[SOLVED] Interpretation of radiation pattern plot
Dobilise
Newbie level 6
HI
Please can anyone help me to interprete the radiation pattern plot! Here an exemple picture of the obtained radiation pattern of patch antenna. What informations we can extract . Thanks for help
Message is unavailable.
Thanks for your reply and for the doc
Just what I want to know is the openning in the radiation pattern is normal or not?
Thanks in advance
Yes, the radiation pattern is fine, because this is about far field of the antenna.
I understand that the asymmetry of the radiation characteristics (in both planes) is doubtful. I think that the measurement results are correct, but the antenna is asymmetrical in both planes (for example, different screen dimensions).
There is some doubt that the width of the beam is the same in both planes (they should be different, wider in the H plane, narrower in the E plane). I assume that the antenna is a single radiator (because of value of gain)
