+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Advanced Member level 2
    Points: 3,836, Level: 14
    Join Date
    Apr 2011
    Posts
    530
    Points
    3,836
    Level
    14
    What determines the number of rows in an SDRAM?
    SDRAM is divided into banks, each bank into rows and each row into columns. What determines how many rows will be there in an SDRAM?
    Is there a formula used to go from a single memory location address to generate three addresses of bank, row and column?
    •   Alt5th January 2018, 10:57
      advertising
  2. #2
    Super Moderator
    Points: 238,729, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,351
    Points
    238,729
    Level
    100
    Re: What determines the number of rows in an SDRAM?
    The DRAM chip internal organisation. Review the datasheet.
    1 members found this post helpful.
    •   Alt5th January 2018, 12:35
      advertising
  3. #3
    Join Date
    Apr 2011
    Posts
    530
    Points
    3,836
    Level
    14
    So it is an arbitrary choice of the SDRAM designers? I see.
    •   Alt5th January 2018, 16:58
      advertising
  4. #4
    Member level 1
    Points: 430, Level: 4
    Join Date
    Aug 2016
    Bangalore, India
    Posts
    35
    Points
    430
    Level
    But if you can access memory locations using linear addressing, then internal organisation may not matter for your application.
  5. #5
    Advanced Member level 5
    Points: 35,259, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,454
    Points
    35,259
    Level
    45
    Quote Originally Posted by mjuneja View Post
    It can be very important. DRAM can be very slow when switching from row to row. But reading across banks and within a row incurs little/no turnaround penalty. So if you can, it is best to design your logic with this knowledge.
