Results 1 to 13 of 13
    Advanced Member level 2
    Points: 3,836, Level: 14
    Apr 2011
    530
    3,836
    14
    Can one force ModelSim to flag signals missing signals in sensitivity list?
    In VHDL we often use processes not trigerred by clock e.g next state process for FSM. In this case, there may be a long list of signals that must be put into the sensitivity list.
    I have noticed that if a signal is missing in sensitivity list, the code may still work when synthesized but will not work in simuation. This often leads to confusion and wasted time.
    Is there a way to detect signals that must be present in VHDL process sensitivity list but are missing when using ModelSim? It does not seem to flag up such things by default.
    •   Alt29th December 2017, 00:00
      advertising
    Points: 19,859, Level: 34
    barry's Avatar
    Mar 2005
    California, USA
    3,831
    19,859
    34
    Re: Can one force ModelSim to flag signals missing signals in sensitivity list?
    If you use VHDL 2008 you can just use "all" in the sensitivity list .
    Points: 35,271, Level: 45
    Jun 2010
    6,455
    35,271
    45
    Quote Originally Posted by matrixofdynamism View Post
    Yes you can.
    the vcom command has a -check_synthesis switch :
    Quote Originally Posted by Modelsim Command Reference Manual
    -check_synthesis
    (optional) Turns on limited synthesis rule compliance checking. Specifically, it checks to
    see that signals read by a process are in the sensitivity list. The checks understand only
    combinational logic, not clocked logic. Edit the CheckSynthesis variable in the modelsim.ini
    file to set a permanent default.
    Advanced Member level 3
    Points: 5,971, Level: 18
    Jul 2010
    Sweden
    775
    5,971
    18
    I never use a "next state" combinatorial process. I write state machines as one clocked process.
    With the tools we have today, I don't see any reason to use 2 processes for one state machine.
    •   Alt31st December 2017, 14:00
      advertising
    barry's Avatar
    Mar 2005
    California, USA
    3,831
    19,859
    34
    Quote Originally Posted by std_match View Post
    I agree. I never understood that whole separate "next state" nonsense.
    Jun 2010
    6,455
    35,271
    45
    Quote Originally Posted by barry View Post
    From my understanding, it comes from several places:
    1. Synthesis tools use to require separate processes for logic and registers.
    2. Some engineers (usually old timers) seem to understand separated logic/register processes better. These people also often also like using schematics.
    3. Because of 1/2, text books and tutorials taught separated logic/register styles.
    4. There are some that argue, that with a single process, it becomes "harder" to write unregistered outputs, as you then have to use the state machine directly in the combinatorial logic.
    Using a single process style, it can be easy to write a monster of a process (and I have been guity of it in the past) that becomes harder for others to follow, where separate processes would be better. But that is true of any style, though I think with single process style, it is easier to do.
    •   Alt1st January 2018, 09:37
      advertising
  7. #7
    Member level 3
    Points: 2,320, Level: 11
    Nov 2006
    59
    2,320
    11
    In the compile menu in modelsim, select "compile options". Under VHDL tab, under "Check for" enable the checkbox "synthesize". When you run the command "vcom" for vhdl files, you will find few warnings like missing signals from the sensitivity list.
  8. #8
    Points: 5,199, Level: 17
    Apr 2016
    1,092
    5,199
    17
    debugging is much much much easier. I am not talking about functional debugging, I am talking about timing issues. When you have to optimise that one critical path that is killing your entire performance, it becomes much easier if you can do it separately.
    Really, I am not Sam.
  9. #9
    Apr 2011
    530
    3,836
    14
    These answers are helpful. I learnt that the process to generate next state is combinatorial and thus should have its own process. It is a "good practice".
  10. #10
    barry's Avatar
    Mar 2005
    California, USA
    3,831
    19,859
    34
    I, and many others, would disagree that splitting the FSM into separate processes is "good practice". (An equal number would probably take the opposite view.) When you use a separate combinatorial process there is the danger of inadvertently creating latches. Furthermore, I, personally, wouldn't find debugging "much much easier" using separate processes. In fact, that complicates debugging as you now have to look in TWO processes for the problem rather than one.
    In the end, if you write your code properly either method should yield identical results and it comes down to a matter of preference and style.
    Another thing: I tend to make all of my outputs registers, so everything fits happily into my clocked process. You've got thousands and thousands of registers, you might as well use them.
  11. #11
    Jun 2010
    6,455
    35,271
    45
    I dont know. I would recommend 1 process, as would many others.
    "Good Practice" is good code that works well and is useable and readible by others. Ive seen "good practice" code that is terrible, and "bad practice" code that is good.
  12. #12
    Points: 6,996, Level: 19
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    1,016
    6,996
    19
    Blog Entries
    As pointed by many others it was a "good practice", but maybe 10 yrs ago. In the university when I was learning VHDL, I was writing state machines as two clocked process and had used Modelsim 6b or something like that.
    The modern "good practice" is a 1 clocked process, in my opinion and I have never run into problems.
    There are some white papers analyzing both practices and discussing their pros and cons. You can search, download and read them.
    In the end it is a matter of perspective.
    .....yes, I do this for fun!
    •   Alt12th January 2018, 09:47
      advertising
  13. #13
    Points: 4,874, Level: 16
    Feb 2015
    813
    4,874
    16
    In either case, you should be able to read/write either. You should also know the fundamental differences and common pitfalls of each.
    In many cases, a one-process FSM is fine from a design perspective. The exception is any time next_state is used for output logic that cannot tolerate the extra one cycle of delay. This can occur when interacting with another module. The one I see most frequently is the use of empty to generate a registered read signal. However it could happen in other situations.
    There are actually some interesting variations on the one/two process designs that mitigate a lot of the problems of either. One process has the issue that new devs still want to define logic as it occurs within a state vs as it occurs on transitions. two process has a lot of verbosity. There are language features that can solve these problems, especially in VHDL. I don't think anyone will use them, but they exist.
