Flyback diode: it has one job, but mine sucks at it, why?
Looking at your blue trace it is not too bad, a small snubber should compensate, smaller C (x 0.3 or smaller, and similar or larger R)
If you go to 5x the junction capacitance (~ 50pF) then a 330pF or 470pF cap should be heaps and you will have to experiment to find the correct R value (100 ohms starting..?) 0805 or 1206 directly across the diode. X7R dielectric as a minimum, preferably C0G (NPO).
A snubber across the driving fet can be of benefit too.
The power in the snubber R will be V^2 C Freq so for 10V, 100kHz, 470pF ~ 47mW, 10MHz = 470mW.
Thank you for your suggestion. In the meantime I decided to make a PCB, since the layout has such a great impact on the performance, I feel that I'm working somewhat in the blind with the "birds nest" circuit I have. I will revert with new results once winter holidays are over.
