MAX3221: RX working TX not working.
francis29
Member level 5
India
I am using MAX3221MDBREP in my design. It was working fine. Suddenly is not working. When i checked with DSO, RX side is working ( RS-232 level to TTL level).
But TX side is not working (TTL level to RS-232). Getting 0 Volts at TX pin (DOUT). While visual inspection the top of the IC has brown color as it got heated somehow.
What could be the reason??
Wrong connection? Wrong supply voltage? Wrong signal signal voltage?
Wrong PCB layout? Wrong parts? All is guessing.
How can we know? You don't show it to us.
