Arduino uno code change to mikroC PRO for pic 16f628a
sribangaram
Full Member level 5
INDIA.:/;:'" VIJAYAWADA
Friends anybody help I want to change the code from arduino to mikroC PRO for pic 16f 628a so please give me the suggestion
Start the job, and just ask some question when/if it arises; There is no specific answer to this, particularly because you did not specify anything about the code.
Friend please my arduino code
PHP:
#include <EEPROM.h>
#include <SoftwareSerial.h>
SoftwareSerial GPRS(7, 8);
unsigned long interval = 120000; // the time we need to wait for switching off motor dry run (100 seconds interval)
unsigned long previousMillis = 0; // millis() returns an unsigned long.
void SendTextMessage(String s, bool b1, bool b2);
void serialMonitorPrint1(String s1, String s2);
void serialMonitorPrint(String s1, unsigned long s2);
void RecieveTextMessage();
void nonBlockingDelay();
void myserialEvent();
void check(char p[]);
int led = 9; // led for indicating that i received sms
int motor1 = 10; // motor pin connection
int dryRun = 11; // sensor for identifying water flow and used for dry run
//int smsPin = 3; // testing the simulation with SMS RECEIVED PIN
int sms_count = 0; //count the SMS sent
int sms_count1 = 0; //count the SMS sent
String EEPROMValue = " ";
bool timerlock = false;
int analogPin0 = A0;
int analogPin1 = A1;
int analogPin2 = A2;
int registration  = 0;
char example_string[] = "0000000000";
int temp = 0;
int i = 0;
char inchar; //Will hold the incoming character from the Serial Port.
int analogval0 = 0;
int analogval1 = 0;
int analogval2 = 0;
int dryRunvalue = 0;
int threshold = 1000;
int ALLPHASEOK = 5;  //ALL Phase OK LED
int PHASEMISSING = 6; //Phase missing LED
bool motorState = false; // state variable for the motor operation
bool waterflowing = true;
bool smsReceived = false;
bool count = true;
char str[15]; //string that holds final value received through SMS
char number[20];
String stringreceived;
char phonenumber[] = "0000000000"; //string that stores new phone number
String changedphonenumber = "";
const int eeprom_size = 10; // values saved in eeprom should never exceed 500 bytes
char eeprom_buffer[eeprom_size];
void setup() {
  delay(10000);
  delay(10000);
  // clear eeprom on new flash... just for debugging
  //for (int i = 0 ; i < EEPROM.length() ; i++) {
  //  EEPROM.write(i, 0);
  if (EEPROM.read(800) == 1)
    read_string_from_eeprom(eeprom_buffer);
    Serial.println("check the value ");
    String storednumber(eeprom_buffer);
    Serial.println(storednumber);
    storednumber.trim();
    changedphonenumber = storednumber;
  else
    changedphonenumber = "0000000000";
  sms_count = 0;
  sms_count1 = 0;
  Serial.begin(9600);
  GPRS.begin(9600);
  delay(1000);
  GPRS.println("AT+IPR=9600");
  Serial.println("AT+IPR=9600");
  delay(1000);
  GPRS.println("AT+CNMI=2,2,0,0,0");
  Serial.println("AT+CNMI=2,2,0,0,0");
  delay(1000);
  GPRS.println("AT+CMGF=1");
  Serial.println("AT+CMGF=1");
  delay(1000);
  //GPRS.println("AT+CFUN=1");
  //Serial.println("AT+CFUN=1");
  //delay(1000);
  GPRS.println("AT+CMGD=1");
  Serial.println("AT+CMGD=1");
  delay(1000);
  //Send new SMS command and message number
  //GPRS.println("AT+CMGS=\"+910000000000\"\r");
  //Serial.println("AT+CMGS=\"+910000000000\"\r");
  //delay(1000);
  //Send SMS content
  //GPRS.println("TEST");
  //Serial.println("TEST");
  //delay(1000);
  //GPRS.println("\r"); //the content of the message
   //delay(1000);
  //Send Ctrl+Z / ESC to denote SMS message is complete
  //GPRS.println((char)26);
  //Serial.println((char)26);
  //delay(1000);
  //Serial.println("SMS Sent!");
  //GPRS.println("ATD0000000000;");//dial the number, must include country code
  //Serial.println("CALL!");
  //delay(1000);
  pinMode(ALLPHASEOK, OUTPUT);
  pinMode(PHASEMISSING, OUTPUT);
  pinMode(motor1, OUTPUT);
  pinMode(dryRun, INPUT);
  //pinMode(smsPin, INPUT);
  // READ ANALOG PINS...............................................
  analogval0 = analogRead(analogPin0);
  analogval1 = analogRead(analogPin1);
  analogval2 = analogRead(analogPin2);
  if (analogval0 >= threshold && analogval1 >= threshold && analogval2 >= threshold)
    //SendTextMessage("All phase are ok");
    Serial.println("All phase are ok : SMS Sent");
    SendTextMessage("SYSTEM READY FOR YOU", false, false);
    digitalWrite(ALLPHASEOK, HIGH);
    digitalWrite(PHASEMISSING, LOW);
  else
    SendTextMessage("SYSTEM READY BUT 3PHASE NOT AVAILABLE", false, false);
    digitalWrite(ALLPHASEOK, LOW);
    digitalWrite(PHASEMISSING, HIGH);
    delay(1000);
void loop() {
  if (GPRS.available() > 0)
    myserialEvent();
  if (analogval0 < threshold || analogval1 < threshold || analogval2 < threshold)
    sms_count1 = 0; //reset the counter for else block
    // sending one time sms
    while (sms_count < 1) //Number of SMS Alerts to be sent limited at 3
      Serial.println("THREE PHASE NOT AVAILABLE & MOTER IS IN OFF");
      SendTextMessage("THREE PHASE NOT AVAILABLE & MOTER IS IN OFF MODE", false, true);
    count = true; // to freshly start the NON BLOCKING COUNTER
    motorState = false; // to freshly start 20seconds Delay
    delay(200);
    digitalWrite(motor1, LOW); // Phase is missing or no power so motor will be switched off
  else
    //Serial.println("inside else statement");
    sms_count = 0; //reset sms counter of if block
    while (sms_count1 < 1) //Number of SMS Alerts to be sent limited at 3
      SendTextMessage("THREE PHASE AVAILABLE ", true, false);
    delay(200);
    if (temp == 1)
      Serial.println("......................................inside temp condition statement");
      check(str);
      temp = 0;
      i = 0;
      delay(1000);
    if (motorState)
      dryRunvalue = digitalRead(dryRun);
      //serialMonitorPrint("dry run value : ", + dryRunvalue);
      if ( dryRunvalue ) //water flow sensor....if pin 11 is active
        nonBlockingDelay(); // create countdown delay of 10 minutes
      else
}// end of the loop
  Serial.println("***********inside non blocking delay*************");
  unsigned long currentMillis = millis(); // grab current time
  if (count == true )
    previousMillis = currentMillis;
  count = false;
  serialMonitorPrint("currentMillis : ", currentMillis);
  Serial.println();
  // check if "interval" time has passed (10,000 milliseconds)
  if ((unsigned long)(currentMillis - previousMillis) >= interval) {
    if (motorState)
      Serial.println("*****************************Timing completed motor will off**************************************");
      digitalWrite(motor1, LOW); // sets the motor to off state
      SendTextMessage("MOTOR TRIP DUE TO DRY RUN ", false, false);
      motorState = false;
      count = true;
  Serial.write(GPRS.read());
  if (GPRS.find("#F."))
    while (GPRS.available())
      char inChar = GPRS.read();
      str[i++] = inChar;
      if (inChar == '*')
        temp = 1;
        return;
void check(char msg[])
  //Serial.println("SMS RECEIVED : MOTOR WILL SWITCH ON or OFF BASED ON SMS DATA");
  if (!(strncmp(msg, "ON", 2)))
    motorSmsOn();
    delay(200);
  else if (!(strncmp(msg, "OFF", 3)))
    motorSmsOff();
    delay(200);
  else if (!(strncmp(msg, "REG", 3)))
    // Serial.print("Message received is : " + String(msg) );
    stringreceived = String(msg);
    delay(100);
    stringreceived.remove(0, 3);
    delay(100);
    stringreceived.remove(12);
    delay(100);
    Serial.println("String received truncated  is : " + stringreceived);
    delay(100);
    numberchangingsms();
    str[0] = '\0' ;
    delay(100);
    char *cstr = &stringreceived[0u];
    delay(100);
    int p = 800;
    EEPROM.write(p, 1); //test bit for confirming eprom write
    delay(100);
    save_string_to_eeprom(cstr); //EEPROM WRITE OF PHONE NUMBER
    delay(1000);
void SendTextMessage(String SENDSMS, bool incAllphase, bool incNoPhase)
  String temporary = "AT+CMGS=" +String('"') +"+"+ String(91)+changedphonenumber+"\""+"\r";
  Serial.println(temporary);
  //GPRS.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
  delay(1000);  // Delay of 1000 milli seconds or 1 second
  GPRS.println(temporary); // Replace x with mobile number
  delay(1000);
  GPRS.println(SENDSMS);// The SMS text you want to send
  delay(100);
  GPRS.println((char)26);// ASCII code of CTRL+Z
  delay(1000);
  if (incAllphase)
    sms_count1++;
  if (incNoPhase)
    sms_count++;
void motorSmsOn()
  Serial.println("SMS RECEIVED : MOTOR SWITCHED ON");
  digitalWrite(motor1, HIGH); // sets the motor to on state
  SendTextMessage("MOTOR is SWITCHED ON", false, false);
  motorState = true;
  delay(2000);
  delay(1000);
void motorSmsOff()
  Serial.println("MOTOR SWITCHED OFF");
  digitalWrite(motor1, LOW); // sets the motor to on state
  SendTextMessage("MOTOR is SWITCHED OFF", false, false);
  motorState = false;
  delay(2000);
  delay(1000);
void numberchangingsms()
  Serial.println("NUMBER TO BE CHANGED");
  SendTextMessage("NUMBER TO BE CHANGED PLEASE RESTART THE SYSTEM", false, false);
  delay(2000);
  delay(1000);
  String s3 = s1 + s2;
  Serial.println(s3);
  Serial.println(s3);
void save_string_to_eeprom(char *stringIn) {
  Serial.print(strlen(stringIn));
  for (int i = 0; i < strlen(stringIn); i++) {
    //Serial.print(stringIn[i]);
    EEPROM.write(i, stringIn[i]);
//-------------------------- EEPROM READ--------------------------
void read_string_from_eeprom(char *bufferIn) {
  for (int i = 0; i < eeprom_size; i++) {
    bufferIn[i] = EEPROM.read(i);
I did not understand why you posted the original Arduino code without showing the code you were supposedly transcribing to C. Anyway, your next activity will now be to look in the compiler you want to work with, libraries that perform functions similar to those in Arduino and start the work by yourself, do not expect anyone to do it for you.
