+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 4
    Points: 887, Level: 6
    Join Date
    May 2015
    Posts
    72
    Points
    887
    Level
    Navigate LUT resources utilized by different components in a hiearchy in ISE 14.2
    In vivado, we can easily compile a hierarchy and navigate the resources utilized by each component. Is there some similar way to do so in ISE 14.2?
    •   Alt30th December 2017, 14:37
      advertising
  2. #2
    Advanced Member level 5
    Points: 12,201, Level: 26
    Join Date
    Aug 2011
    Posts
    2,482
    Points
    12,201
    Level
    26
    Re: Navigate LUT resources utilized by different components in a hiearchy in ISE 14.2
    •   Alt2nd January 2018, 02:11
      advertising
  3. #3
    Member level 4
    Join Date
    May 2015
    Posts
    72
    Points
    887
    Level
    No, I want something like this
    Click image for larger version.
    •   Alt2nd January 2018, 16:25
      advertising
  4. #4
    Super Moderator
    Points: 27,966, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,386
    Points
    27,966
    Level
    40
    You have to enable the hierarchical utilization report in map, which is disabled by default. I believe it is under the advanced map options, which is also disabled by default.
    1 members found this post helpful.
