[General] Does using a USB mouse with PS/2 converter support page scrolling or not?
NewbeeAVR
Junior Member level 2
if used USB mouse wtih PS/2 converter supports scrolling or not
I want to know if I use USB mouse with USB to PS/2 converter to interface to micro controller it support scrolling wheel or not ?
Re: if used USB mouse wtih PS/2 converter supports scrolling or not
The mouse just produces data from the buttons, scroll wheel encoder and motion detector. All the controls are outputs so it depends on your MCU how the signals are used.
Brian.
Thanks for your reply.
I want to interface USB mouse-keyboard combo using USB to PS/2 adapter to ATmega is it possible or not.
It is not possible. To get working USB mouse over USB->PS/2 adapter you need to use a special mouse which supports both protocols: USB and PS/2.
Did you mean I need a PS/2 mouse not a USB combo.
Yes, an ordinary PS/2 mouse should work. Or you can use a microcontroller with a USB host functionality.
