Results 1 to 8 of 8
    Points: 730, Level: 5
    Mar 2015
    43
    730
    Unhappy Problem with hex2bix utility(does't run)
    hi every one. i have written a firmware for transferring data in slave FIFO mode for CY68013A.
    i have download .hex file generated in keiluvision2 to FX2LP. now i want to make .iic file for eeprom.
    my problem is when i run hex2bix.exe in utility folder it runs and closes promptly!
    i even run hex2bix.c file in visual studio 2008 but the problem is still there.
    with cmd i addressed the hex2bix.exe but with using uex2bix command i get the error:
    hex2bix does not recognize ...
    please help me how can i convert my hex file to .iic :(
    •   Alt5th January 2018, 10:57
      advertising
    Points: 69,545, Level: 64
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    11,367
    69,545
    64
    Re: Problem with hex2bix utility(does't run)
    I've never seen 'hextobix' but there used to be a program called 'hextobin'. Are you sure you got the program name correct?
    I don't know the '.iic' format, maybe it isn't a standard .hex file which has line headers, address and data fields and CRC stored as text.
    •   Alt5th January 2018, 15:54
      advertising
    Mar 2015
    43
    730
    Yes. Hex2bix is an application provided by cypress. This app converts hex file to standard eeprom file.
    •   Alt5th January 2018, 16:54
      advertising
    Points: 239,566, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,505
    239,566
    100
    Obviously the location where hex2bix.exe resides isn't in the path. Either add it or execute it with a full path specification.
    Mar 2015
    43
    730
    i think the path is right. i set the path just like the picture. the program runs but it seems that hex2bix doesn't accept any input Click image for larger version.
    •   Alt6th January 2018, 11:12
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,505
    239,566
    100
    The screenshot in post #1 tells something different.
    You did not set the path. You are trying to run hex2bix from your working directory but it's not recognized. You need to enter hex2bix with the full path as in the first call plus the argument, with your work directory being the current directory. Something about "first steps when using the windows (or linux) cmd shell".
  7. #7
    Points: 54,878, Level: 57
    Apr 2014
    11,115
    54,878
    57
    To avoid path problems:
    * Copy your source file to the hex2bix directory
    * use the "cd" command to go to the hex2bix path
    * run the hex2bix program without additional paths
    Please don´t contact me via PM, because there is no time to respond to them. Thank you.
  8. #8
    Mar 2015
    43
    730
    Yes. that was the problem.
    thanks guys....
