Eagle Cadsoft - looking for crystal oscillator Smd part
Garyl
Full Member level 5
Hey,
I am looking for that part:
Including datasheet:
View attachment LFSPXO019082BULK.pdf
anyone know library when I can find matching part with that footprint?
It's easy to generate your own.
But in about 10 hours I can check our libraries. If you can wait that long...
Klaus
Reactions: Garyl
    Garyl
It would be very helpful.
I am still trying to make this oscillator element by editing existing libarries, but I am unsure about the schematic mirroring in Eagle.
I mean, if I have the underside view in datasheet, then should be my "red board view" in Eagle mirrored?
Please check, this is datasheet:
This is how it looks in Eagle:
(Each pin header is near the soldering pad, just to show which pad is which)
Do I have the pinouts mirrored?
Maybe you are confused by the schematic symbol.
--> a schematic symbol doesn´t care about pin orientation. Only the correct "pin to pad" relation is important: Pin2 = GND and so on
Klaus
Reactions: Garyl
    Garyl
