Compile package into "ieee_proposed"
Hugo17
Junior Member level 1
I would like to use the fixed point package from D. Bishop for an altera fpga. According to the header of the file
fixed_pkg_c.vhd it should be compiled into "ieee_proposed".
Could someone tell me how I can do that with Quartus?
thanks
you set the library in the file properties:
project -> add/remove files in project -> <fixed_pkg_c.vhd> properties -> library.
To be honest, you should be able just to stick it in the work libarary as Quartus is rather relaxed about libraries by default.
Reactions: Hugo17
    Hugo17
