+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Junior Member level 3
    Points: 165, Level: 2
    Join Date
    Oct 2017
    Posts
    26
    Points
    165
    Level
    non responsive vhdl code in FPGA board
    I wrote a VHDL code for synchronous demodulation. I use vivado 2016.4. it works perfectly with a testbench in the software. but when I burnt the code into the FPGA board (Xilinx Artix-35T FPGA (xc7a35ticsg324-1L)) it doesnt work. any suggestions?
    I used a software called terra term to read the output from the board. it is serial communication. nothing is wrong with the board. I tested the board with a different code and it worked. since it works fine in the simulation i couldnt find the error in my code.
    the baud rate and pin mapping are double checked and verified. plus after implementing the design I ran a post-implementation timing simulation also. the result was positive. it said the user timing constraints are completely met.!! need help!
  2. #2
    Super Moderator
    Points: 53,858, Level: 56
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster
    Join Date
    Apr 2014
    Posts
    10,870
    Points
    53,858
    Level
    56
    Re: non responsive vhdl code in FPGA board
    Possible issues:
    Not correct power supply
    No valid clock source
    Wrong schematic
    Wrong code
    Wrong expectation
    Wrong test method
    If you want us to validate your application you need to give all these informations.
    Klaus
    Please don´t contact me via PM, because there is no time to response to them. Thank you.
    1 members found this post helpful.
    •   Alt29th December 2017, 08:25
      advertising
  3. #3
    Join Date
    Oct 2017
    Posts
    26
    Points
    165
    Level
    thank you for replying. but as I mentioned, it is working properly with a testbench. so I hope the code is ok. at least there is no error in the synthesis. and from the post-implementation time simulation, it gave a positive reply. it said the user timing constraints are met. and about the power supply, the board is connected to my lap! i mean if thats what you meant by incorrect power supply.
    i didn't understand what u mean by wrong expectation and test method!
    •   Alt29th December 2017, 08:38
      advertising
  4. #4
    Advanced Member level 5
    Points: 35,244, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,453
    Points
    35,244
    Level
    45
    What do you mean by "working properly in a testbench"?
    Have you tested it exhaustively?
    Have you modelled all the busses?
    Did it pass all your asserts?
    Have you used appropriate coding styles?
    Did the design meet timing?
    In your case, the usual issue is poor coding. It is easy to write code that will "work" in a testbench and then fail synthesis because you didnt use correct coding styles. Why no post the code so we can help?
    •   Alt29th December 2017, 10:47
      advertising
  5. #5
    Join Date
    Oct 2017
    Posts
    26
    Points
    165
    Level
    no synthesis error and timing constraints are met.
    i ll upload the code below:
    in this code, the period of CLK is 20ns and demod_clk is 1320ns
    TX_DATA and RX_DATA are set of 24 data points which are 32767,40609,47995,54496,59735,63406,65296,63406,59 735,54496,47995,40609,32767,24924,17538,11037,5798 ,2129,238,2129,5798,11037,
    17538,24924
    TX_DATA is the refference wave and RX_DATA is the incoming wave. i am using same numbers for both for the sake of verification.
    entity scheme_demod is
        Port ( TX_DATA : in signed(16 downto 0);
               RX_DATA : in signed(16 downto 0);
               clk : in std_logic;
               demod_clk : in  STD_LOGIC;
    	       --rx_data_compl : in std_logic;
    		   tx_data_compl : in std_logic;
    		   b_count : out std_logic;
    		   start_data : out std_logic;
    		   start_data1 : out STD_LOGIC;
    		   DATA_OUT : out std_logic_vector (39 downto 0)
    end scheme_demod;
    architecture Behavioral of scheme_demod is
    type bus_type is array(0 to 23) of integer range 0 to 65535;
    type bus_type1 is array (0 to 23) of signed (16 downto 0);
    signal temp_rx : bus_type1 :=(others =>(others => '0'));
    signal temp_tx : bus_type1 :=(others =>(others => '0'));
    signal newrx : bus_type1 :=(others =>(others => '0'));
    signal i,p : integer :=0;
    signal moore_rx : signed (16 downto 0);
    signal new_rx : signed (16 downto 0);
    signal dif : signed (16 downto 0);
    signal temp_sum : signed(39 downto 0) :="0000000000000000000000000000000000000000";
    signal a,b : std_logic;
    signal zc_clk,demod : std_logic;
    signal test,test1 : std_logic := '1';
    begin
    start_data <= test;
    start_data1 <= test1;
    process(demod_clk,clk)
    begin
      if rising_edge(demod_clk) then
        test <= '1';
        temp_tx(i) <= TX_DATA - 32767;
        temp_rx(i) <= RX_DATA - 16384;
        moore_rx <= temp_rx(i);
        i <= i + 1;
      end if;
      if rising_edge(clk) then
       dif <= 0 - moore_rx;
       if (0 - moore_rx > 0) then
            a <= '0';
        else a <= '1';
        end if;
        end if;
      if rising_edge (demod_clk) then
        b <= a;
        end if;
     if i = 24 then i <= 0; end if;
     end process;
    zc_clk <= (not b) and a;
    process(zc_clk,demod_clk)
    variable k : integer:=0;
    begin
    if zc_clk' event and zc_clk = '1' then
     demod <= '1';
     k := 1;
     end if;
      if falling_edge(demod_clk) then
        if demod = '1' then
    --        b_count <= '0';
            newrx(k) <= moore_rx;
            new_rx <= newrx(k);
            temp_sum <= temp_sum + newrx(p) * temp_tx (p);
            p <= p + 1;
            k := k+1;
       end if;
       end if;
      if k = 24 then
         k :=0;
      end if;
          b_count <= '0';
        if  p = 24 then
            b_count <= '1';
           DATA_OUT <= std_logic_vector(temp_sum);
           temp_sum <= "0000000000000000000000000000000000000000";
            p <= 0;
         end if;
     end if;
     end process;
    end Behavioral;
  6. #6
    Super Moderator
    Points: 238,683, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,343
    Points
    238,683
    Level
    100
    No fun to be proved right...
    About to impossible for various asynchronous constructs like
    outside an edge sensitive condition.
    My general suggestion is to rewrite the code in a strictly synchronous manner, everything under the control of the 50 MHz clock, external events synchronized to it as far as necessary.
  7. #7
    Super Moderator
    Points: 27,922, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,379
    Points
    27,922
    Level
    40
    I would also suggest using 1 clock 1 process, instead of 2 clocks 1 process.
    I guess synthesis tools have gotten better if it didn't barf on that coding style.
  8. #8
    Member level 1
    Points: 410, Level: 4
    Join Date
    Aug 2016
    Bangalore, India
    Posts
    32
    Points
    410
    Level
    Too many clocks in a single process.
    I would recommend define your process in a way that makes your code synthesizable.
    A reference template has been added for your reference.
    process (<clock>,<async_reset>,<en>)
    begin
       if <async_reset> = '0' then
          <statements>;
       elsif (<clock>'event and <clock> = '1') then
          if <en> = '0' then
             <statements>;
          else
             <statements>;
          end if;
       end if;
    end process;
    •   AltYesterday, 09:41
      advertising
  9. #9
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,379
    Points
    27,922
    Level
    40
    en in the above code is not required and should not be in the sensitivity list. It will actually cause the simulator to reenter the process when en changes wasting simulation kernel cycles.
    clock'event and clock = '1' is depricated over using the function rising_edge(clock), this antiquated style (with actual simulation repercussions) is taught by way too many academic institutions. You would think a institution of higher learning would learn what is new (actually very old) in a language.
