How to write the code for the nonlinear equation using an ode 45 of matlab?
rahul.6sept
Full Member level 5
Guwahati, India
How to write the code for the non linear equation using ode 45 of matlab?
Dear all,
Kindly let me know as how to write the coding using ode45 in Matlab for the following non linear equation:
I'm slightly confused as what are the parameters to be passed in the function that is to be written.
del Chi/del T = mu(1-BC)(mu[SUP]2[/SUP]/2 -1)*chi*del chi/del x + (mu/AB)del[SUP]3[/SUP]chi/del x[SUP]3[/SUP]
Regards,
Rahul Chakraborty
Re: How to write the code for the non linear equation using ode 45 of matlab?
You have Chi as a function of T and x. d/dT(chi) has no T on the right hand side. What is the real problem?
I've written the function as
function chi = nonlin (T, chi)
But I'm not sure if the parameters passed are correct or not.
You did not read my post; the LHS (d/dT Chi) is a derivative of T but the RHS does not have any T. You need to be explicit with both T and x because these two variables are key ...
Yes I missed a sign. This is a kdV nonlinear equation.
del Chi/del T + mu(1-BC)(mu2/2 -1)*chi*del chi/del x + (mu/AB)del3chi/del x3=0
I see now; your chi is a function of both T and x and similar problems are seen in heat conduction and diffusion etc. Yes, your function must define the derivatives.
Can you guide me as how to find a solution for the same? Any related tutorial if available, will help me immensely.
Hi, I,ve written the code, but it is giving a plot not expected.
%the function is for solving of the nonlinear kdv burger equation for the
%ion acoustic waves
% The kdv differential eqn converted to a second order differential eqn is:
% del^2 chi1/del rho^2 = [mu(1-BC)((mu^2/2 -1)chi1 -1)]AB/mu , where A,
% B,C are given by equations as given below in codes
% x denotes rho, y denotes chi1
function dy = kdvnonlin(x,y)
G=6.67*10^-11;
mi=1.67*10^-27;
sigma=0.1;
kappa=100;
gamma=3;
mu=1.0367*10^4;
chi_i=9*10^-1;
lambdaJ=2.1*10^28;
omegaJ=11.83*10^-13;
pi=3.1416;
X=(kappa-0.5)./(kappa-1.5);
A=(4.*pi.*G.*mi.*sigma.*(kappa-0.5))./(kappa-1.5);
B=((1-gamma).*sigma.*X)+(2.*sigma.*X)+1-(sigma.*X.*mu.*(mu+(chi_i./((lambdaJ).^2.*omegaJ)))).^-1;
C=((kappa-1.5)+ sigma.*(kappa-0.5).*(gamma-1))./(kappa-1.5);
y=[0;0];
dy=zeros(2,1);
dy(1)=y(2);
dy(2)= (mu.*(1-B.*C).*((mu.^2)-1).*y(1)-1).*((A.*B)./mu);
%Stability analysis of acoustic waves in nonlinear mode
% this is the main program to call the function
clear all
y0=[1e-2 1e-5];
xspan=0.001:0.1:10;
options=odeset('RelTol',1e-5);
[x,y]=ode45(@(x,y) kdvnonlin(x,y),xspan,y0,options);
%[x,y]=ode45('kdvnonlin',xspan,y0,options);
figure (1)
plot(x:),1),y:),1),'b--');
xlabel('X');
ylabel('Y');
hold on
%ion acoustic waves
G=6.67*10^-11;
mi=1.67*10^-27;
sigma=0.1;
kappa=100;
gamma=3;
mu=1.0367*10^4;
chi_i=9*10^-1;
lambdaJ=2.1*10^28;
pi=3.1416;
y=[0;0];
dy=zeros(2,1);
dy(1)=y(2);
clear all
y0=[1e-2 1e-5];
xspan=0.001:0.1:10;
figure (1)
xlabel('X');
ylabel('Y');
hold on
