Results 1 to 6 of 6
    Advanced Member level 3
    Points: 4,833, Level: 16
    kripacharya's Avatar
    Dec 2012
    New Delhi
    899
    4,833
    16
    VL53L0X distance measurement chip
    Does anyone have proper data how to program this chip ?
    The specs of this new IC are great, but almost impossible to use for general use since there is virtually zero documentation.
    I need code which will fairly reliably measure distances upto 5 feet using this chip. Can anyone help ?
    •   Alt5th January 2018, 18:30
      advertising
    Points: 26,055, Level: 39
    andre_teprom's Avatar
    Nov 2006
    Brazil
    7,857
    26,055
    39
    Blog Entries
    Re: VL53L0X distance measurement chip
    I need code
    Did you even have made a search on GitHub ?
    There are a lot of examples there.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt5th January 2018, 18:41
      advertising
    Dec 2012
    New Delhi
    899
    4,833
    16
    Yes Andre. I have seen lots of code on github. But it is all very obscure and badly documented. Also it all refers to libraries which I cannot directly use.
    Please try not to be so condescending. If you have any actual inputs then please provide. Otherwise stay off this thread. Thanks.
    I already have a system up and working, but require more details for improving the operations. Especially for longer range work up to around 5-6 feet.
    •   Alt5th January 2018, 19:14
      advertising
    Points: 57,700, Level: 58
    Apr 2014
    11,760
    57,700
    58
    It's not Andre's fault that the code is not well documented.
    And as long as you don't write what effort you did so far and what results you experienced .... I think it's helpful to give ideas where to look for code.
    Please don´t contact me via PM, because there is no time to respond to them. Thank you.
    Points: 241,686, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,967
    241,686
    100
    There are range specification in the datasheet for different object reflectance and ambient light conditions. I won't expect in a first order that software can extend the range beyond the specification, although it may be possible.
    Regarding software, I would start with the ST provided code.
    •   Alt5th January 2018, 23:58
      advertising
    Dec 2012
    New Delhi
    899
    4,833
    16
    Actually there are references in various code fragments of different modes - like 'high accuracy', 'long range', 'fast measurement' etc. But no clear documentation on which set of registers/ what settings to choose. Also not known is whether code by various different people is actually working properly or not. So clearly long hours need to be spent in playing with different settings - not a good way to develop a surprise-free product.
    I wish I could, but I cannot use this option.
