[SOLVED] CRPR Threshold in PT
r1caw ex ua6bqg
Hi all!
I performed timing analysis in PT DMSA and have found that my "clock reconvergence pessimism" in report is 0 (crpr analysis is active), but my timing path has common clock path and CRPR value should be non-zero. I used "report_crpr" command on this path, results are presented below:
Common Clock: clk
Launching edge at common point: RISING
Capturing edge at common point: RISING
CRPR threshold: 0.1
Arrival Times (Static) Early Late CRP
Rise 0.1705 0.1896 0.0191
Fall 0.1675 0.1870 0.0195
Arrival Times (Dynamic) Early Late CRP
Rise 0.1641 0.1960 0.0319
Fall 0.1610 0.1935 0.0325
Selection Details
Arrival Times: Using Dynamic Arrivals
Edge Match: Match, using rise CRP
clock reconvergence pessimism 0.0319
Information: The CRP value reported by report_timing and report_clock_timing will be -0.0000. (UITE-468)
As seen, we have difference btw actual and reported in the timing report values (UITE-468 message). I tried to reduce "CRPR_threshold" value from this report ( by seting " timing_crpr_threshold_ps" command), but it does not work, I can only increase "CRPR threshold" value, but not decrease. The question is - how I can set this CRPR Threshold value and make CRP value from this report and from "report_timing" equal?
The problem is solved by updating PT tool.
