. The 1 output is instantaneous upon pressing, the 0 output only occurs if the button is pressed for a determined time. This is essentially how the power button in desktops work: if computer is off pressing the button starts the computer but, if the computer is on, the button requires to be pressed for several seconds.
    •   Alt10th January 2018, 01:31
      advertising
  2. #2
    Super Moderator
    Points: 241,334, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,891
    Points
    241,334
    Level
    100
    Re: Write a verilog/system verilog of a normally open momentary switch toggle with de
    Is it a Verilog software exercise or a hardware design? In the latter case, you need a clock to implement the delay timer and key debouncing.
    A PC realizes the respective function in the BIOS firmware. You probably noticed that the off-delay becomes effective after the operation system has booted, you have a fast turn-off function during initial boot phase.
    1 members found this post helpful.
    •   Alt10th January 2018, 07:55
      advertising
  3. #3
    Junior Member level 2
    Points: 192, Level: 2
    Join Date
    Dec 2017
    Bydgoszcz - Poland
    Posts
    22
    Points
    192
    Level
    Quote Originally Posted by cesarxhc View Post
    Hello,
    as more experienced colleague has written you need: clok, counter (timer), debouncer (for button/switch) and very simple "state machine"( the state machine is for remember the actual state of switch) components. Just find out how to implement these components in Verilog (Google) and then interconnect them all in your project.
    Regards
