+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 4
    Points: 1,772, Level: 9
    Join Date
    May 2014
    Posts
    215
    Points
    1,772
    Level
    9
    Modelsim vsim-3033 error can't find instantiation is the -L handle broken?
    The following is the dump
    vsim -L work test.sd_cmd_master_tb
    # vsim -L work test.sd_cmd_master_tb
    # Start time: 16:38:27 on Jan 03,2018
    # Loading sv_std.std
    # Loading test.sd_cmd_master_tb
    # ** Error: (vsim-3033) ../../../bench/verilog/sd_cmd_master_tb.sv(72): Instantiation of 'sd_cmd_master' failed. The design unit was not found.
    # Time: 0 ps Iteration: 0 Instance: /sd_cmd_master_tb File: ../../../bench/verilog/sd_cmd_master_tb.sv
    # Searched libraries:
    # C:/fpgamason/memory/sd_card_controller/trunk/sim/rtl_sim/run/test
    Notice that it doesn't look in the work library but rather the test library twice.
    to put into context the following works
    vmap diff_name work
    vsim -L diff_name test.sd_cmd_master_tb
    # vsim -L diff_name -L test test.sd_cmd_master_tb
    # Start time: 16:46:34 on Jan 03,2018
    # Loading diff_name.sd_cmd_master
    •   Alt3rd January 2018, 17:49
      advertising
  2. #2
    Super Moderator
    Points: 28,582, Level: 41
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,549
    Points
    28,582
    Level
    41
    Re: Modelsim vsim-3033 error can't find instantiation is the -L handle broken?
    I never use -L with the work library it's modelsim's default library and I've noticed it has a different behavior than libraries that are vmap'd (and therefore show up in the modelsim.ini file. There is an existing forum member that is employed by Mentor that can probably explain this in more detail.
