+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 3
    Points: 299, Level: 3
    Join Date
    Nov 2017
    Posts
    54
    Points
    299
    Level
    Bulk driven MOS. Flow of current direction
    Hi
    I have read about bulk driven MOS in research article it was written that applying input to the bulk removes the threshold voltage from the signal path. How is it possible?
    It was also writren that small voltage should apply at the gate to generate a small inversion layer.
    Normally in normal gate driven technique we apply gate voltage channel forms and current flows between drain and source.
    What will this bulk driven do how the current flow. Will it flow between bulk and drain? I can understand. What will the ac current and dc current work.
    Can someone explain ac and dc current flow seperately. Or suggest some good basic paper?
    •   Alt10th January 2018, 06:29
      advertising
  2. #2
    Member level 4
    Points: 868, Level: 6
    Join Date
    Jun 2015
    Posts
    78
    Points
    868
    Level
    Re: Bulk driven MOS. Flow of current direction
  3. #3
    Member level 3
    Join Date
    Nov 2017
    Posts
    54
    Points
    299
    Level
    The diagram is not clear in this paper.can you provide some other paper
    •   Alt11th January 2018, 04:09
      advertising
  4. #4
    Member level 4
    Join Date
    Jun 2015
    Posts
    78
    Points
    868
    Level
    Which one is not clear?
  5. #5
    Member level 3
    Join Date
    Nov 2017
    Posts
    54
    Points
    299
    Level
    I cant understand its not defining the bulk driven technique what happens when input is applied to the bulk
  6. #6
    Member level 4
    Join Date
    Jun 2015
    Posts
    78
    Points
    868
    Level
    I did not read this, but it seems there is an explanation that there are two BJTs in the bulk. Moreover, a circuit with the input-differential pair using bulk technique is presented and described. I do not think I can help you more. My apologies.
    •   Alt11th January 2018, 16:05
      advertising
  7. #7
    Super Moderator
    Points: 241,412, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,906
    Points
    241,412
    Level
    100
    I would try a simplified answer.
    In useful bulk driven operation, the current is still in the channel, the bulk junction should be reverse biased. You'll apply a gate bias voltage that allows channel current flow with reversed biased bulk.
    You effectively get a FET with an additional junction insulated gate (like JFET), review basic MOSFET literature or SPICE simulation models how the combination of Vbs and Vgs is setting Id.
