+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Advanced Member level 2
    Points: 3,910, Level: 14
    Join Date
    Apr 2011
    Posts
    540
    Points
    3,910
    Level
    14
    Is there special way to map address to SDR SDRAM?
    SDR SDRAM like other DRAMs contains banks, rows, columns. Thus, to get maximum efficiency, I assume that there would be some non-trivial way to translate memory address to bank, row and column address. Is this true? If so, then how is it usually done?
    •   Alt5th January 2018, 17:01
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,892, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,567
    Points
    35,892
    Level
    46
    Re: Is there special way to map address to SDR SDRAM?
    You read the data sheet.
    There will be a number of address pins each for row, bank and column. So you know how many of each by doing 2^(npins)
    •   Alt5th January 2018, 19:11
      advertising
  3. #3
    Super Moderator
    Points: 241,537, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,924
    Points
    241,537
    Level
    100
    The optimal scheme is almost trivial. You get fastest access when reading or writing full pages, thus the lower address bits are usually mapped to column address lines.
    1 members found this post helpful.
    •   Alt5th January 2018, 19:17
      advertising
  4. #4
    Advanced Member level 3
    Points: 5,102, Level: 16
    Join Date
    Feb 2015
    Posts
    849
    Points
    5,102
    Level
    16
    normally, the addresses are mapped either (bank, row, column) or (row, bank, column). You can choose a different scheme if you want though. placing bank at higher address bits has a little advantage if you have a small number of independent applications that are allocated a large memory space. placing bank at lower address bits allows a larger sequential region to have only column accesses once all banks are open.
  5. #5
    Member level 5
    Points: 753, Level: 6
    Join Date
    Aug 2016
    Bangalore, India
    Posts
    94
    Points
    753
    Level
    To access SDRAM in an efficient manner, it is better to follow linear addressing scheme as told in #4 that is combining row address, column address and bank address into a single vector and then increment this single vector to access different memory locations.
    But as switching from one row to another row is slow, therefore keeping the row address in MSB is recommended.
    Therefore I think (row,bank,column) will be efficient in terms of time.
