wtr
Full Member level 5
Hello all,
I've got vim/gvim. I've got plugin syntastic.
I have ghdl install on my computer & path mapped to my environment variables.
In my vimrc I have
The problem I'm getting is as follows
VHDL code in file is
The syntasticcheck gives me this error
Now it makes sense, since how would ghdl know about external files. Is there a way I can link it up like how someone does ctags which span multiple files. OR can I suppress these types of errors?
Much appreciated, and if there isn't yet. I think it's worth creating an article how someone can create their own hdl IDE using opensource applications.
Regards,
Wes
In my vimrc I have
set statusline+=%#warningmsg#
"set statusline+=%{SyntasticStatuslineFlag()}
set statusline+=%*
let g:syntastic_always_populate_loc_list = 1
let g:syntastic_auto_loc_list = 1
let g:syntastic_check_on_open = 1
let g:syntastic_check_on_wq = 0
let g:syntastic_enable_signs = 1
let g:syntastic_vhdl_checkers = ['ghdl']
Code VHDL - [expand] 1 clkdiv : entity Work.ClockDivisor Port Map (4, clk, int_clk);
file.vhd|95 col 26 error| primary unit clockdevisor not found in library "work"
Regards,
Wes
